Correct method to mount the undertray | FerrariChat
Discussion in '206/246' started by yakxx21, Feb 26, 2015.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Having recently had my dino returned from an overhaul I notice the undertray is mounted to the chassis by pop rivets all the way around into the chassis tubes...was this as it was done originally ??
  2. MarkT
    MarkT Karting
    Jun 7, 2004
    180
    mountains-NC
    Mark Turczyn
    I have owned my GT since 1974 and that is the way my fiberglass undertray is mounted.
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    Totally correct to use rivets on the undertray.
  4. swift53
    swift53 F1 Veteran
    8,345
    E.S.
    Alberto
    Let's get slightly anal, rivet dimensions please?
    And, if making a new undertray from scratch, as of course the original was missing,
    just mold it on flat sheet metal?
    Thank you.
    Regards, Alberto
  5. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Thanks guys ... Appreciate your time
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I don't remember the exact size of the rivets but they can be matched by going off of the holes left in the chassis. As for the floor the earlier cars like your L series have a fiberglass floor which is totally flat with no detail of any kind to it. The later E series cars have sheet aluminum floors. Either one is pretty easy to make.
  7. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Are the alumimium floor flat or with a profile? The superformance one I bought has a profile / crease
  8. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I'll ask for others to chime in to greater detail however the aluminum floors I believe should have some ribs rolled into them. The earlier fiberglass floors are flat.
  9. swift53
    swift53 F1 Veteran
    8,345
    E.S.
    Alberto
    Thank you Rob!
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    05082 and 05702 both have flat fiberglass that was installed between the rocker lip and the chassis secured with rivets and oversized washers
  11. Ken Ivey
    Ken Ivey Formula Junior
    256
    Portland, OR, USA
    Ken Ivey
    I took a look at my aluminum undertray - #07228 - but without having it on a lift. It is attached with pop-rivets, without washers. There is no sign of ribs. That's how I remember it from earlier periods of laying under the car. I believe the undertray to be original – at 51K, it’s too beat up not to be.
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #12 2NA, Mar 1, 2015
