Correct paint for filter housing and header tank | FerrariChat
Discussion in '206/246' started by abstamaria, Jul 13, 2006.
  1. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    I need to repaint my air filter housing, which was repainted by a previous owner, and also the water header tank (original paint but needs repainting).
    Is the paint supposed to be a satin black on both these items, as opposed to flat or shiny black? Sorry for the basic questions - am very new to Dinos.
    Many thanks.
    Andres
  2. Dinoguy2
    Dinoguy2 Karting
    Nov 9, 2005
    91
    Racine, Wisconsin
    Bob Budlow
    I believe the air filter housing should be satin black, and the header tank should be gloss black. I just finished a long restoration on my Dino and that's what my restorer and I had determined after doing research.
  3. DinoDriver
    DinoDriver Formula Junior
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Dinoguy2
    I believe all the major black pieces in the engine compartment - air cleaner, air plenum, coolant reservoir - are supposed to be the same satin black. I found a terrific Rust-Oleum product several years ago "Ideal for Furniture, Fixtures, and Outdoor Decor," "Classic Low Sheen Finish," "Smooth Protective Enamel." The 12oz. spray cans are coded "7777 Black." Looks glossy when it goes on but dries perfectly to a satin finish. Just follow the instructions on the can. This has worked well for me over the years and at the recent 2006 FCA Annual Meet, I took a Platinum Award in class and the Dino Ferrari Award for "Best 2-series Dino." The judges loved the engine compartment so I must be doing something right!
    Oh, don't forget to do the interior of your filter canister, too. The bottom of this area tends to collect moisture (when you wash the car, drive it in the rain, etc,) and will rust unless well protected. Start will a spray coat of Red Primer 7569 and follow with 7777.
    Good luck,
    Bill
  4. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Quite right, mine is still original and all elements satin black as you describe. I guess the paint you used has stood up to the heat.
  5. Dinoguy2
    Dinoguy2 Karting
    Nov 9, 2005
    91
    Racine, Wisconsin
    Bob Budlow
    My restorer has been working on Dinos for more than 30 years. He recalls near-new Dinos in his shop in the mid-70's with gloss black header tanks. I have also seen 2 Platinum-level Dinos in the Chicago area with gloss black header tanks. In one of Anthony Curtis's books on the Dino, there is a photo of an "original" Dino showing a glossy tank. However, I also have seen Dinos at Concourso Italiano with satin header tanks. I think this is another example of the phrase I have seen on this site - "In the world of Ferrari, there are sometimes no absolutes!"
  6. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Dignini,
    No problem with engine heat for the Rust-Oleum for at least the last 10 years. I suspect Rust-O's spec for outdoor metal furniture paint calls for a simulated test for a black wrought iron chair on a patio in Phoenix, in the direct sunlight, 110 degree day. Chances are you'll get a bad burn if you touch that baby! Same might be true with the expansion tank, especially if the engine is overheated. Give it a try and let me know what happens! :) just kidding.
    Dinoguy2, yeah, could be the early cars were glossy. I had a '72 in 1974-1976 but I don't recall the expansion tank finish. My current '74 has always been satin since I bought it in '77. I'll pay more attention to other Dinos and see if there is a trend with model years. I'm surprised we haven't had more responses to this thread. Keep what you have if your restorer can back up his research. What year is your car and who is the restorer?
    Bill
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I used Plasticote BBQ paint on the header tank of my 328 - almost perfect match for what was on there (satin black).
    I.
  8. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    #8 Crawler, Jul 15, 2006
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Not quite 100%, Your radiator hose clamps are non-original
    Brian
  10. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    You're right. 99.5%
  11. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Dinodan.
    Based on the configuration of the firewall - no aluminum sheeting - and a few missing info/warning plates here and there, I'd guess this is an early Dino, maybe European specs. If so, it blows my theory about the early cars having a glossy finish on the expansion tank. Doesn't look too glossy to me. Can you confirm/deny my guess.
    Bill
  12. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Bill:
    Nope, not an early car. It's a '73, s/n 7412. You're correct that it is a European spec (actually GB RHD) car. That would probably account for the lack of warning plates and maybe the sheeting. Maybe US spec cars ran hotter and had the sheeting to reflect heat?....
    If you look carefully, there's a plate affixed to the top of the plenum from the London Ferrari agents, H.R. Owen. My dad bought it new from them in early '74.
    At least your expansion tank paint theory isn't shot full of holes!
    Dan S
  13. abstamaria
    Feb 11, 2006
    2,668
    Andres
    Thank you all for the advice, which has been quite useful. My expansion tank does not look like it's been refinished. It has a satin finish, matte in some areas, but this could be the effect of the years. There are some shiny areas, though, as on the ridges, so it is possible that the tank was painted a gloss black originally. I'm leaning toward satin.
  14. racerboy9
    racerboy9 F1 Rookie
    2,642
    Is your firewall painted silver?
  15. racerboy9
    racerboy9 F1 Rookie
    2,642
    Are your gas tanks painted silver?
  16. Dinoguy2
    Dinoguy2 Karting
    Nov 9, 2005
    91
    Racine, Wisconsin
    Bob Budlow
    To DinoDriver -
    My car is a 1972 Euro production coupe, # 04092, approx. June production. Restorer is in Northern Wisconsin. There may something to the previous comment about earlier cars having a gloss finish header tank. I also think that the euro cars made running changes that are sometimes difficult to document precisely. During the restoration, they removed several dents in the header tank, then stripped and repainted it. My restorer told me that it did not appear that the tank had been repainted, and that the original paint had a gloss finish. Hope this helps.
  17. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    My new theory is, "Nothing is constant but change." Good luck!
    Bill
