correct washer bottle for a '77? | FerrariChat
Discussion in '308/328' started by Doug, Jan 7, 2010.
  1. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    My '77 GTB came with a makeshift washer bottle hidden under the pass side louver. I took it out and got a bottle. However, I have seen pics where the early cars have the soft bag. My car has the vinyl zip cover for the spare compartment that covers the tire and the washer fluid etc.... I can get the soft bottle and sell the other, but I want to know which is correct.
    thanks
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    It's the bag type with the washer pump attached to it. It is located in the center of the plastic tub and attached to the tub. The pump almost hits the back of the radiator. Call Rutlands and see if you can get one from a salvage car. I bet they are a bit pricy.
  3. detroit
    detroit Karting
    Jun 20, 2006
    101
    Detroit area
    Eric
    I have an early '77 - 20613. It's got the bag, if that helps...
  4. Steve King
    Feb 15, 2001
    4,367
    NY
    20927 here born in Feb. 77
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    +1. Mine has the bag. I always thought it was a bit cheesy! When I first got the car, I thought it was a half-assed repair by some doofus!
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
  7. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    I have a '77 (Jan 77 - Happy Birthday!!) and it has the bag
  8. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Ha.
    When i first started getting into the construction aspects of my car back about 1985, I thought the whole car was built that way!
    Everything pop riveted on, fiberglass wrapped around steel supports here and there, etc. I finally decided that is the only way you can really build a limited production car and not have it cost a fortune.
    Doug
  9. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    I've got a '78 GTS and it has a plastic (leaking) bottle. Maybe I'll go with the bag. Price isn't too bad. Anyone know if these are available in the states?
  10. 360C
    360C F1 World Champ
    #10 360C, Jan 7, 2010
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    There ya go......nice!
    Happy New Year!
  12. BigTex
    79,386
    Houston, Texas
    Bubba
    Where's your battery cover?????
  13. dave80gtsi
    dave80gtsi Formula 3
    1,920
    Ohio
    Dave Meredith
    #13 dave80gtsi, Jan 8, 2010
    That bag appears to be identical to the OEM washer bag / pump that came with my 1978 Fiat X1/9.
    I'm the original owner of the X1/9, so I know it's OEM factory spec.
    Point being that a poke around some Fiat wrecking yards / parts suppliers should get you one of these for way cheap money!
    Cheers - DM
    Edit: How does $37.00 sound to you?
    http://marketplaceadvisor.channeladvisor.com/StoreFrontProfiles/DeluxeSFItemDetail.aspx?sid=1&sfid=82804&c=437597&i=175673426
  14. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    Awesome color.
  15. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    thanks
    Just ordered one
  16. veloce33
    veloce33 Karting
    Feb 4, 2009
    124
    Vandalia, OH
    Shawn Hobbs
    As a long time Fiat guy, you will never find a non-leaking X1/9 washer bag with a working pump.
  17. david
    david Formula Junior
    Feb 21, 2001
    809
    Northwest
    david
    For the record, I have an October 77 - 22871. US model. It has the plastic washer bottle that hangs off a bracket. The bottle actually hangs inside the spare tire.
  18. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    And I've got 22891 (Nov. 1977) that uses the plastic bottle + bracket arrangement as described for 22871.
  19. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    For all of you with the hard plastic bottle, do you have the vinyl front bonnet cover as shown in post#10 by 360c, or do you have the hard plastic cover that covers the brake booster and all the other stuff?
  20. Steve King
    Feb 15, 2001
    4,367
    NY
    Doug I believe the change over to the plastic tire cover and plastic bottle was in 1978.
  21. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    My Sept, 1978 manufactured car has a hard bottle and hard fiberglass tire well/brake booster cover.
    Doug
  22. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    +1 my Lancia Scorpions use the exact same water bags, I used to have a bunch of the that I threw away but I may have a couple left. Also used to get them from wrecking yard for like $2.00 a piece.
  23. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    #23 samba-lee, Jan 10, 2010
    These washer bags were fitted to all Fiats in the 70's and early 80's so they are pretty common, although come in different shapes and sizes. I would not advise getting a used one as they don't last too long and often spring a leak where they've been folded a little or rubbing on something.
    We had -15º temps here in Manchester, UK and I pulled my washer bottle out of my GT4 because it had frozen solid (although I was more bothered about the coolant freezing of course but it has been ok).
    That bag must keep nice and warm in a GTB/S that close to the radiator - it sits in the headlamp area in a GT4 just like an X19
    Lee
  24. 360C
    360C F1 World Champ
    In the rear boot carefully wrapped up for protection. The spare wheel damages the paint, which aggravates my anal retentive side.
  25. 360C
    360C F1 World Champ
    #25 360C, Jan 11, 2010
    Thanks, it's Pino Verdi metallic.
    Funny story attached to this car and colour. My late father and I went to the Melbourne Motorshow in 1978 and this very car was on display. At the time he was seriously looking to fulfill his life long ambition of buying a Ferrari after decades of blood, sweat and tears. He looked at the car and proclaimed "who would buy a green Ferrari? ". Like most newbies he wanted red. So when he visits the dealer after the motor show he finds that the green car was $42,500 Australian and ordering a red one would take 6 months and the price would be $48,000 (rampant inflation in Australia at the time). So he reasons he could get a pretty good red respray for that and he didn't want a crappy fibreglass body anyway, so he up and buys the green car! Over the years the colour grew on us and when he repainted it years later it was in the original colour. I bought it from him in 1986 and after using it rather vigourously for 3 years I did the full nut and bolt restoration- it took 10 years; but that's a story for another day. There was never a moments doubt that it would be restored in anything other than the original Pino Verdi.
    The attached photo is of the car in the 1978 motorshow and another of the car as it is today.
