Is this the correct stencil I would use to restore the faded lettering on my 3.2 Mondial airbox? Ferrari 308 328 Airbox Restoration Lettering Stencil | eBay I would assume that this would be more correct than the vinyl "Ferrari" stickers I have also seen used for this purpose. Since this will probably be a one time use item for me, is anyone else interested in using it after I am done with it? Alden
I think it looks correct. My airbox was redone with a stencil in 2008... here's how it looked in 2011. It still looks the same now. Makes a big difference. Image Unavailable, Please Login
You did a fantastic job Charles. I bought the stencil and tried painting it with a brush and it turned out horrible for me. Did you use a spray can because I think this is only way that it won't run or smear.
Did mine couple months ago some tricks I learned: respray the cover apply 3M spray glue to back of stencil let dry until sticky apply stencil to cover spray 1 coat LIGHTLY ALLOW TO DRY REPEAT FOR 2nd Stencil there will be a little bleed along edges I used x-acto to carefully remove bleedthrough http://www.ferrarichat.com/forum/mondial/484524-stencil-air-intake-cover.html
Don't buy a stencil yet, we may be able to re-use the stencil when I get done with it, I'll let you know. Alden
