Corroded main fuse panel | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Britward, Apr 27, 2022.
  1. Britward
    Britward Karting
    Sep 8, 2021
    97
    SF Bay Area
    Rob Ward
    Hi All, a couple of weeks ago one of my fuel pumps gave up but really the problem is more about the main fuse panel being corroded than the fuel pump.
    The fuel pump connections on the board are temporarily fixed but it's only a matter of time before another part of it goes and some random peripheral such as the brakes/lights/cooling fans stop working.
    Any idea where I might source a spare?
    1986 412, the fuse panel in the passenger footwell (on left hand drive car).
    Thanks!
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,276
    Lyon (FR)
    R. Emin
    Your pumps and in-tank filters have to be replaced: the pumps draw too many amps.
    Good luck finding a clean fuse box. Some repro were made for the 328. Could be used for your car but expensive.
  3. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,435
    Make sure your pumps are no shorting out, ideally remove both, you will be surprised what you can find in there. It is easy to, all the parts are readily available and not expensive. I recently did them, happy to guide you through it.
    I would not waste money on getting a new fuse board, it will be expensive and not necessary. Rather what you can do it first clean all the connections, fuses and relays, and then for the high amp ones make a separate circuits - namely the pumps, radiator fans and the lights; foe the rest the fuse board is more than adequate.
  4. 57Wayne
    57Wayne Karting
    Mar 29, 2015
    139
    Wilbraham MA
    Wayne Thresher
    Hi Britward,
    As I mentioned on FB, I have an 86 412. Most of my discussions on this forum have been regarding troubleshooting a recurring and somewhat random "one pump out" situation.
    At the recommendation of another owner I replaced my relay panel in the passenger side footwell first. I was able to source it from GT Car Parts in Arizona. At the same time I replaced two of the connectors and maybe four pins in the connectors where there were burn marks from high current draw. I also replaced all the relays, because I was there and looking to avoid the future mystery game.
    I still had the same fuel pump problem although it seemed better.
    Checking resistance from the white connector at the relay panel to the connector closest to the pump in the trunk, the right side was very different from the left. By this time I had already replaced both pumps and all the rubber bits that had turned to gum inside the tank. Both of the old pumps had been replaced by a PO, and still worked. I have new pumps anyhow.
    There is ONE connector between the relay connector and fuel pump connector. It is at the firewall, behind the battery. Remove the battery and you should see it. A wiring diagram helps here too. I cut the fuel pump wires from the connector and wired into a heavier duty connector. Resistance to the rear was now the same from both circuits and both pumps worked. Car runs on 12 cyl, all the time.
    Search for my other posts. I was working on it last year at about this time. There should be photos still there.
    Good luck.
    Sent from my moto g(7) play using Tapatalk
  5. 360modena2003
    Jul 11, 2009
    2,435
  6. 57Wayne
    57Wayne Karting
    Mar 29, 2015
    139
    Wilbraham MA
    Wayne Thresher
    Both are in that connector. I simply wired the second connector in parallel with the original. Added a little wire length.
    I must not have been proud of my soldering job as I did not take pics! Intent was to solder the wire extensions and cover with shrink tube. It was kind of tight, so not as neat as I envisioned. A crimp butt splice with heat shrink jacket would probably work better.
    I bought these connectors on Amazon; IEUYO 1/2/3/4/6 Pin Way Waterproof Electrical Connector kit 2.5mm Series Terminals Water Resistend Connectors Quick Locking Wire Harness Sockets 6sizes/9sets
    Kit3/122Pcs/6Sizes/9Sets and picked one from there. $15.
    I'll try to grab a photo later and post.
  7. 360modena2003
    Jul 11, 2009
    2,435
    Great, but how did you get the "extra" wire from there all the way to the pump?
    But this still keeps all the amperage on the original fuse board.
    Another way would be to add two new relays in the trunk, and have those fed independently, this way the only tension on the fuse board would only be the minimal current needed to "close" the relay.
    Sent from my MAR-LX1M using Tapatalk
  8. 57Wayne
    57Wayne Karting
    Mar 29, 2015
    139
    Wilbraham MA
    Wayne Thresher
    There was no problem with the wire. I confirmed resistance with the new connectors and left it in place.
    The problem was with the connectors.
    There are other options to solve the problem. I chose to keep as much of the original as made sense, esp since I had a new relay board ( new manufacturing methods vs mid eighties early multilayer circuit boards that were more likely to have failures with heat cycles).
    My connectors at the relay box and firewall showed burn marks for the fuel pump circuits. The connector pins were also soft / guessing heat annealed them.
    That's what I did, and it's worked for me!
  9. 57Wayne
    57Wayne Karting
    Mar 29, 2015
    139
    Wilbraham MA
    Wayne Thresher
    Photo of the connector. The wire is pretty good gage, but orig connector was too small. Image Unavailable, Please Login
  10. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,670
    Romulus, NY (Finger Lakes)
    Ken Battle
    Clearly the 412 is wired different than the 400i based on comments above. I believe the correct solution is what I posted several years ago and seconded by 360 modena above: "Another way would be to add two new relays in the trunk, and have those fed independently, this way the only tension on the fuse board would only be the minimal current needed to "close" the relay." For the 400i my two relays are underneath the rear seats which is just above the fuel pumps and the 400i wires pass thru 2 grommets at that point. I used a #10 or 12 wire with 30 A fuse upstream of the fuse panel. Its neat and I have never touched the pumps since.
    Ken
    Ak Jim likes this.
  11. raemin
    raemin Formula 3
    Jan 16, 2007
    2,276
    Lyon (FR)
    R. Emin
  12. Britward
    Britward Karting
    Sep 8, 2021
    97
    SF Bay Area
    Rob Ward
    All, sorry for the late response to your very quick ones to my original post.
    Decided to start with a new fuse panel to get ahead of the next layer of problems waiting to happen. Had a PM from a guy on this forum, says he's made 200+ for various Ferrari, so going to take chance.
  13. SouthJersey400i
    Mar 14, 2007
    1,670
    Ken Battle
    Can you share his contact info? Cost?
    Ken
  14. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,579
    Argent/Brasil
    Guido
    Ken, I started a conversation about your fuseboard.
