Corrosion between different metals | FerrariChat
Discussion in 'Technical Q&A' started by WILLIAM H, Aug 13, 2013.
  1. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Suppose you have an aluminum frame s a steel cage bolted to it
    And just paint between the 2 metals
    Will they still corrode ?
    Anyway to avoid or lessen it ?
    Thnx
  2. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Powder coating. Will slow the process.
  3. staatsof
    96,125
    Fuggetaboutitland
    Bob
    There are special paints you can use as well. GOOGLE!
  4. Glassman
    Glassman F1 World Champ
    Aluminum and stainless will not corrode together. At least not in this lifetime.
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,606
    Honolulu
    Kevin
    Ahhh, dissimilar metals, I think over time they will still corrode. I believe anti-seize products are your friend here.
  6. fatbillybob
    Aug 10, 2002
    29,166
    socal
    Amazingly on surface one would say dissimilar metals corrode period. But anyone who has worked on say any Ferrari with steel studs in an aluminum block and say an NSX with same steel in their aluminum block will notice an immediate difference. Aluminum is not aluminum. So if the chassis aluminum is as good as the block aluminum I would say don't worry. If the chassis is like an NSX aluminum worry! I always thought the challenge cage design lacking and it is especially poor where it connects to the chassis. So much more can and should be done especially when steel cages are only bolted to an aluminum chassis. I would never race a factory challenge cage.
  7. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    You must be making funeral plans.
    One of the most common sources of cursing and hand-wringing in the sailing world is when someone tries to remove something mounted to an aluminum mast; a winch or cleat for example. In nearly every case, the mounting hardware is SS and the mast is aluminum. The non patented process involved is something sailors call "time weld". After a few years the SS mounting bolt and aluminum mast become one and you can guess the rest of the story; broken bolts, drilling out the bolt, use of an Easy-Out, stripped threads, etc. etc. Galvanic corrosion between aluminum and SS is a VERY serious concern.
    Of course we Ferrari types try to keep our cars from direct contact with salt water, but I would NOT want to have a non-insulated SS component against an aluminum part. The aluminum acts as an anode to the stainless steel. The Anodic Index shows that stainless steel and aluminum are just about as far apart ( this is bad ) as you can get for ordinary materials, unless you consider gold an ordinary structural metal (some Ferrari owners might).
  8. JL350
    JL350 Karting
    Jan 20, 2013
    217
    Galvanic corrosion is essentially a battery, key thing required is an electrolyte, ie water. The presence of salt and acids accelerate the corrosion process.
    Aluminium oxidises rapidly to alumina on the surface which protects the aluminium from further oxidation. Scratching the surface exposes aluminium which can then oxidise again. Alumina is very hard, while aluminium is soft, so where there is constant rubbing, the alumina wears the aluminium down.
    Steel rusts rapidly and needs a protective coating of zinc, paint etc, but coating strength is the real issue. Any movement between a painted steel and aluminium joint in the presence of water will create a corrosion and wear issue. This can take a long time or a short time depending on the conditions.
    I would put an insulating layer of rubber, Teflon etc between the two, make sure that the bolts are torqued properly to prevent movement of the joint and you should be ok.
  9. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Being an avid sailor and having owned several sailing craft over the years I can fully support the comments above about trying to remove fittings from a mast. Given that there are different environments and with a auto the situation is much different. I am also a fan of old British cars especially the Austin Healeys. They are made with body parts of both steel and aluminium. The upper shroud front and rear are aluminum and while the side fenders are steel separated by a nice SS bead that works especially well in isolating the parts and preventing corrosion. BB made a good point about the different forms of aluminium, there are differences there that can make a big difference. Just a thought.
  10. FPFaeth
    FPFaeth Formula Junior
    Dec 3, 2009
    663
    NY
    Frank Faeth
    When building the Maranello, didn't Ferrari have to use some type of spacer or material to separate the steel frame from the aluminum body to prevent galvanic corrosion? I recall reading that years ago when the Maranello first came out. Frank
  11. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    just a tid bit on aluminum- the oxide formation protects cuz it is one of the most DENSE oxides of metals, preventing oxygen from penetrating and causing more oxidation. Thats why steel/iron rusts easily, cuz iron oxide is no way near as dense as aluminum oxide. Rust is so flaky/lose, as we have noticed perhaps. It rusts forever, deeply, until no more iron left to oxidise.
    On the boat thing- gotta remember also contributing is the extremely salty environment. unlike ferarris parked in garage/driven away from salt water, etc. (yous dont park the ferrari on the beach, now, do you??)
  12. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    I design commercial airplane repairs for a living. Corrosion is a fact of life. There is no avoiding it.
    That being said, there is a lot you can do to slow it way, way down.
    For airplane parts with dissimilar metals... ( and that is most of them with all the alloys that are out there... ) the standard is two coats of zinc chromate epoxy primer on both parts with a poly-sulfide sealant between both parts. The primer protects the parts from atmospheric contaminants and the sealant barrier prevents the electrolytic contact.
  13. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Good tip, NW. Now, if one wanted to get a hold of a consumer quantity of the above, where does one get them? NAPA paint store? other?
  14. staatsof
    96,125
    Fuggetaboutitland
    Bob
  15. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Try Dupont paint products. Their Nason line of paints offers an etch primer with the qualities stated earlier. Use a Dupont paint store in your area. Most body shop supply house offer this product.
    http://pc.dupont.com/dpc/en/US/html/visitor/common/pdfs/b/product/nsn/Nason/491-17.pdf
  16. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    thanks. good to know, people.
  17. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    be sure to include the fasteners ( bolts, nuts, washers ) in the isolation process in addition to the parts being joined
    also the same also applies when joining parts to carbon fiber,
