Costs on f355 spyder top repair | FerrariChat
Discussion in '348/355' started by Dr.Gee, Mar 20, 2015.
  1. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Anyone have ballpark costs on seat positon sensors and hydraulic pumps.?
    97 if it matters.
  2. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
    seat pots NLA
    Hydraulic top motors can run 3500-5k
  3. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Thanks. What does Nla mean?
  4. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    NLA no longer available.
    You would have to get used parts.
    Or see if someone can rebuild them.
    I used to do hydraulics On Helicopters when I was in the Marines.
    If you can isolate your issue perhaps someone can rebuild them.
    Damn maybe I should get my business just to fix ferrari convertible tops.
    I would search ebay for cars being parted out.
  5. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I'd probably rip it all out and convert it to a 348 all-by-hand-mechanism. It's just over engineered for what it does, seriously!
    I understand a California hard top or even a 360 which need to be mechanically powered because of the complexity and the opening within the body of the car. But on the 355, it just sits behind the headrests and no body parts on the actual car need to move or open & close so it sometimes feels like an exaggerated thing to have a push button hydraulic system for such a simple & short range of motion.
  6. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Convert it to manual...DONT RIP IT ALL OUT...it isnt necessary. You can also call Russ @ Ferrparts he should have everything you need.
  7. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
  8. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Can you adjust the wiring to override the seat potentiometers (or however its spelled- the seat sensors is what I mean), and just move the seats forward before beginning the top down/up operation? This way you're not ripping out anything, and saving the money/aggrivation of dealing with those sensors...
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    I have all four rams plus motor all in great working order.I converted my top to manual.
    If you need them PM me.
  10. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    I just "manualized" my top. The seats do not have to be moved, just the seat backs. FWIW, it takes two people to raise my top; I'm not able to put enough forward/upward pressure on the front stay or bows. The ???????s on both sides of the car have to be maneuvered individually.
  11. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
  12. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Mine is the same..there is a technique to putting it up and down by yourself...I can send a video if you want
  13. janders82
    janders82 Karting
    Nov 26, 2014
    180
    Atlanta, GA
    can you provide more info on what your issue is?
    I just fixed my top a couple weekends ago. After hours of trying to figure the dang thing out, i started putting everything back together. Just as I was finishing up, I found a blown fuse. Quick trip to AutoZone for a 30A fuse, topped off the fluid, and 20 minutes later the top was back in business.
    Sometimes i have to play with the top's micro switch by the drivers visor to activate the process in putting the top down. Not sure if that micro switch is somehow linked to the seats or not.
  14. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,014
    PA
    Kevin
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,231
    CT
    John Kreskovsky
  16. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    You don't have to wire anything, it is already there. Pull the little button out of the side of the pump cover that is labeled emergency top switch and if the hydraulics and the top itself works you can run the top up and down with the buttons overriding the seat and window switches etc. You could probably wire that to the center switch if you wanted.
  17. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Or simply convert it to manual and be done with it. Takes 2 hours costs nothing and is reversible
  18. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    That's what I would do.
  19. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I think that's what he was talking about.
    I have my pots unplugged and I'll be rewiring the override switch to the console switch so I don't have to fiddle with the plug.
  20. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Please do.
  21. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    I will try for some reason I can't load video from my iPhone they are always to big
  22. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    It cost me $7633 at FNA to get my top closed last week. no warranty it wont happen again
  23. WATSON
    23,700
    WI
    Works great to.
  24. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    Wow why not convert to manual spec and save the money ? From the videos I saw it seemed effective. Luckily I never had a roof failure but then again I would only use the roof at the beginning and end of each season or if a rainstorm camr out of no where.
  25. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Tim,
    I suspect (hope) that included a complete new top, along with at least 5 individual components being replaced.
