countach at reunion island | Page 12 | FerrariChat
Discussion in 'LamborghiniChat.com' started by SCORAF974, Jun 2, 2010.
  1. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    ok Pascal , merci pour la traduction , c'est beaucoup plus claire ainsi pour moi .
    pour la dino on est reparlera dans 3 mois .
    i come back in garage to work on countach , this week end , may be i shall send another photos .
    bye all
  2. BB512 1980
    BB512 1980 Formula 3
    1,263
    AIX-EN-PROVENCE - F
    Pascal
  3. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    #278 SCORAF974, Apr 15, 2011
    EHHHHHHHHHHH merd,
    this afternoon i remove a master brake fiat ducato , first problem 5 outs , ok i can stop 3 , and try to put on mastervac , impossible , the 'barre anti rapprochement " is to neer .
    Hummmmmmmmmmmmmm , ok i have some electrod "fonte" and say i try , taht is more easy that i think , now i can remove it , and remerd, the out rear don't correct .
    I don't understand , some body write they remplace their master brake by ducato ? may be i dont sale the good maodel ? but somebody can say me if he know how i can find the tubing between master and repartition little more long ( + 1 cm shall ok ) ?
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1307240&stc=1&d=1302878338
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1307241&stc=1&d=1302878338
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1307242&stc=1&d=1302878338
    thanks for your answerk
  4. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    this morning the day start well , i find a solution for the master brake and put loocked (silicone), all is ok . for the clucht master , same , all is ok , i can put the first gear and move in garage , youpi .
    after i turn motor , when is cold , the slow motion are no stable , and when hot its ok , but a big problem , they are many smoke left exaust , right motor , many too for is normal .
    when i shut it i control all ring piston , all was free ,and cylinder are no use , no marked .
    Humm i am afrais i must open motor again , and loock are is problem , its sure , its the combustion chamber ? or may be , oil fault by gasket head ?????
    my night shall be white . if you have idea or conviction , iam ok to listen good idea ?
    thanks all
  5. You should be able to narrow down to 3 cylinders are causing the problem, just by looking at the exhaust, unless it's the entire side bank. Do a leak down test first. It might help isolate which cylinders need attention. Is it oil smoke, or possibly from the carbs being way off? Any ignition problems?
  6. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    HI EARLYCAT ,
    its a ggod start to loock 3 cylinder by 3 cylinder to remove muffler . but with this tick smoke white , i dont think its problem off carburator or ignition .
    Another precision in slow motion 1200RPM , they are no smoke , when i take 3000/4000rpm then they are many white smoke , impossible to inhale in garage .
    iam afraid its a piston or ring metal .
    i remove muffler this morning
    thanks for good idea
  7. Thick white smoke sounds like a head gasket. (Cylinder head machine work could be off as well). You can pressure test the coolant system, easy to do. You just put the engine together. I would run it for 20 minutes @ 2000 rpms (unless there is some noise) before I pulled it out. Then re evaluate the situation.
  8. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    YES I MAKE THIS CONTROL ALSO , but you think white smoke is water , but for me its oil , you smell oil .
    i think , may be "reniflard" /recuperation oil ? i can remove the tubing go to the air filter and loock .
  9. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    HI COME BACK GARAGE FOR SOME CONTROL
    first the level water is correct
    i put 4 finger in out muffler , the 4 out have oil burn ,
    i ok to say , may be i make ONE error on one cylinder , or may be ONE ring metal piston are destroy , but oil in 4 out muffler , its impossible .
    its possible they was old oil in the muffler
    Or , all compression is bad , i try to find a tool to control this .
    if we are some idea ,,,,,,
    thanks
  10. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    Christian, sorry I do not remember from your earlier messages if you put new rings on the pistons. Does the Countach have new oil rings? Is it possible that an oil ring or compression ring is installed upside down and will not seat correctly? That could be a possible cause for oil blowing by the rings and out the exhaust.
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #286 2NA, Apr 16, 2011
    I'm having great difficulty following your descriptions but I would recommend a cooling system pressure test, examine the oil for evidence of coolant contamination. Inspect spark plugs for differences in color. White smoke typically means coolant is entering the combustion chamber. Head gasket, cracked head or cylinder liner are common sources. Oil smoke is typically a blue color and could be leaking by the pistons/rings or valve guides.
    You seem like a pretty resourceful guy but it's helpful to go down the list and check all the possibilities.
    Is the oil level correct?
    Is the crankcase breather working properly?
    Are all cylinders firing?
  12. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    hi thanks for your answerk ,
    i dont chnage ring to pistons , put my countach only 13000kms .
    i only wash the piston and ring , dont put out them , and impossible they are in bad side .
    yes i know smoke oil is little blue , i just star again the motor , the motor turn 10 mn in lown motion and some smoke arrive , i think , may be they have in muffler ? but i turn motor 3000/4000 5mn , huuuuuuuufffffffffff impossible to inhale ,.
    the thing , i shortly the guide valve , same in my race car ( and they dont smoke ) .
    i phone a friend have a control compression tool , and write them the result .
    thanks
  13. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    The continuation , this morning i looock two spark , little wet oil , but its no this ; after i start 3 time 10mn , and i loock the smoke are less important ;
    i phone a friend very good in mecanical ( 40 years experience in A110 alpine renault) , and i talk he all , and he answerk me ( a good explication ) when i wash piston and ring , i position 3 ring 120° , then they loose they position in cylinder , then for 1000 kms , they make their position and i burn little oil . For me its a good explication , more , maybe in muffler they are little oil when the last owners destroy the gasket head .
    Then for the moment , i must find compression tools and controle , how many PSI or BARS , i must have ?
    i shall correctlely ignition , because i have 40cm fire long when i decelerate , impressionnant .
    ok i say you in the week what news .
    thanks all
  14. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,350
    USA/France
    Christian,
    your are deep into mechanicals here. Not many people get that involved in their car, including me. I would suggest that you split your messages in a French part and the translated english part. They are many French speaking guys on the board. The French are good at car work. this way someone can always translate again from your French if your own is too hard to get.
    Christian
    Tu es au coeur des problemes mecaniques. Peu de particuliers vont aussi loin dans l'entretien de leur voitures. Je te recommande de poster tes messages en 2 sections: une Francaise et une en anglais. Il y a pas mal de personnes qui parlent le francais ici. Les Francais sont assez doues en mecaniques en general. De cette facon,= quelqu'un peut retraduire ta partie Francaise si ta tranduction est difficile.
  15. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    ok countach QV ,
    je disais donc que depuis hier aprés avoir redemarré la countach , j'ai était surpris d'avoir autant de fumée a la sortie des échappements .
    Ce qu'il faut savoir , c'est que je me suis juste contentais de nettoyer les pistons et segments sans les démonter , donc pas d'erreur d'en avoir mis un a l'envers . les chemises ne sont pas neuves , mais ont seulement 13000kms , pas de ressaut et pas de couleur de blowby , j'ai donc pris la decision de remonter les pistons /chemises et segments sans mettre du neuf .
    Les segments coulisseent parfaitements dans leur george , pas de grippage .
    ma premiere idée est , un segment cassé , bien qu'ayant pris toutes les précautions au remontage , mais cela peu quand même arriver .
    puis en controlant la sortie des echappements , les 4 sorties sont grasses / huileuses , imposible donc d'avoir eu de la casse sur 12 cylindres en même temps .
    deuxieme idée , et si l'ancien proprio en détruisant les joints de culasses ( revoir l'historique de mon post ) n'aurait pas amené de l'huile jusqu'au silencieux , et voyant la voiture fumer anormalement , l'aurait abandonné depuis 10 ans !!!!
    Les bougies sont juste sales (carburation pas encore au top et calage de l'allumage pas encore fait a la lampe strombo ) d'ou leur couleur .
    J'ai aussi lors du démontage profiter pour faire sauter le bout des guides de soupapes qui gêne la vaine d'air ( je le fais toujours sur mes voitures de courses et aucune ne fument . le jeu soupape / guide ne ma pas semblé anormal , je me rappel avoir monté avec du WD40 pour un parfait coulissement ) , le probleme ne vient pas de là .
    J'ai redémarré 4 fois la voiture ce matin , a chaque fois j'attendais le déclenchements des ventillo au ralenti ,pour commencer a donner des petit coup d'accélérateur entre 3000 et 4000rpm , c'est a ce moment que ca commence a fumer beaucoup . PAr rapport a mon idée (d'huile dans le silencieux ) ca serait normal car le pot commence a chauffer et l'huile a bruler . CE qui est positif , c'est qu'au 4éme demarrage , ca fume de moins en moins .
    De plus en positionnant mon oreil a l'entré du filtre (cone en fiberglass fixé sur les radiateurs ) le bruit est trés régulier et sans cliquetis .
    j'ai aussi appelé un copain en Corse qui est trés bon en mécanique ( 40 ans d'experience dans les alpine renault A110 ) , il me demande si j'ai tiercé les segments . ma réponse est oui bien sur , et me demande si j'ai changé les chemises , je lui dis que non au vue du kilometrage et a leur apparence , et c'est la qu'il me dit
    " tu as déplacer les segments dans leur chemises , donc perdu la parfaite étanchéité du a l'inévitable ovalisation des moteurs (surtout en V ) donc il y a une légére remonté d'huile mais qui partira en roulant , il avait fait la même chose sur un moteur renault est au bout de 1000kms , l'étanchéité est redevenue bonne et plus de fumée a l'échappement .
    CEtte explication me convient parfaitement , mais pour autant j'essayerai de prendre les compression pour en avoir le coeur net . Quelqu'un peu me dire le taux de compression attendu pour ce moteur ? le rapport volumétrique est de 9,5 sur les 5000S il me semble .
    Si parmis vous , quelqu'un a une autre explication , ou controle a éffectuer , je suis preneur , bien évidement je vous tiendrez au courant de mes avancées .
    Pour la petite histoire , le moteur hurle ca rage en crachant a chaque décélaration 4 long flamme bleue de 30 cms , a filmer pour vous la prochane fois .
    il est vrai que c'est la seule countach que j'entends dans ma vie , mais ce moteur ne semble pas etre malade , ca respire fort , a suivre.
    merci a tous .
  16. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    pour la durite de frein trop courte j'ai "résolu" le probleme en décalant le limiteur de pression .
    J'ai ensuite essayé l'embrayage , les vitesse passe bien sans craquer et la voiture avance , ouahhhhhhhhhhhhhhhh , faudra voir ur route plus tard , mais petit rappel , j'avais agrandis le recepteur de 0,3mm pour rattraper la corrosion et parfaire donc son etanchéite , revoir mes post .
    De plus j'ai également mis un disque kevelar , je vous dirais lors des premiers essai route si ca accroche bien ( car théoriquement il leur faut 20% de pression supplémentaire ) , ma butée acier pour l'instant n'a pas cassé ( voir ancien post ) , tout va bien , oufffff
    une photo du moteur tout remonté ( il me reste a changer les blance des fils de bougis pour que ca soit encore plus beau ) toutes les durite d'eau sont en inox .
  17. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    #293 SCORAF974, May 2, 2011
    HI ALL ,
    i send you news my problem smoke , ouffffffffffffffffffffffffff , it was the old oil in muffler , i take with a friend this week compressor motor .
    11 cylinder have 11,5 bars and one 12bars , its perfect , smile return , then after i control rear wheel and front , i put their wheel with news tyres , and put original value .
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1316852&stc=1&d=1304347469
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1316853&stc=1&d=1304347469
    http://www.ferrarichat.com/forum/attachment.php?attachmentid=1316854&stc=1&d=1304347469
    all is ok , i must finish the spoiler , the next week .
    the next week also a friend come at hamo to film the motor move with sound .
    the next time , another countach shall run , YEsssssssssssssss .
    thanks
  18. SCORAF974
    SCORAF974 Karting
    May 30, 2010
    120
    REUNION island
    christian
    #294 SCORAF974, May 12, 2011
  19. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks and sounds pretty good. Glad you are back together.
  20. JonathanElstein
    JonathanElstein Karting
    Oct 19, 2010
    149
    London, UK
    Jonathan Elstein
    I haven't been to Reunion, but I was in Mauritius last year which is not too far away. This is a very beautiful part of the world, but it didn't seem to me to have the infrastructure to enable people to do what you have done with your car. Having just had my Silhouette engine rebuilt by a professional team in the UK, I have some idea of what's involved and I therefore have the utmost respect for what you have accomplished so far largely by yourself (with help from the forum experts).
    Enjoy it!
    Jonathan
  21. Peter K.
    Peter K. F1 Rookie
    4,448
    Connecticut
    Peter K.
    Excellent!
    Nothing like seeing those carbs at work!
  22. norcal2
    norcal2 F1 Veteran
    Sounds and looks great! great job!
  23. effer
    effer Formula Junior
    Jan 6, 2004
    814
    near Montréal
    François R.
    Wow! Congratulations Christian!
    Thank you for bringing another Countach in top shape!
    Super travail! Tu vas avoir encore plus de plaisir à sillonner les routes avec!
  24. thedoc
    thedoc Formula 3
    May 27, 2009
    2,159
    christian says... "smile return"!
    that just about sums it up .
    Great thread!!!!!!!!!!!!!!!
    Gary
    Espada
    8394
