Countach Door Latch. Will Mercedes Latch Work? | FerrariChat
Discussion in 'LamborghiniChat.com' started by frached, Jan 20, 2018.
  1. frached
    frached Rookie
    May 20, 2017
    40
    Tampa
    Fares Rached
    Hello,
    I am looking for a drivers side door latch assembly for my 1988 QV. I saw a thread where a gentleman stated the door latch from certain early 70s Mercedes would work. If you have any info on this or a door latch for a 1988 QV let me know.
  2. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Here is what i would do.Locate a Mercedes of the model claimed to have the similar door latch, Look at it, there is your answer.
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    At least in the Ferrari world Mercedes latches look the same on the outside but the internal linkage is different. I researched this in great detail during a Dino restoration and found a lot of different variances among the Ferrari latches with no direct cross reference to any Mercedes latch. The latches are also press riveted together and impossible to disassemble to mix and match parts.
    As for the actual catch that goes on the door frame those are all the same as 70's Mercedes and not too hard to find. The modern replacements found on eBay are not correct as they are all for the later cars (with angled receiver cones). You want the ones in which the cones are square to the mounting holes and those are only available from a scrapped car. As a tip if you find a wrecker tell them to give you the receiver from the rear doors as they are almost always new compared to the front door ones :D
  4. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    I do believe I have that. Do you still have the old latch?
