Countach Downdraft 1985 to 1988.5 | Page 194 | FerrariChat
Discussion in 'LamborghiniChat.com' started by joe sackey, Oct 25, 2015.
  1. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4826 joe sackey, Nov 19, 2016
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4827 joe sackey, Nov 19, 2016
    Enough on this topic, but, I do think they are a nice touch!
    Of course in some countries where currently-registered front plates are enforced, you can't mount the EE plates anymore.
  3. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Another (cold-starting!) Countach Downdraft with the heat-shield behind the exhaust not painted black
    [ame]http://www.youtube.com/watch?v=E4fKDkc3wIs[/ame]
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4829 joe sackey, Nov 19, 2016
    And here is the beautiful FLA12858 (or is it GLA? I'm doing this from memory) that also has an unpainted heat-shield.
    * Before anyone comments, I belive that plate is gone!
  5. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    Yes, they are taking the classic cars seriously and I can tell you that a complete restoration of the LP400 Prototipo is under consideration. Patience is a virtue...
  6. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    Are you seriously suggesting that Guerra's jig didn't work properly? The cause of variable ride height is possibly attributable to worn springs etc...
  7. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    I am aware that plans are afoot under this new CEO to show more care for the classic cars, because I have recently been contacted by someone who will be involved in that process.
    But waiting 15 years is beyond being patient, considering the minor rectification the car needed and what the time-span conveys. Under the previous CEO the works could easily have treated the LP400 with a little more respect the past 15 years - have you seen the non-original smoked turn-signal lens covers they applied a few years ago?
    Seriously :rolleyes:
    That's said, its good news to learn first-hand that some long-overdue TLC will be forthcoming.
    Here is the LP400 Prototipo, about to be shown to the whole world on the Grand Tour, sadly still with its cosmetic aberrations...
    [ame]http://www.youtube.com/watch?v=AaZqhgGkR2A[/ame]
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4833 joe sackey, Nov 20, 2016
    I am suggesting precisely what I said, which is - bearing in mind the hand-built nature of our cars, another consideration is going to be, is the body affixed to the chassis precisely the same on both sides?
    My suggestion has nothing to do with worn springs or less-than-optimum suspension geometry - which we have covered.
    Although a jig is at play to standardize placement of flexible body panels and align them properly, they still had to be riveted on by human beings, and I know it to be an indisputable fact that many Countach bodies are not precisely symmetrical from left-to-right as they leave the factory!
    I base this knowledge on the dozen or so Countachs Ive owned the last quarter century, and perhaps a hundred more I have inspected, and you'll note that when you are talking the difference of a sill riveted on to the chassis just 2mm higher on one side than the other, that alone can account for the measuring difference we are seeing in some Countachs - as Harry's measurement experiment may have showed.
    All credit to Giancarlo Guerra's jig, but just because a jig is used does not mean the outcome is automatically perfect, with a hand-built car. Perhaps his jig was used more properly by some teams than others, but the fact remains that Countach bodies have lots of 'character' from the factory, and that's what I was referring to.
    After the jigs were used to help apply the panels, why do you think there were men with hammers beating on Countach bodies to get them better aligned and positioned?
  9. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4834 joe sackey, Nov 20, 2016
  10. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4835 joe sackey, Nov 20, 2016
  11. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4836 joe sackey, Nov 20, 2016
  12. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Best post ever. Also the fact it's coming from you,with your total covering experience,to those of us whith mechanical minds which do our own work,it's refreshing,for those out there with the Countach addiction but no mechanical skills,it's extremely informative and a big wake up call, thanks for posting the facts,your new book should be named, Countach, from A to Z.
  13. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    The jig was used to position and locate the major fixed panels but as your pictures show the opening and ancillary panels such as engine cover, doors, rocker panels and spats were fitted later without the use of the jig and some traditional skills were needed to get these to fit correctly.
  14. Maser
    Maser Formula Junior
    Jun 2, 2011
    254
    Harry Metcalfe
    #4839 Maser, Nov 20, 2016
    Aside: Jaguar Classic had the same problem when they measured an original E-Type Lightweight before creating the six £1M+ reborn Lightweight E-Types revealed a couple of years ago. They carefully measured an original (un-crashed, un-restored and utterly original) LWE using modern laser equipment and discovered the wheelbase on the lefthand side was approx 5mm different to the righthand side.
    The dilemma then was whether to make the six reborn LWE 'wrong' as well, or make them perfectly symmetrical left and right. In the end, the decision was to make them perfect, as they should have been in the first place!
  15. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    When my wife and I toured the Aston Martin factory in 1987 with the factory manager, Roger Stowers, he told me that building hand-built cars was a challange for sure. He said that when someone needed body panels to repair a car, all the spares were built oversized so the craftsmen working on the car hand plenty of excess material to trim away and have it fit perfectly when installed.
    Like he said "no two cars that left the factory were ever the same".
  16. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    You are missing the point of my rebuttal.
    Let me try another (perhaps more direct) way.
    To your comment "Are you seriously suggesting that Guerra's jig didn't work properly?" my answer is: Yes, I am, sometimes the jig did not work properly.
    Why?
    Because the jig was operated by human beings, and the riveted application of the body panels had to be carried out by human beings.
    Accordingly, one side might be fitted 1mm or 2mm off than the other, and I have personally seen this. Therefore, when measuring from the sill to the ground, the measurement from left side to right side will not be the same, and this might fool you into believing the chassis of the car is not precisely level.
    Until someone shows me images of robots carrying out an automated manufacture of the Countachs, I stand by my assertion that the car's are not precisely symmetrical from side-to-side.
    In any case, I have first-hand proof of this based on my experience with the Countach that spans from back when the cars were still being manufactured.
  17. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Thank you, appreciate that.
  18. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Great story.
    BTW, to me, these Supercars from the hand-built era are very special indeed, because its almost as if they are 'alive' with individual character. Its like a human being looking in the mirror, not symmetrical either...
  19. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    That's a good expression to cover what I was trying to say.
  20. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #4845 joe sackey, Nov 20, 2016
    UK-registered E 3 ULL ZA9C005A0JLA12309, it was first registered on the 2nd of March 1988, and still looks as good as ever! No surprise, it has a great keeper.
  21. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    On the contrary. I understood and did not disagree with your reply. However you asked me a question:
    and I replied:
    If I have somehow misunderstood the construction process I am confident you will correct me!
  22. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    All the best jigs and fixtures in the world will only get you so far when positioning a hand formed panel on a hand made frame and fastening it by drilling holes by hand and riveting by hand. Errors add up to cause alignment issues which get solved by hammering or other. A simple rivet can push or pull a panel out of alignment easily.
  23. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    No need, my only point of contention was to your original question "Are you seriously suggesting that Guerra's jig didn't work properly?" to which my answer is and will always be: Yes, I am, sometimes the jig did not work properly" for reasons (judging by other people's responses) I'm confident I have adequately described. Your original question came off as if Guerra's jig was infallible and that is was highly unlikely to be the cause of any measurement discrepancies.
  24. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    i do not know the VIN, sorry Joe
  25. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,097
    Rob
    #4850 Spyder-Man, Nov 21, 2016
    OK, I know these are not Countach gloves (Diablo) but better for the toolkit than the newer ones. In good condition. Must still be pretty rare?
    R
