Countach engine and engine bay refresh | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Nov 20, 2019.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #1 sp1der, Nov 20, 2019
    Just starting the next phase of getting the Countach all together sorted, so engine out precipitated by a small leak from the flange joint for the gearbox tube into the sump. Planned work is to clean and referb the engine bay components, new engine bay harness, and min sort out the cylinder heads as the valve stem seals are starting to show some signs of giving up the ghost - plus make a few things a bit more service friendly e.g. fuel filter location.
    Has uncovered some butchery to the exhaust by a ham fisted attempt to make it all fit which will require the LHS pipes to be re-made to properly align and remove the kinks caused by some-one bending them to make them fit and also welding on the sleeve connector at an angle! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Aficior, topcarbon, Peter K. and 2 others like this.
  2. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,088
    Rob
    Ohhhh, I shall be watching this thread with some interest. That exhaust mod must be worth at least 50 ponies lost!
    R
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Certainly won't help for sure
  4. Peter K.
    Peter K. F1 Rookie
    4,413
    Connecticut
    Peter K.
    Go all the way with the motor. There are usually are surprises inside :)
    joe sackey likes this.
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will see what we find for sure it's guides, seals, valves but suspect min it will be plateaux hone and new rings plus bearings.
  6. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #6 sp1der, Nov 24, 2019
  7. dinonz308
    dinonz308 Formula Junior
    858
    Dean
    Obviously from the pics you removed the headers with the engine still in place, but did you have to remove anything else to get to them? Is it possible to remove and replace headers without major deconstruction as you have done?
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    once the inlet manifolds were off it was easy to get them off, guess it took 20mins a side, it was easier taking these off to get to the engine mounting nuts.
    dinonz308 likes this.
  9. Spyder-Man
    May 11, 2004
    2,088
    Rob
    Great work as ever ;)
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Thanks Rob, hopefully last major step to getting the car back into great shape, as all major systems will have been gone through.
  11. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #11 sp1der, Dec 8, 2019
  12. That is progress. What is the bike? An old BMW?
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    The outfit is a Chang Jiang made in China, basic copy of R71 BMW. Not fast 32HP/350kg! but sounds and looks good. Also interesting as it is shaft drive so has reverse.
    EarlyCat and Spyder-Man like this.
  14. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,018
    Switzerland
    Raymond S.
    You have already the new head gaskets of Victor Reintz, can be identified by the blue Silicone layer.
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Yes already got new gaskets, valve seals, just need to sort out valves now to get the heads done.
  16. joe sackey
    Sponsor
    May 23, 2006
    57,418
    Southern California
    Joe Sackey
    If you can or are so inclined, when finished please arrange to have it dyno'd on the bench to get true hp numbers.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    It maybe a while, too many projects on the go!
  18. joe sackey
    Sponsor
    May 23, 2006
    57,418
    Southern California
    Joe Sackey
    Understood, no worries, I routinely mention this anytime I observe an engine out of a Countach.
    Meanwhile Bravo for the hands-on approach.
    noppojp likes this.
  19. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Raymond,
    Are these the gaskets of choice when replacing cylinder heads on a Countach?
  20. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,018
    Switzerland
    Raymond S.
    Yes, Victor Reintz is a well reputated Producer, since Lambo belongs to Audi they changed from Sanguinelli to Victor Reintz, good decision ime.
    Spyder-Man and Jalpa_Mike like this.
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #21 sp1der, Dec 9, 2019
    Peter K. and Spyder-Man like this.
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #22 sp1der, Dec 10, 2019
    Peter K., S_AGATA and EarlyCat like this.
  23. Interesting view. I'm going to guess that the flange seal has been more than a few misdiagnosed rear main seal leaks.
  24. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Flywheel is bone dry, there is oil on 2 of the studs on the flange joint and a couple of the nuts are also less than what I would consider tight, the prop is also bone dry, the other thing that is of note is that the pilot bearing is shot - notchy and stiff
  25. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    has anyone got specs for the camshafts especially lift?
