Countach Fans. | FerrariChat
Countach Fans.
Discussion in 'LamborghiniChat.com' started by Anthony bentley, Sep 21, 2010.
  1. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    552
    London
    Anthony Bentley
    Im just trying to understand my 88.5 QV. (i have no hand book)
    My car has two fans one for each radiator, one comes on the other doesn't, is this correct? I have read some have a twin stage temperature sender ie one fan cuts in and the other cuts in if necessary.
    Also where are the fuses?
  2. johneli1
    johneli1 Formula Junior
    Feb 10, 2006
    714
    Hampshire, England
    Are you in London - I definitely want to see your car out and about! I'm up there most days!
  3. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Fuses and relays for the fans are in a box behind the LH panel in the trunk.
    Not sure about the 2 fan cars, but I know my '86 uses (4) fans. A "puller" fan on each radiator that come on when the water temps rises, and "pusher" fan on each radiator that kick on when the water temp really gets warm. Not sure of the exact temps when they come on and off.
  4. Anthony bentley
    May 20, 2006
    552
    London
    Anthony Bentley
    Are both fans on same fuse, i was reading your thread regarding the fans, hence i knew about the two stage set up.
    Yes the car will hopefully be out this weekend sitting in London traffic depending on my mood.
  5. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Both pushers are on 1 circuit and both pullers are on another circuit. The plastic box (used on the earlier QV's prior to 88.5) gets so hot that it warps out of shape!
    Each set of fans runs through a 25-amp fuse to a BOSCH relay. In fact, my relay had got so hot at one time it actually melted!!
    Like Raymond, I am going to redo my box back there, use better wire and connectors that have more surface area than these silly little things Lamborghini uses. No kidding, they have a 10 gauge wire running into a fuse block which is held in place with a set-screw on the connector that is no bigger than a pencil lead! No wonder so much heat builds up!
  6. paul328
    paul328 Formula Junior
    May 5, 2009
    764
    Scotland UK
    Paul Santoni
    Hi anthony
    As i aid in our convesation, both fans need to be on the same time as both do the same job and the radiators are just different sides of the same process. Get an electrician to check them out. The wiring on the countachs can be in various places. I got rid of the one 25amp relay and put two realys and fuses into mine due to consistent problems with fuses blowing
    Give me a call again if your stuck. These cars run very hot as the air cooling is poor and the engines big with lots of fluid in them!
    Paul
  7. alan
    alan Formula 3
    Apr 17, 2004
    1,502
    United Kingdom
    Alan
    Oops i thought this was a thread for Countach fans, being one of the worlds biggest Countach fans i tuned in, but i see its about fans not for fans.:)
  8. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    LOL! Yeah - this thread blows... ;)
  9. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,054
    Switzerland
    Raymond S.
    #9 raymondQV, Sep 21, 2010
    or sucks :) depends on the point of view...
    Trunk, left side in that ugly melted grey plastic box, in the pre 1988, yours should already have the metal box
    http://www.countach.ch/fusebox.html and http://www.countach.ch/MSD/index.html
  10. mattymouse33
    mattymouse33 F1 Rookie
    Oct 25, 2004
    4,632
    We'll set aboot ye!
    Matthew
    My Diablo was away for 5 months there, came back with a 'sticky relay' which meant the right rear fan didnt work. I noticed quite quickly as I use to get a huge blast of hot air standing behind the car whereas now it was just one side.
  11. 123quackers
    123quackers Formula Junior
    Sep 29, 2010
    299
    web land
    quack quack
    Don't know about 88.5 my 25th works right hand fan cuts in at 90 /92 degs and when sat in traffic on hot days only left fan will cut in around 95/ 96 degs. I did have an issue with said wires melting, the block connector easy corrected.
