Countach interior & electrical refresh | Page 2 | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Aug 29, 2017.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  2. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Very nice Simon. Were you able to find bushings to fit all the heim joints? Just curious how many of the heim joints utilize that Lemforder bushing? Where did you get them and how much are they? Seems like pressing in a new bushing is a more cost effective than buying an entire joint.
  3. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Get up to date,there is tons of replacements in todays age, Raymond got it covered
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    They are just Alfa bushes only fit the lower front wishbones, not expensive and easy to push into the housings.
  5. Just the lower front. None on the rear suspension. There is a noticeable diameter difference between them.
  6. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Oh OK, understand. Yeah, I knew about the Alfa bush for the front lower, its just in your photo it looked like that was a smaller heim joint and I thought maybe someone had found a bushing that would work in all of the rear suspension heim joints. :)
    Thanks again,
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    A few bits started arriving back this week, so have new harness from Autosparks, and some of the trim, gone for a slightly brighter shade of red for the re-trim. Will be getting the hubs back together this week-end and getting all of the parts ready for plating next week. Image Unavailable, Please Login Image Unavailable, Please Login
    S_AGATA likes this.
  9. Doc_K
    Doc_K Karting
    Oct 19, 2014
    218
    Honolulu, HI
    Ian K.
    That rosso leather is breathtaking!
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  11. S_AGATA
    S_AGATA Formula Junior
    Aug 24, 2016
    570
    Mill Valley CA
    Jon/Sean Sohaei
    Very cool. Love seeing the progress on this.
    Are you keeping the standard ride height?
  12. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    yes ride height will be set as close to standard as possible but have option to adjust as the spring perches are adjustable on the Koni shocks
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Image Unavailable, Please Login Temporary siberian conditions stopping much going on at the moment, however new Tarox front discs on the way and just working with Hispec Motorsport to get a bolt on front caliper kit sorted with Monster 300 calipers.
  14. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,087
    Rob
    Very cool Simon. Will the bolt on kit work with all varients of the model?
    R
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Should fit every car fitted with ATE brakes with 300x32 discs.
  16. Wow, nice work! Please list the part numbers or order info to the brake conversion for anyone else that might be contemplating a brake upgrade.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Will do, calipers on order and drawings for the adaptors should be in place next week. Guess mid to late Jan we should be good to go with a complete conversion, a complete kit will be in the order of about £750-800 to take standard front discs and will be a complete bolt on solution.
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  20. Doc_K
    Doc_K Karting
    Oct 19, 2014
    218
    Honolulu, HI
    Ian K.
    I'd love to hear how the new brakes work compared to the old ones, once you get every put back together!
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
  23. Countach88.5
    Countach88.5 Karting
    Jan 27, 2012
    66
    Solihull, UK
    spider, which koni shocks are you using? my rears are failing, and I refuse to pay 2017 prices for 1960's tech.....
  24. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Will be using the koni sport ones from a Diablo, they are about £350 each, but are adjustable in rebound
  25. Countach88.5
    Jan 27, 2012
    66
    Solihull, UK
    cheers, are you using the same springs?
    I have changed my front suspension to koni #### with adjustable bump/rebound* and spring seats, but the firm I was dealing with pulled a disappearing trick before we got the rears sorted.
    *from memory I think we hit the far end of the adjustment range and I was told they would need to be revalved.
