Countach Rear Wheel Bearing: parts and help | FerrariChat
Discussion in 'LamborghiniChat.com' started by Anderson, Aug 18, 2012.
  1. Anderson
    Anderson Karting
    Nov 6, 2004
    51
    Colorado
    David Anderson
    The right rear wheel bearing on my 1979 LP400S S1 Countach is going bad and I am seeking help on obtaining the necessary parts and tips on replacement.
    PARTS:
    In reviewing my parts catalog I believe I need the following parts:
    8503507 (1)
    8524502 (1)
    8516003 (2)
    8614506 (2)
    5109529 (10)
    What else?
    Where can I buy these parts at a reasonable price?
    TOOL:
    I need a tool for the nut, part # 8252803. Where can I get this item?
    HELP:
    My shocks are fine but the bushings (probably part #5109529?) are shot and rattle
    when going over bumps. Can these bushings be pressed into my existing shocks?
    Why would I need 10 of 5109529??
    What other issues should I be aware of when replacing the two wheel rear bearings? If you offer suggestions, please make them simple!
    THANK YOU,
    David Anderson
    Colorado
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    PM sent.
  3. Albert-LP
    Albert-LP F1 Veteran
    8,169
    around Modena, Italy
    Alberto Mantovani
    #3 Albert-LP, Aug 19, 2012
    I know that many attempts were done to find a cheap replacement for these ball joints, but at the end i bought them at the factory spare part service: you can find the straight balljoints, but the angled ones are unfindable and i know of some very bad ending attempts.
    Be careful.
    ciao
  4. Peter K.
    Peter K. F1 Rookie
    4,448
    Connecticut
    Peter K.
    Wil Degroot replaced my wheel bearings. Was not a problem locating (that's when you are able to give exact sizing).
    Chad Bolles has both a ring nut socket and a ring nut wrench available.
  5. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    David, IF you have a LP400S, then you have looked up the WRONG part numbers for what you need. The LP400S rear suspension is different from the LP400 car.
    Like I said email me and I will give you the correct numbers.
    Chadbourn Bolles
    803 532 6257
    803 798 3044 cell
    Lamborghinionly my address at yahoo.com
