Countach side mirrors | FerrariChat
Discussion in 'LamborghiniChat.com' started by charles robertson, Nov 4, 2019.
  1. charles robertson
    charles robertson Karting
    Mar 27, 2019
    122
    charles robertson
    Are anyone else’s floppy or is it just mine lol.
    im continually adjusting them and re adjusting them. Is there a way to tighten them?
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Yes, pull back the rubber boot, set the angle to the desired level, tighten the bolt, and replace the rubber boot.
  3. charles robertson
    Mar 27, 2019
    122
    charles robertson
    Thanks Joe much appreciated.
    joe sackey likes this.
  4. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Charles,
    One other thing to check, the setscrew sometimes works loose and allows the mirror to wobble around. Once you loosen this enough, you can remove the entire mirror from the door. Check that the base is screwed tightly to the door. These screws can also work their way loose. And, as Joe stated you can pull the rubber boot back to adjust the angle of the mirror which sometimes works loose as well.
  5. charles robertson
    Mar 27, 2019
    122
    charles robertson
    Thank you Mike, I’ll check all...much appreciated
  6. volkster999
    volkster999 Karting
    Sep 22, 2005
    86
    CT
    Neil Volkmar
    Great thread, I have the same issue on the passenger side. Been working up the nerve to try pulling back the boot without ripping it.
    Thank you to all!
    Neil
  7. charles robertson
    Mar 27, 2019
    122
    charles robertson
    Neil it’s super simple, the boot would be difficult to tear.
