Countach spark plug wrench | FerrariChat
Discussion in 'LamborghiniChat.com' started by blown daytona, Apr 27, 2012.
  1. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    #1 blown daytona, Apr 27, 2012
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I think you will find it is the same part (or very very similar) as that used on Ferrari's of the same vintage. Certainly the one in this toolkit is from a 308.
  3. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,832
    Dallas Texas
    If you know you know
    What actual size is the hex?
    I may have a lead for you
    Feel free to PM me
    S
  4. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Sure does. I googled some 308 tool kits. It doesnt look like all have them. They seem to have varying styles
  5. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Mine is 18mm spark plug hex and 14mm on the side that goes into the handle PM sent Thanks!!!
  6. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Ferrari one is 14mm across the hex, the early 308's had a T bar spark plug tool. The later tool is the one shown in the picture.
  7. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Is that 14mm on both sides of the tool?
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    No just 14mm across the hex (cannot rember the plug size), in the ferrari toolkit one of the spanners is a 14mm ring spanner to use the tool. To be honest looks good to have in the toolkit but in real terms better off with a T bar plug spanner.
  9. blown daytona
    Feb 6, 2008
    1,679
    maryland
    If the 308 takes a 18mm hex spark plug, then that gives me more options. It does look like the same one. The tool is only for my tool kit completion. As all the other tools in the kit, they are the worst tools I have ever seen in my life!!!! Looks like they went to the dumpster in the local flea market to find them.
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Ha ha, will check the part in my 308 and give you the exact dims. Yes the tools and the bag for the Countach are certainley not of the highest quality! I am just after the bulb holder and correct pliers to make my kit whole.
  11. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #11 sp1der, May 2, 2012
  12. Albert-LP
    Albert-LP F1 Veteran
    8,175
    around Modena, Italy
    Alberto Mantovani
    #12 Albert-LP, May 2, 2012
    Thanks, sp1der: I hope to help you next time as a thanksgiving.
  13. blown daytona
    Feb 6, 2008
    1,679
    maryland
    It appears the 14mm section is slightly shorter on the 308 tool. I would take one anyway if anyone knows where I could buy one. It is close enough....not like I am going to use it
  14. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Mine is also missing. Must be a stack of them someplace! LOL!!!
    Did you get your new alternator yet? Curious how it looks compared to the old one. I'll pick one up too, if you are satisfied with yours.
  15. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Pulled the old one out last night, hope to install new one tonight. I will let you know. I am crossing my fingers. This is the last issue with the car that I am uncomfortable with.
  16. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Do all the mounting holes appear to line up? Same size as the old unit? I take it you'll have to remove the fan and belt cog to put on the new unit?
  17. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Just got done. Fits perfect, just change over the pulley, but........the unit only puts out 65a @ idle and 95 @ 3k RPM. I called them and he thinks they sent a stock replacement unit. They said he has to build one up and test to insure proper outut. He will at least refund the shipping. It will probably be another week or so before I have results :( On a positive note it does perform slightly better than the unit I took off.
  18. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Good grief..... A never ending battle. Sorry to hear about the delay!!! This was supposed to be a 200 amp unit?
