Countach Technical Thread & Questions | Page 11 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Thanks guys,off it goes
  2. jwiner2
    jwiner2 Karting
    Jan 1, 2012
    61
    Hamburg, NY
  3. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Poor quality pic, but it looks like a side dash vent for a later QV car, which the 5000S did not have
  4. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Ask seller what the Lambo part number is.
    But best is probably to totally stay away from this guy.
    He normally does not state the Lamborghini part numbers, to make cross checking and price checking difficult.
    He even came on here and sold none original poor quality Countach suspension parts to board members without standing up and reimbursing the buyers. Check the old threads.
    He is a total fraud in my opinion.
    I ordered and paid him for a Lamborghini manual, never got my manual nor my money back.
    He is a member here but is using various nick names to avoid getting attention to his fraudulent business.
  5. jwiner2
    jwiner2 Karting
    Jan 1, 2012
    61
    Hamburg, NY
    Ok. Thanks for the information I will keep looking.
  6. GraemeS
    GraemeS Karting
    Jun 6, 2005
    166
    Auckland New Zealand
    Graeme Stebbing
    Hi have a look at these on ebay uk number
    371195938907
  7. jwiner2
    jwiner2 Karting
    Jan 1, 2012
    61
    Hamburg, NY
    Thanks Graeme that's what I am looking for.
  8. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Thanks for posting the part numbers from GT Car Parts.
    It might become handy for someone!
  9. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Need a distributor cap for a Quattrovalvole.
    - How was it with this less expensive Jag cap again?
    - Is it a direct bolt on replacement for the Marelli cap?
    - Who here have actually tried it?
  10. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,059
    Switzerland
    Raymond S.
    Try OKP Parts from Munich, I have mine from them.
  11. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Thanks for the lead Raymond.
  12. islandguy
    islandguy Formula 3
    1,439
    Northern CA & NV
    What’s your thoughts on powder coating springs and other suspension parts? I realized it’s little $ but is it really worth the extra effort?
  13. Doc_K
    Doc_K Karting
    Oct 19, 2014
    224
    Honolulu, HI
    Ian K.
    Hey guys, I had a question about restoring old cars, like the Countach. I see engines that have been rebuilt, like the car in this auction,
    Lamborghini Countach LP500S | eBay
    and I'm wondering how the owners were able to make the finish look like new? Are they coated with enamel, or powder coated, or have they been treated with some other method? Thanks!
    Ian
  14. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    800
    #264 Downdraft1, Mar 22, 2015
    sorry double post
  15. Downdraft1
    Nov 13, 2008
    800
    Painted, the oil and smog migrate into the aluminum and no matter how you try to clean the block, heads and intake manifolds remain stained - especially the downdraft intakes from the fuel fumes - however the final result is spectacular and in most cases remains pristine looking.
  16. Downdraft1
    Nov 13, 2008
    800
    #266 Downdraft1, Mar 22, 2015
  17. Doc_K
    Doc_K Karting
    Oct 19, 2014
    224
    Honolulu, HI
    Ian K.
    That's beautiful! Thanks for sharing!
    Ian
  18. gurslo
    gurslo Formula 3
    Feb 25, 2008
    1,524
    Connecticut
    Peter
    Nice job, it looks fantastic.
    Don't forget your radiator reservoir cap.
  19. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Looks very nice. Great job there.
  20. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    #270 jollygood, Apr 9, 2015
    I am about to replace my distributor cap.
    But before putting a new cap on I need to know why it became faulty and why the arching occurred inside the old cap.
    I am running MSD with a Blaster SS 8207 Coil.
    Could it be that this coil is actually to strong for this configuration?
    Way back this was a coil that was recommended for this setup.
    Any thoughts?
  21. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    #271 jollygood, Apr 9, 2015
  22. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    I have only had this happen once. The issue started about the time I cleaned the engine. It was a horizontal distributor just like the Countach. Looking at the cap it appeared there was water in the cap along the bottom side after washing it. It appeared that the water acted as a conductor initially but as it dried the arcing formed a carbon trail which continued to cause the arcing after the water was gone. Grinding the carbon trail off made a good temporary fix. In general I try to keep the inside of the cap clean and dry but I do not do anything special ie I only check it when I have the cap off for another reason. Also note this was only one occurrence. I have gotten the distributors wet on many occasions without this issue although those were typically vertical installations.
    Cheers Jim
  23. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    #273 jollygood, Apr 10, 2015
    Thanks for replying and your contribution to the subject.
    I am attaching a pic of inside of cap. Comments appreciated.
  24. Redlambo
    Redlambo Formula 3
    2,413
    Pendergrass GA
    Vic Woloschinow
    It appears almost as if your distributor is out 180 degrees.
    I don't know if that is possible, however if you look at the arcing its as if the lower part of the rotor button is firing on the higher part of the distributor cap and vice a versa.
    Maybe Tim K will chime in and verify if this scenario is even possible.
  25. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    There are two pickup points or very early type magnetic triggers and you should use lower one.
    Other posibility is if you got multispark ignition and it is not timed correct (I know it is little challenging to set with Countach) you could get similar results.
    Third posibility is that your mechanical advance system inside distributor is stuck to other end and spark is arcing to neares point or so. Do try sligthly twist ignition pointer side to side, there should be few cm play so that you feel that retain spring, DO NOT FORCE IT, those ignition pointers are really expensive. (I have made instructions to dismatle Countach /512BB distributos to L-talk forum)
