Countach Technical Thread & Questions | Page 15 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,814
    Bologna
    I live in a hot climate and have run Evans in my BB, LP400S, and TR for years with zero issues and zero corrosion (no water in the system). And you don’t need to swap it out every 2 years to renew the corrosion inhibitors.
    EarlyCat likes this.
  2. Tet
    Tet Rookie
    Aug 24, 2019
    13
    Tetsuji Watanabe
    Cam specs In Opens TDC 45, closes BDC 75
    EX Opens BDC 75, closes TDC 45
    it mean BTDC 45' ABDC 75' ?
    and Is it same 1985 QV?
  3. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    You are correct about the BTDC and ABDC. The owners manual should have the cam specs in it, I know the 5000S does. You do not mention which QV. The downdraft and the fi have different cams.
    Cheers Jim
  4. Tet
    Tet Rookie
    Aug 24, 2019
    13
    Tetsuji Watanabe
    Thank you.
    but I dont have owners manual.
  5. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,350
    USA/France
    I need some brake fluid asap. What are you guys using in your Countach these days in your original Gerlin?
    In the past my techs used Castrol LMA, Motul. Th eLAM is supposed to be gentle on the master cylinder, less corrosive.
    I suppose I need DOT3 right ? then moisture absorbant or not?
    I also need fluid I can find easliy locally not in some mail order specialty shops.
  6. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I replaced the master cylinder with an aluminium BMW 7 series part to avoid these corrosion issues which will ultimately happen with the cast iron part. Its literally plug and play with some very small tweaks to the brake pipes.
  7. Countachqv
    Apr 25, 2007
    2,350
    USA/France
    Did that too but what I need to know is what fluid do people use for the ole girling. I lost mine. a rear leak developed over winter storage and lost it there.
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I am just using standard Halfords dot4 without testing hard to understand the exact nature of the fluid compositions e.g lubricity, potential seal swell etc. If the car leaked over winter likely a relaxation of a mechanical joint somewhere, not sure a change of fluid will help as all brake fluid except synthetic will absorb fluid.
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Sorry should have made clear in last post that all fluids will absorb moisture.
  10. I use Castrol dot 3 or 4.
  11. dinonz308
    dinonz308 Formula Junior
    Nov 26, 2017
    867
    Dean
    What tool do you use to remove the screws holding the shift gate in?
    Also - what should be holding in the bull emblem at the back? Feels like mine has modelers clay.
  12. Countachqv
    Apr 25, 2007
    2,350
    USA/France
    Rear Brakes countach QV
    Here is what my search found for a countach 85 rear caliber/pads: Caliper are Front & Rear: BMW 735 (E23) 79-82
    I want to mate them with:
    DP3104C EBC Redstuff Ceramic Low Dust Brake Pads; Rear
    DP3753/2C EBC Redstuff Ceramic Low Dust Brake Pads; Front
    since the rear countach caliper are actually the front BMW caliper , I am not sure if the correct pads are the rear pads or the front pads (which I think would be the correct one)
    The calipers can be had at autozone at decent price but they have 2 sets 46/47 or 48/49. Not sure what is different, other than some pads' hardware. If they come silver, not gold they can be plated.
    https://www.autozone.com/brakes-and-traction-control/brake-caliper-front/bmw/733i
    Can anyone bless this?
  13. MiuraP400
    Feb 3, 2008
    949
    Arizona
    Jim
    Looking at the photos the 46/47 calipers have a web between the flanges that bolt the caliper to the axial the other ones do not. I would look at your old ones to match them up.
    Cheers Jim
  14. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    800
    i shaped a piece of wood with a rounded seat with three metal studs protruding, worked great and did not scratch the screw heads
    Behind the rug you should find a series of 5mm brass nuts and washers that secure the bull and scripts. The bull should not be able to shift if you try to move it
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will dig out my old calipers and take a look over the week-end, I think I still have the pads, I had redstuff on my car with the original calipers and found the pads tended to loose small chunks out of them.
  16. dinonz308
    Nov 26, 2017
    867
    Dean
    I pulled mine out, and the badge itself has no threads on the posts at the back at all, and doesn't look like they have been stripped. Checking Eurospares, and it seems they're supposed to have a nylon seal they push in to - those seals are definitely missing from my car.
  17. dinonz308
    Nov 26, 2017
    867
    Dean
    Is anyone aware of websites with "how to's" for Countachs? For my Ferrari 328 there's many sites with how to intructions to do various jobs, but I seem to draw a blank on Countach help. Things like removing the instrument panel, getting to the front auxiliary lights (mine seems to have had water pool and dry behind the front glass), replacing the headlight bulbs etc
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Short answer is no, for headlight bulb handbook shows you how. For side lights there are 2 little spring clips you have to unhook to get the sidelight/indicator unit out. Then you can clean inside. To be honest to do this it is easier taking the front bonnet off to get easy access. Instrument panel 4 Allen bolts you can see, drop column down to lowest position and put tape in dash binacle to stop leather getting scratched as you remove, there should be enough cable slack plus Speedo cable slack to allow you to pull out.
    dinonz308 likes this.
  19. dinonz308
    Nov 26, 2017
    867
    Dean
    Thanks Simon - appreciate that!
  20. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will get some pictures of how to do just got to find them.
  21. Anyone know a cross reference for a front turn signal housing?
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Are you talking about the actual light unit behind the lens? If so they are the same as a Ferrari 308
  23. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,059
    Switzerland
    Raymond S.
    And Jalpa, and...
  24. Lel
    Lel Formula Junior
    Oct 11, 2007
    295
    All outside light units for the Countach were taken from the standard four door Alfa Romeo Alfetta. Therefore the odd looking serial rear lights compared to the Countach prototipo.'
    L-E
  25. Yes. The housing that holds the light bulbs.
    Mine has a crack, fixable, but if a replacement is reasonable - why not.
