Countach Technical Thread & Questions | Page 8 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Jay:
    Flatbed is the only way to go.
    When I had mine towed 3 years ago to have its new clutch installed, it was flatbedded. No issues at all. Arrived at the shop in perfect condition.
  2. jgoodman
    jgoodman F1 Rookie
    3,259
    Central PA
    Jay Goodman
    #177 jgoodman, Sep 14, 2014
    Be more specific please. Like exactly how did they get the car on the flatbed? Where was the tow hitch attached? Is there a tow bar?
  3. #178 EarlyCat, Sep 14, 2014
    Also called a rollback truck
  4. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Yep, that is exactly what they used for mine.
  5. gurslo
    gurslo Formula 3
    Feb 25, 2008
    1,524
    Connecticut
    Peter
    Mike did they need to use boards or planks of wood to make the transition onto the truck? Looks steep.
  6. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Nope, no ramps needed. In fact, the bed actually lowers down further than the photo shows, which makes the incline even less severe.
  7. jgoodman
    jgoodman F1 Rookie
    3,259
    Central PA
    Jay Goodman
    Where did they attach the tow rope to the car? And how do you do that without ripping off the front valence?
  8. TSS
    TSS Karting
    Jul 2, 2004
    71
    #183 TSS, Sep 15, 2014
    I’ve been towed twice; many years ago when a bearing gave out in the gearbox and more recently when the ignition coil failed.
    The Countach has 2 tow hooks underneath at the front (well mine does anyway, maybe earlier cars don’t?) They are quite far back so you have to get your head right on the ground to see them.
    Both time we had no problems. The recovery company sent a truck where the back comes right off so the incline is very slight and the recovery guy just attached his tow cable to one of the hooks. We put a big foam pad between the cable and the underside of the front spoiler, most recovery trucks carry foam pads for this purpose. Then just very slowly winch the car on.
  9. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Same story here , had mine flatbeded across the state for clutch and misc fun stuff, the driver had 2 wooden boards he put under the front wheels ,easy as 1 2 3
    Same thing when it was delivered back to me. No worry be happy :)
  10. islandguy
    islandguy Formula 3
    1,439
    Northern CA & NV
    #185 islandguy, Sep 15, 2014
  11. amc
    amc Formula Junior
    253
    old school
    How many radiators are in the front area and what are they for?
  12. 12097
    12097 Formula Junior
    Apr 4, 2007
    685
    Regina, Canada
    There is one air conditioning condensor with 2 small fans ("radiators" for the air conditioning)
    in the front of the car. It is located just in front of the left side wheel well.
    The 2 engine radiators and engine oil cooler are located mid ship just behind the passenger compartment.
  13. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    Unless you have a LP400 or LP400S or 5000S, then the oil cooler is mounted in the right front inner fender. Also the heater core is mounted there.
    Chadbourn Bolles
    803 532 6257
    email: [email protected]
  14. 12097
    Apr 4, 2007
    685
    Regina, Canada
    I stand corrected Chad.
    Thanks for the information.
  15. amc
    amc Formula Junior
    253
    old school
    #190 amc, Sep 24, 2014
    So the heater core is mounted front right fender on LP400 and...?
    and AC condenser left front fender?
    U mean there's water hoses from back to front for the heater?
    Oil cooler in the back parallel to one of the water radiators?
    This heater inlet, looks like it is split in two...
  16. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Qv have oil cooler in the airscoop driver side (mounted in front of driverside radiator.
    And your ac lines run all the way from the compressor in he back of the engine (really front being that the engine is backwards) thru the driverside doorsills in to front compartement and conects to condenser / fan etc ,
  17. amc
    amc Formula Junior
    253
    old school
    and the rest?
    LP400 heater and oil cooler were are they specifically?
  18. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Oil cooler is in the RH front AFAIK.
    But I have been wrong before.
  19. Chadbourn Bolles
    820
    Leesville, SC USA
    Chadbourn Bolles
    Oil cooler and heater core mounted in right front fender. Also blower for heater is located there, REAL fun to get to, if you need to.
    Chadbourn Bolles
    803 532 6257
  20. amc
    amc Formula Junior
    253
    old school
    Why is the clutch pedal heavy if it is operated hydraulically?
    and
    Between LP400 and Anniversary is there any improvement in this department?
  21. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    ive seen flat beds that lift the whole bed-off to ground level,and some that lift all 4 wheels up and just pick up the whole car onto the flat bed
  22. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Back in 06 when i bought my Countach, i ended up getting a Factory Lamborghini uppgraded ignition box , dont have much info but acc to my guy at the dealer it was supplied as a replacement/uppgrade for faulty Countach ign boxes.Factory Lamborghini,
    Its a cast aluminum casing screwed to an aluminum plate, one single box as opposed to the original 2 piece magneti Marelli.also only halv the size. Never installed it in the car,being that my original boxes so far has worked just fine , but this system is very simple and clean looking , just vondered if any of you guys have any experience with the system ,
  23. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,096
    Rob
    Got any pictures / part numbers please?
    Rob
  24. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Part nmbr 001631621 cast alu Bull on the front with the nmbr 31621 casted in to the casing wil try to post a picture tomorrow , if my 10 year old will help me.
  25. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
