Countach Technical Thread & Questions | Page 9 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Yes, thanks. Thats it. I did install it once in the car ,easy plugg in and bracket fits good but the car did not shut off when you turned off the key,i later recieved diode from my dealer wich is supose to avoid the alternator to backfeed to the ignition box after the key is turned off,i did not find a plug anywhere to fit the connections the diode kit came with.car sounded good but kinda hard to pull the coil wire every time you shut the car down, do you know if the system is any better than the original? And also where do you conn the diod the easyest to make the car turn off on the key?or is there perhaps another reason the car does not shut off. Very thankful for all help,would like to install the new box if it is in fact any better,my existing ignition works fine so far,but stil would like to try the new one.
  2. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #202 Jalpa_Mike, Oct 8, 2014
    Nils,
    Lamborghini addressed this "run on" problem in Technical bulletin #004 back on June 24th 1988.
    Here is a copy of the 2 pages:
  3. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Thanks !i did recieve the same two pages from Lamborghine with my diod kit, have not being able to find the connectors in the wire harness anywhere, there is only the big red pos cble coming inn from the alternator to a common terminal,from there it feeds in to a relay box in the left side rear compartmnt in the taillight section. The box contains fan and ignition nd start relay, perhaps Lamborgini expects you to find suitable place for the diod where there is acces to the right wire,but there is no plug anywhere to be found that connects to the plug /diod kit. Did the Canadien guy run in to the same problem?
  4. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    Next time you get ready to run car, try this. Disconnect the switch wire at the Alt. Start car, then shut it off. If it shuts off, then place the Diode in that wire.
    Chadbourn Bolles
    803 532 6257
    email: [email protected]
  5. Peter K.
    Peter K. F1 Rookie
    4,441
    Connecticut
    Peter K.
    #205 Peter K., Oct 9, 2014
    I don't remember posting this picture of my car. Where did you see it?
  6. amc
    amc Formula Junior
    253
    old school
    Countach thread... or some restoration thread in this forum.
  7. johnghini
    johnghini Karting
    100
    #207 johnghini, Oct 21, 2014
    Can anyone confirm whether the areas I highlighted have the black sealant in their seams? In short, I cannot tell whether the horizontal "rocker panel" seam that runs into both the front and rear flares should have the sealant. Seems some cars have it the complete distance, while others have it on the flares only...or none at all. I am finishing up the car and need to know! Car I am referring to is a US QV (1986).
    Thx!
  8. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    #208 godabitibi, Oct 21, 2014
  9. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,857
    The Cold North
    Tom
    I know that car..
  10. jgoodman
    jgoodman F1 Rookie
    3,259
    Central PA
    Jay Goodman
    Anyone have the part number for the windshield washer fluid reservior? Any part cross links for other cars? Just noticed that mine won't hold fluid. Thanks in advance.
  11. gurslo
    gurslo Formula 3
    Feb 25, 2008
    1,524
    Connecticut
    Peter
    Would a "3D printer" work it's magic for a project of this sort?
  12. Get the part number actually on it & Google it. It is probably a Fiat or Alfa part.
  13. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
  14. jgoodman
    jgoodman F1 Rookie
    3,259
    Central PA
    Jay Goodman
  15. SupercarGuru
    SupercarGuru F1 Rookie
    Sponsor
    Dec 14, 2003
    3,744
    Fl
    John Temerian
    I cannot find the owners manual on my 1987 car... And cannot find where to check the oil?? I know this sounds absurd... Am I blind??
  16. Redlambo
    Redlambo Formula 3
    2,413
    Pendergrass GA
    Vic Woloschinow
    #216 Redlambo, Oct 23, 2014
    This should help.
  17. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Even when you know where to look, sometimes it's a mystery.
  18. Chadbourn Bolles
    820
    Leesville, SC USA
    Chadbourn Bolles
    #218 Chadbourn Bolles, Oct 27, 2014
  19. Peter K.
    Peter K. F1 Rookie
    4,441
    Connecticut
    Peter K.
  20. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,051
    Switzerland
    Raymond S.
    #1121228, of my friend, Vortex charger
  21. Amazing work!
  22. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #222 Jalpa_Mike, Nov 15, 2014
    Rebuilding the water pump on my 5000QV.
    Here are all the old components laid out. Just ordered new seal, bearing, hoses, snap clips, etc. from GT Car Parts.
    Also having the water pump cover re-welded. At some point in the cars history, someone must have broken the cover and welded it (note all the red silicone gasket sealer on it). So, I took it to a proper machine shop (the same folks who have done Jon Shirley's Pebble Beach winning Ferrari 375MM). They'll weld a new flange on it and machine it properly.
  23. islandguy
    islandguy Formula 3
    1,439
    Northern CA & NV
    Looks good Mike. Was it giving you trouble or just on your list of things to do?
  24. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Yes, it started leaking.
  25. I will be rebuilding mine soon. I've already rebuilt mine twice over 8 plus years. One catch is the seal must be pushed on, evenly, or it will leak immediately. The perfect "tool" to press the seal, is the plastic top of a bug bomb like you would get at Home Depot. Did you get the packing slip with the parts? A Ferrari seal.
