Countach, the ultimate supercar | Page 112 | FerrariChat
Discussion in 'LamborghiniChat.com' started by joe sackey, Aug 21, 2007.
  1. J Ingram
    J Ingram Formula Junior
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    #2776 J Ingram, Mar 25, 2009
  2. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    #2777 J Ingram, Mar 25, 2009
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2778 2NA, Mar 25, 2009
    I'm not sure what you are referring to regarding "rust and crappy workmanship". The hidden areas of a 24 year old handmade Italian car don't look too unusual to me.
  4. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    #2779 J Ingram, Mar 25, 2009
    Notice the rust in the originals. The fabricated ones are gonna look nice especially when the lights come in from Italy.
  5. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    Perhaps my comments are a tad harsh. But, per my mechanic's report, the heavy American bumper was put in place by someone who did not do so according to factory specs. The bumper was drilled into the rear body through where the tail lights are supposed to be and held on by huge bolts. You can see one of the holes in the lower inside corner in the pic showing the rear taillight opening close up. I don't have pics of when they took it all off so I cant show you. The plastic tail light lenses are supposed to be clear with square holes to let the red square lights fit through and cover the red textured looking material underneath. But these were some fabricated black plastic pieces that were not stock. The American bumper is supposed to be removed and the tail lights should be complete as on the Euro versions. I'm not sure who did the conversion, but the whole tail assembly was not factory spec.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks like you're doing a great job restoring it to "better than new". :D
  7. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #2782 raymondQV, Mar 25, 2009
  8. alan
    alan Formula 3
    Apr 17, 2004
    1,502
    United Kingdom
    Alan
  9. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    800
    Raymond is correct, those parts are in aluminum and not in material that can rust. Actually the only rust that you can find around the back end of the car is the screws treading of the tail lights, frame, shocks or exhaust. While you are at it check the grounds to your rear lights, a bad ground can cause poor functioning of the flashers, signal lights and brake lights.
    Also check for small cracks in the corners of the rear fender around the lights. The factory used a lead base sealant (stagno is the Italian word).
    Actually the build of the Countach was well done, I took apart my lights and replaced some threading that had rusted around the nut. I replaced them with machined threading in stainless steel. Remember these cars are 25 years old +. it is more than likely that someone stateside messed it up, or the car had rear accident damage.
    Alex
  10. Is the old taillight panel made of metal something done after the car left the factory? If you take off the US panel, it should be a aluminum panel correct? To change it to the euro look you would only need the reflector parts?
  11. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    That aluminium piece is under the red plexi and is structured, that's the effect of the brezel, it's a standard aluminium plate you can buy at every metal shop.
    How the american variant was done I don't know since we don't have them here.
  12. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    #2787 J Ingram, Mar 27, 2009
    You and Raymond are correct. Bobileff showed me how it was supposed to look. It's true that if you remove the American rear bumper, the complete Euro light cluster should be intact. That's what we were anticipating when I decided to convert to the much better looking Euro version. We were surprised by what we found underneath. It went from a simple job and turned into a complete back end repair job complete with fabrication of the aluminum pieces. The thought was that someone messed up stateside as the rest of the car is as it should be. It has the correct, complete fuel injection system and emissions stuff intact. The entire red plexiglass cover and the textured material is on order and should be here soon. I was at his shop yesterday and everything is done except for the placement of the red light surround pieces. I'll post pics again soon. Thanks for the input!
  13. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    Awesome exhausts Emilio! Do you have any leads on an Anza exhaust for a '78 308 GTS, USA version with the two cats setup?
  14. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    you have PM
  15. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    Did you see those:
    http://cgi.ebay.com/Lamborghini-Countach-Rear-Metal-Light-Frame-LH-74-89-MY_W0QQitemZ140308800736QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item140308800736
    http://cgi.ebay.com/Lamborghini-Countach-Rear-Metal-Light-Frame-RH-74-89-MY_W0QQitemZ140308800755QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item140308800755
    http://cgi.ebay.com/Lamborghini-Countach-Rear-Perspex-Light-Frame-LH-74-89_W0QQitemZ380111785759QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item380111785759
    http://cgi.ebay.com/Lamborghini-Countach-Rear-Perspex-Light-Frame-RH-74-89_W0QQitemZ140308800782QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item140308800782
  16. archivist
    archivist Rookie
    Nov 14, 2006
    30
    Windsor, Colorado
    s.a.m.
    #2791 archivist, Apr 1, 2009
  17. archivist
    archivist Rookie
    Nov 14, 2006
    30
    Windsor, Colorado
    s.a.m.
    #2792 archivist, Apr 1, 2009
    This is a pic from the same SUPERAUTO Illustrated article on the Turbo Countach. The article states that this is from L & L International in Wilmington, NC back in the mid 80's, I guess they were an importer for Lamborghini. Cool pic I thought.
    Murph
  18. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    from the color i guess it is a Max Bobnar car...
  19. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    #2794 EMILIO, Apr 1, 2009
  20. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #2795 raymondQV, Apr 1, 2009
  21. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
  22. sumlin
    sumlin Karting
    Jan 12, 2009
    238
    #2797 sumlin, Apr 3, 2009
  23. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    SOOOOOOO NICE!!!!
    Thank you for the shots.
  24. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Looks familiar! Note the 5 rain-gutter slots on each side of the trailing edge of the roof. You wont see hat on any other LP400S S1 with a flat roof...
