Countach, the ultimate supercar | Page 159 | FerrariChat
Discussion in 'LamborghiniChat.com' started by joe sackey, Aug 21, 2007.
  1. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Yes, it is true! I have full documentation of the following, performed with cars it tip-top running condition:
    I have achieved 188.4 mph which is 303.2 kph in a 1975 LP400. However, the tach was at 8000 rpm (assuming the tach is 100% accurate), so that was it without risking damaging something.
    BTW, the top speed I achieved in a '88 1/2 Euro DD was 182.4 mph. It was hitting the rev limiter, but might have had a little more without the rev limiter.
    So, the top speed of a LP400 is greater than the next fastest Countach, the DD. The reason is because of the lower rev limitation of the DD. The DD was quite a bit faster up to around 125mph, but then it started slowing, where the LP400 was slower to that speed, but kept on pulling better beyond that speed than the DD did. I contribute that difference to the more streamlined shape of the LP400.
  2. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    #3952 vaholtorf, Oct 19, 2009
    Some cool pics of these two cars........
  3. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #3953 raymondQV, Oct 19, 2009
    Not only the QV, also the LP5000s in Switzerland and hot countries in Arabia. Swiss cars have 3 fans, arabian even 4.
    Hmm, rev limit of the MM ignition box used on the QV and 25th is at 7800rpm, LP5000s had the same box but no rev limiter.
    For sure the tacho and speedo are not accurate, since the LP400 was told to run 315kmh which is exactly the gear ratio at 8000rpm... The fastest offical measured countach was the 88,5 of Pier-Luigi Martini reaching 312kmh which reflects 7800rpm. Since Lamborghini was known to have special engines for special clients (like Formula One drivers) that engine must have had around 500hp. German magazine Auto Motor & Sport tested the QV 1986 at 298kmh at 7400rpm.
    The 25th has a slightly shorter gear ration which is the reason why it accelerates as good as a QV although it weights 100Kg more (of course the new model couldn't be slower on 0-60mph than the QV...)
    Correct, and looking at your pictures it's obvious that with that protection you improved the drag coefficient at the front significantly which explains the excellent top speeds.
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Well stated.
  5. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Hi Raymond. As you can see in the pic, the LP400 had smaller tires....Hoosier 245/60/ZR14 instead of the taller Michelin XWX...just because the shorter Hoosier tires were the only Z rated tires I could find. They are shorter and wider than stock. That is why my top speed was lower at 8K rpm. I know the gauges aren't accurate but we measured electronically. On the DD, I was using a Burtoni (MSD) ignition with a lower rev limit of 7250 rpm. I don't know why, but that is how Al Burtoni set it up. The gauges aren't accurate...I know! See, in the pic of the DD gauges, the tach was only reading 6900 rpm but was really 7250 rpm! There the speed was 182.4 and I could feel the rev limiter cutting out the ignition....
  6. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #3956 raymondQV, Oct 20, 2009
    As expert for MSD ignitions I can tell you that Burtoni used a standard MSD 7 AL-2, they simply plugged in a standard MSD rev module with removed sticker.
    If you want to have a higher rev limit, buy a set of 11'000 rev limiter plugs and calculate 11'000/12 * 8 = 7333rpm, the same set contains also a 11'800 plug = 7866rpm.
    I asked MSD years ago, they never changed the tacho/rev limiter circuit on a single box from V8 to V12 for Burtoni, I opened one of these mighty V12 Enginnering boxes and it was plain stock, since MSD seals the entire unit with epoxy!
    http://www.countach.ch/MSD.html
  7. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    #3957 hyenahf, Oct 20, 2009
    joe
    if wallace told you he say 300km electrically time i wouldnt doubt it. now was that a stock LP400? he would also tell you today the highest spec production 4 liter motor (that isnt a costumer special) had not much more than 300hp real world crank horsepower and not anywhere close to reputed specs 375 of the LP400.
    one can deduce a top speed of a vehicle relatively easily. lets say 300-320hp in a car with relatively poor Cd A and a coefficient of drag of near .40 (A LP400S/LP500/DD with flares no wing is said to have a Cd.42) how much power would you think a car would need with Cd of.40 to come near the 300kph with exponential factor of 4? even if it had the claimed 375hp it wouldnt even be close.
    For comparison sake, a modern F360 with 400-425hp and respectable Cd of .34 does (factory claimed) 295kph. the numbers required to get a LP400 magical 300kph is just a bridge too far.
    now whatever the speedo of the SW or Jeager gauges reads isnt most likely what the car is really doing. nearly all the vintage italian cars speedo are optimistic in my limited experience . old school tachs arent that reliable either.
    i once had a rental 140hp ford mondeo speedo up to 148mph going down hill with a strong backwind on the motorway in europe. should i claim thats a 150mph car? top speed test should be run on flat surface both ways using calibrated equipment.
    i reckon the DD 455hp power ratings are much closer to truth than the LP400 375 when you look at the tested weight and acceleration plus drag. the highest figure i recall reading was a FastLane DD countach near 300kph. I just refuse to believe a LP400 does anywhere near that despite the multiple stories. when magazine do use calibrated electronic equipment to test early countachs, the top speed figure fall woefully short of the claims.
    anyhow hats off for to Victor f for running his LP400 in anger!! whether its 285kph or 260kph, its still bloody fast for a early 70's design.
    respectfully
    hf
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    HF:
    Thanks for your thoughts.
    Yes Bob says it was a standard LP400, electronically (externally) timed. That was his point - standard car.
    I believe Victor's real-world experience also.
    I respectfully disagree with your assertion that the LP400's power figures do not come close to 375bhp. Unlike the Miura's typically over-estimated numbers, after the departure of Etienne Cornil, Paolo Stanzani was careful not to exaggerate with Countach power numbers, and I actually think the 375bhp for an LP400 with 45mm carbs is honest.
    Best,
    Joe
  9. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #3959 raymondQV, Oct 20, 2009
    The DD speedo is extremely accurate, I tested with the GPS Navigation, at 100mph it's only 1mph off...
    Fast Lane tested Martini's car, 312kmh which means at the redline, I doubt there was another car delivering more hp than this 88.5.
    Agree, keep in mind than hp is only a calculated value, derived from the torque and the rpm, a modern formula one engine has only 300Nm but 750hp at 18'000rpm.
    Torque is more or less directly related from the cubic inch, whereas it depends from the engine setting where the torque peak is located and how the curve is formed.
  10. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3960 joe sackey, Oct 20, 2009
    Not always correct. See Emilio's last post.
  11. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Remember though, Formula One driver Martini himself has stated that his QV as tested by Fast Lane was "tuned" special for him. His car was a 1986 QV by the way.
  12. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #3962 raymondQV, Oct 20, 2009
  13. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Forgot to say: don't get too excited by magazine tests. They borrow somebody's car for a few hours, and they have to hope it is operating correctly (it often isn't) and they have to hope they find a good road (they often don't) or ideal test conditions (it often isn't).This is especially relevant with carburetted Lamborghini's where the running order from one car to the next is starkly different. Certain cars are known to be 'quick' ones, others need help and if the testers get one of the latter types, the numbers are going to be off, which is the point Vic & I, who've owned so many Countach are at pains to make.
  14. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Thanks for those links!
    Yes I know that Rosso/Bianco S1....
  15. Redlambo
    Redlambo Formula 3
    2,414
    Pendergrass GA
    Vic Woloschinow
    I always thought they were added for the extra cooling needs of the 4 valve engine.
    Maybe I am wrong seeing that your 4 valve car did not have them installed.
    In my LP5000S parts book I show the both the two and four fan radiator configuration.
    Possibly it was a hot climate option. Hopefully someone else will chime in on the subject.
    Sincerely Vic
  16. Redlambo
    Redlambo Formula 3
    2,414
    Pendergrass GA
    Vic Woloschinow
    #3966 Redlambo, Oct 20, 2009
    After reading through the threads further I noticed Raymonds post on the subject here.
  17. ilrglen
    ilrglen Formula Junior
    Sep 30, 2005
    447
    Yorkton, SK, Canada
    Glen Kohut
    Victor, I remember seeing your white LP400 at that Beyond the West event in Montana. I recall taking that photo and wondering about the silver duct tape all over the front end. Must have been before 3M came out with their StoneGuard product. Or maybe your idea was the inspiration. So I have to ask... Isn't the glue from that duct tape horrible stuff to get off the paint?
  18. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Yes, that was a great rally and I miss them! Too bad she quit putting them on. The glue came off pretty easily with some of that Goo Gone adhesive remover, and it didn't hurt the paint either.
  19. ilrglen
    Sep 30, 2005
    447
    Yorkton, SK, Canada
    Glen Kohut
    We'll just have to talk Jane out of her retirement and get those Rallies going again.
  20. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    I find it mind boggling that owners who spent a cazillion dollars in restoring LP400 drivetrains dont spend $65 dollars to see, monitor and confirm how there engines are running. with the accessibility of dyno shop these day evey countach should be tuned on a rolling road to just to confirm its mixture setting if not to find out what the power outputs are.
    my hunch is that yes there have been numerous CT dynoed. is it possible that owner keep the low dyno results to themselves? you 3 CT owners involved in this conversation may want to dyno your cars yourselves to find out? just dont post the results here...lol
    stanzini motors of the urracco and later (Giulio Alfieri) like the early 70's 308 motors where substantially inaccurate. according to recently rebuilt motors to of 2.5 v8 220hp (claimed) vs dynoed 140 rwhp = 170-180hp. a healthy jalpa 3.5 255hp (claimed) vs dynoed 173hp = around 220hp. it has been well documented that a euro 308 output is near a later QV motor at 230-240 rather than the 255hp printed on the brochures.
    on an early R&T test wallace claims the LP CT was under 2400lbs. when R&T put one on there scales for the 76 test, it weighed over 3000lbs. now the it may have been dry rather than curb weight but i dont think fuel, oil and fluids made up the 600lbs difference. im sure current owners have weighted there owners to confirm this also.
    i believe when the DD came around the factory have became much more honest with the printed specifications.
    whatever the case, all this hear-say and stories has certainly add the legendary CT mystique.... and it dosent hinder there desirability one iota
    all the best
    HF
  21. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    #3971 raymondQV, Oct 20, 2009
    I know my countach, it weights about 1500 Kilo, with luggage but tank not full.
    it was on the dyno, it reached 397bhp but with the muffler restricted, I can only sign that the engine numbers are italian fairytales.
    Look how they tested these engines, no airbox above the carbs, italian exhaust muffler you don't know what is insinde, like this you can imagine they reached 455hp on the engine dyno, but never ever in the car.
    Engine dyno picture a swiss (covered headers and CO tubes in the headers) DD engine 1985: http://www.countach.ch/TestAMS1986/TestQV_5.jpg
  22. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Wallace must have been trying to impress Road & Track, or the writer must have heard wrong, because in the October 1971 issue of Wheels he told the Editor the LP500 weighed 2,750 lbs, and we know the standard LP400 dry weighed 2,850 lbs dry, so with fluids, a tankful of gas & tools, 3,000 lbs is about right.
    As for dynoing engines, I know both Burtoni and Carobu Engineering in California have dynoed LP400 engines with the results coming in at 380 bhp and 370 bhp according to my notes (Carobu also tested a standard Miura P400S engine that came in at some 350 bhp suggesting that the supposedly wildly exaggerated numbers for Miura engines wasn't so true and in fact the numbers were pretty close).
  23. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #3973 joe sackey, Oct 20, 2009
    So you think the DD QV is about 400 bhp then?
  24. paul328
    paul328 Formula Junior
    May 5, 2009
    764
    Scotland UK
    Paul Santoni
    Been reading the recent posts with some amazment! I have an espada which apparently has 350bhp. Same engine as the early CT 400's. My own reckoning is about 320bhp at bes. When lambo increased the capacity to 4.0L I think the mauin differences were the carbs. Between the series I II and III espadas I wasnt sure there were any real differences! Although lambo claimed steadily increasing power form an identical engine!
    So to get top speed we then get into the calculations of drag x weight x power
    The tacho on my CT isnt't accurate. The speedo certianly isn't. I could never work out why the LP400's were apparnetly so much lighter than th later 5000 or QV's?? I appreciate the QV's had a different engine ,but the body steel tubes etc were much the same. 200kg difference???? Well if they were where was the difference? Less tubes? Less hot air????
    The relaible car magazines tested these cars a lot and had difficulty matching the factory figures. Individal cars can vary +/- 10% in all cases. But a base LP400 CT doing 180+ ??.
    Whilst I do not doubt the word of what people are posting, the suggestion that only using the tacho or speedo on a car as a means of measurment isn't relaible. You need to check their accuracy and then determine the readings AT THAT TIME! tyre wear and temp can alter the accuracy.
    I love my CT and other cars, but try not to be hooked up in the myth. My QV is a very fast car. In full tune light fuel load etc it may be very quick even by todays standards. But a 185+ car?? On a level road with no wind and no rear spoiler? Possibly. a LP400? with 130bhp less or thereby? Sorry I don't think so. Do the maths. Will check the formula and post when I can, that is drag x bhp x weight.
    Paul
    Glasgow
  25. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Paul how do you arrive at 130 bhp less?
