360 - Couple more 360 questions | FerrariChat
360 Couple more 360 questions
Discussion in '360/430' started by Kitchdog, Jan 1, 2020.
  1. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Hi all,
    always have my battery on a tender bit of late the starts have been sputtering a bit, had to give it a little bit to make sure it stayed started on a few occasions. Sign of the battery on the way out?
    Also found this hose under the passenger side dash, not connected and it’s the first time I have seen it - any clues what it’s for?
  2. one4torque
    one4torque F1 Veteran
    5,118
    Houston
    One4torque
    That hose might have been the vent hose for your battery.
    Some sealed batteries don’t use the vent hose.
    As long as starter spins normal speed then battery is probably good.
    sputter or tractoring on start up can be mass air meters. Or perhaps if car sat for a very long time I’m guessing fuel re filling lines to injectors. If my 360 sits for several weeks the first start Is rough or slow at 1st. Then subsequent starts are fine.
  3. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    #3 Kitchdog, Jan 1, 2020
    I last drove it a week ago, it has sat longer before and had better starts. Subsequent starts were all fine though. I have noticed that the battery has taken longer to get to ‘full charge’ lately as well.
    I did recently take off my air filter covers and paint them silver, could have potentially done something to the mass air meters when removing the filter covers.
    Another thing I have noticed lately is that little red immobiliser light is blinking faster than usual (at least I’m pretty sure it is).
    Nothing has changed with the drive though, still bringing a smile to my face :)
    Thanks for the info re the hose.
  4. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    That hose is indeed the battery vent tube.
    Kitchdog likes this.
  5. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,738
    Memphis, TN
    Your alarm module may have gone tango uniform. I just replaced mine yesterday. An easy job, $100 if you buy the GM part instead of the one that comes in a horsey box ($500). My old one was toast as the internal, soldered in batteries had leaked, destroying the circuit board. Typical failure mode for these things.
    There's a really good thread on this topic under the stickies for tech help in the 360 forum section.
    Here's where I got the GM module:
    https://www.gmpartsdirect.com/oem-parts/gm-alarm-15213135
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Connect a volt meter to the battery or somewhere and hit the starter- should not drop under say 10.5 volts. If below consider a battery change.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Even with the tender, batteries do not last forever. How old is your battery?
  8. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Thanks for all the replies.
    Battery is only a year old, but was done by the previous owner and is a cheap one.
    I'll start her up tonight, 1 day after last drive and see how it starts.
  9. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Okay exactly 24 hours until I last started it and she did the same thing. Stumbled from cold, so I switched off and back on and she came alive instantly like normal.
    Can probably rule out the battery, that seems fine.
    Just ordered some red line injector cleaner so will run that with a fresh tank of fuel and see if that makes a difference.
    If not, will try MAF sensor cleaning.
    If no luck, will be one for my mechanics at its next annual in May. Will keep this thread updated.
  10. Zanny1
    Zanny1 Formula Junior
    987
    Arizona
    My '99 has done that for years. I don't get a chance to drive it more than once a month, and it always stumbles on first start. Has nothing to do with the battery. If the "miss" is particularly bad, I just turn off the ignition and try it again. That often fixes the stumble. I've heard it can be related to fuel pressure bleeding down over a period of non-use, but unless it gets worse I am not gonna worry about it.
  11. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Thanks for the reply. A quick google search brings up a lot of similar issues and many FChat threads about it. I have driven about 700 miles in the last 6 months so in my case it’s unlikely it would be to non use.
    it’s comforting to hear I’m not alone though.
  12. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,693
    Melbourne Florida
    KGC
    You may also may want to check out the Otima Red Top battery thread (warning) in the event you are thinking of a replacement battery. My battery was not that old either but started to notice how it would run done in less than a week and would not start the car. Repalced it and all is fine. I drive my car at least once a week, most times more. But with that said it can sit sometimes for two weeks. With the new battery, it always seems topped up and the car starts easily. FWIW
  13. Kitchdog
    Kitchdog Karting
    Jan 10, 2019
    151
    Ryan
    Took it out in the nice weather today, wasn’t smoky with all the bushfires - very sad what is happening here in Aus.
    Started fine from cold - these cars are funny things.
    When at idle, is it normal for there to be tiny flutters? Idles at about 1000 and will often move to say 1050/1100 and back to 1000 etc.
    Cheers
  14. My 1st
    My 1st Karting
    173
    Gladwyne, PA
    Scott
    My daughter landed in Brisbane on her way home to north Qld. She said they couldn’t see the terminal from the plane due to the smoke. I’m surprised they even landed. The photos are so tragic. Friends in NSW have evacuated. My prayers are with all in Oz, the people and the poor critters. I’ve heard some species may be wiped out, and some fires may be arson.
    kes7u likes this.
  15. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    23,049
    Honolulu
    Kevin
    I would say yes if the car is not all the way warmed up or if the gas is old. It takes a lot of time to warm up a car with 12+ quarts of oil! If it does this after you have driven for 45 minutes then no.
  16. Angus ferrier
    Angus ferrier Rookie
    Jul 28, 2018
    33
    Australia
    Angu ferrier
    do you know if ngk make ignition coils for ferrari 360 as mine are up for replacement
