couple of questions during my first cambelt change | FerrariChat
Discussion in '308/328' started by qedqeq, Mar 31, 2016.
  1. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    #1 qedqeq, Mar 31, 2016
    Hi all,
    I am doing my first cambelt/tensioner change out since I purchased the car (87328GTB).
    I noticed that the inner boot on the passenger side axle is torn, The boots look pretty generic from what I can see.
    1 - Are they specific to Ferrari, or can I just order a boot repair kit remove the local partshop?
    2 - What are these 4 (Looks like 1/4" 6mm, diameter) tubes for? and why to they end here by the cylinder head? See attached images. The connectors are loose on the exhaust manifold, looks like they have been cross-threaded.
    Regards
  2. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    The 4 tubes are sniffer tubes. They are used to check the co output from each cylinder. There should be 4 more for the front bank.
  3. qedqeq
    Apr 15, 2015
    384
    Oh ok, thanks for the clarification.
    They are all cross threaded at the manifold, connectors are just spinning freely, Should I be fixing this, or should I just cap them off at the manifold?
    Regards
  4. Steve Magnusson
    26,944
    Try a search on "110860" (which is the F part for replacing the tubes) for prior threads.
  5. qedqeq
    Apr 15, 2015
    384
    Great I will Thanks
  6. BigTex
    79,407
    Houston, Texas
    Bubba
    Quick answer is, they rarely sample exhaust gas that way any more..you pass Inspection with a larger sniffer at the tail pipe tips.
    Color Tune plugs are another better way to tune your air/fuel ratio.....
    You do need to make sure it attaches to the header or you will hear an exhaust leak, ahead of your muffler.
    Are you sure there are not plugs in the header, and they simply left these tubes mounted instead of removal??
    EDIT: After looking at your picture I see no plugs, maybe they are just loose.
  7. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    If you are referring to the CV boots, these are also a 80's era 911. Around $5 for the Porsche, $40 for the Ferrari. Would recommend replacing them all.
  8. BigTex
    79,407
    Houston, Texas
    Bubba
    +1.
    Torn ones will be loosing grease.
    That said, you would pull the whole axle, to work it, so maybe doing one side at a time would save labor and expense, if the other side remains OK.
  9. SeattleM5
    SeattleM5 Formula 3
    1,266
    Kirkland, Washington
    Ettore Palazzo
    First off, congratulations on doing your first cambelt change. I found if very satisfying work the first time I did a major service on my 328. Regarding the exhaust sampling tubes, I would recommend not leaving them in that condition (either repair or cap them off). If they spin freely as you describe then you likely have an exhaust leak which has several down stream effects. I'm not sure what version 328 you have but if it is equipped with Kjet w/ lambda then the Jetronic ECU will be fighting to maintain an appropriate AFR as a result of the O2 sensor seeing excess oxygen. Some time ago one of my exhaust sampling tubes on the front bank was compromised and I ended up removing the tubes and capping the ports off at the manifold with plugs (See Steve's post for the part#). Some day I hope to fabricate some replacement tubes for no reason other than to maintain the original look of the engine bay.
  10. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,340
    Encino, Ca
    Carl T
    #10 cmt6891, Mar 31, 2016
    The convenience of the sniffer tubes is that you can get AFR and CO readings pre-cat which is the proper method. Probably more meaningful for carb cars but still very useful. Not to mention it isolates activity at a specific cylinder .
  11. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    #11 SeattleM5, Mar 31, 2016
    I think the isolation of the single cylinder part is really cool, I know that the experts like Dave Helms does it this way and I suspect Rifledriver has had those sniffer tubes opened up on a car or two on more than one occasion. When I installed my Fabspeed cat I welded in a second precat O2 sensor bung so that I could monitor AFR using a second wide band O2 sensor monitor. In particular, I use an LM-1 to set the AFR in open loop operation as well as monitor appropriate AFR regulation with the native O2 sensor in closed loop operation. Not as good as monitoring at the individual cylinders but allows for a good general assessment.
  12. qedqeq
    Apr 15, 2015
    384
    #12 qedqeq, Mar 31, 2016
    Can't thank you guys enough for your assistance guys. Since one boot is compromised, I will be replacing them all, Since I have to tear down the suspension to replace the bushings as well.
    I will remove those tubes and plugging them as the car is running rich, and now I think that it is because of those adding too much oxygen into the system.
    One more quick question. I am trying to line up the bell housing marks, but where on the "PM14" do I line it up with. This is for my 87328GTB. I have seen pictures of the 308 having a mark just before the "P" but I cannot find that mark on my flywheel.
    I got it lined up like the pictures I find of 308's, but I would rather ask here first about the 328
    Attached picture of what I see, please zoom in..........
    Download Hi resolution Picture here: https://drive.google.com/file/d/0B64SezNciaMeRHI5d0VkSXlpVXM/view?usp=sharing
    Regards
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,281
    CT
    John Kreskovsky
    If you are not going to time the cams it really doesn't matter. You can take off the oil cap on the rear cam cover and you should be able to see the timing mark on the rear bank intake cam. Line up that mark with the mark on the cam journal and then you can check to see how the marks on the flywheel line up. In any event, you can just lock the cams and as long as you don't rotate the crank or cams, removed the belts and put the new ones on in the same position. Mark both cam sprockets, drive pulley and old belts to show which tooth is engaged in with gap. Transfer marks to the new belts and install in same position.
  14. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    #14 SeattleM5, Mar 31, 2016
  15. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Your sniffer tubes are probably not just loose. The screw insert has likely disintegrated. On carb cars they were brass brake fitting and steel lines-not sure if yours is the same. If they have disintegrated you will have trouble getting them out so you can screw a cap in. It will be easier if you take the manifolds off the car. The rear ones can we welded shut on the car but unlikely the front ones on the car. Any leak is not allowing air in the combustion as it is down stream of the exhaust valve. The exhaust leak will give an improper exhaust reading if you are using an o2 sensor or other gas analyzer as well as cause for smog failure in many states.
    The timing mark is darn near invisable. I make a big yellow and pink lines on the clutch for the different banks so I can see it. I also make corresponding marks on the balancer/cam cover which are much easier to see.
  16. qedqeq
    Apr 15, 2015
    384
    Great, Thanks a million for all your guys assistance
    Regards
