couple of questions on F430 | FerrariChat
Discussion in '360/430' started by 24000rpm, Jan 18, 2019.
  1. 24000rpm
    24000rpm F1 Rookie
    1. is it supposed to blow hot air even if the ON/OFF button is pressed in? Isn't it supposed to blow ambient air, which is cold in north hemisphere now?
    2. does the Euro version F430 has precat in the header , does it have 2nd air injection?
    Yesitsfast likes this.
  2. ttforcefed
    ttforcefed F1 World Champ
    19,255
    1. not sure anyone actually knows the answer to this. to get the air to stop blowing i press the re-circulation button
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    With the on/ off pressed in, you should get no airflow. When it is out you get air flow
    All 430 has pre cats in the manifolds which have a habit of getting sucked back into the engine
  4. johncasale
    johncasale Karting
    May 18, 2006
    215
    1. You do not get heat with the a/c switch in the off position. It will blow ambient air in the off position. It must be in the on position to get heat in the winter/cold in summer depending on the temperature setting.
    Caeruleus11 likes this.
  5. BlacktopRacing
    BlacktopRacing Formula 3
    1,000
    Pittsburgh
    Dale
    Glad I'm not the only one confused by this. I thought it also depended on if either than temperature control or fan control were set to "Auto". User manual doesn't help. And before you ask, yes, both directional arrows blink whether you have your left or right turn signal on.
  6. efg2014
    efg2014 Formula Junior
    Sep 14, 2014
    657
    Northern California
    I agree quite confusing; the old hit the buttons and try different combinations on the control tends to work in getting the hot air out; usually. :)
  7. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    This same thing comes up every couple of months. It is climate control; it is not hot/cold. If you think about it being climate control on/off it makes perfect sense.
    Caeruleus11 and whatheheck like this.
  8. ttforcefed
    19,255
    with climate control off air still comes through the vents - thats what i understood the OP question to be. to get no air from the vents you need to have the system off and push the recirculation button
    Caeruleus11 and Skidkid like this.
  9. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    TT you are correct. And turn the fan off.
  10. 24000rpm
    24000rpm F1 Rookie
    First, the auto button wasn't pressed.
    The temperaure is set to its max heat. I press OUT the On/Off button, and it blows hot air---- that is normal.
    What I think is not normal is, when I press IN the on/off button, it still blows hot air, and it is 0 degrees outside the car.
    I vaguely remember this indicates a heater control valve failure, any one shed some lights?
  11. ttforcefed
    19,255
    What happens if u press the recirculation button like i said?
  12. ttforcefed
    19,255
  13. 24000rpm
    24000rpm F1 Rookie
    no, i didn't try it yet. But I think you don't understand my purpose
    My purpose is: I want ambient air to be blowing out of the vent when the air outside is cold when the On/Off is pressed IN and the temperature setting is to max heat.
    On my CS, it will blow COLD AIR when On/Off is IN and temp is set to max heat and outside temp is cold.
    ( i am thinking of buying this car)
  14. ttforcefed
    19,255
    Yeh i dont get it. U cant moderate with the temperature control? Good luck
  15. 24000rpm
    24000rpm F1 Rookie
    ok, about the temp, here's what i am confused. Assume weather is cold, 0 degrees C (32 Degrees F)
    On my CS, i am driving normally with heat on ( On/OFF button OUT, temp to max heat)
    I will immediately get cold air if I press ON/OFF button IN.
    On the said 430, i am driving normally with heat on (On/OFF button OUT, temp to max heat)
    I will STILL get HOT AIR if I press ON/OFF button IN.
  16. ttforcefed
    19,255
    Not sure. I really only drive my 360 cs and 430 in summer so i usually have ac on or system off and the top down.
  17. 24000rpm
    24000rpm F1 Rookie
    Yes. I can moderate the temp control. But I do not want to.
    I want to blow air from outside the car, regardless the outside is cold or hot.
    So i'll try your recirculation method a little later today. You got a good point.
  18. ttforcefed
    19,255
    To be honest im confused myself now. I thought u were originally asking how to stop air flowing from the vents
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    I throught i used to understand the system, now u r getting me confused.
  20. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    Not a 430, just a 360. One thing I do have, is if I don't actually use the air conditioner in my Modena, there's a very faint warm flow of air that comes from the vents. This assumes I have not placed it on recirculating air, and it is not also turned 'off' with that one button. Once I turn the air flow dial to auto or to 1, 2 or 3, then, and only then will it begin to run cool air if I chose a temperature which is supposed to be cool, rather than warm. I'm thinking it might have been easier to just keep it always warm via the radiators giving it some heat unless the owner explicitly decides to choose a cooler temperature, after which the condenser turns on, and there's always just a little bit of warm ear leakage due to the design if the driver chooses not to. I may be very wrong with my thinking, it doesn't really bother me...
  21. ttforcefed
    19,255
    im asking jerry to opine - he knows everything
  22. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    Thanks for the compliment Ricky. In this case Im confused too! The only thing I can add, most modern cars, and I think the F430 also, monitors the outside temp vs the inside temp and so if you select 70F for your desired interior temp and if it is 32F outside, it will run heat. If you select the same 70F and it is 90F outside, then it will go for AC. The F430 HVAC would require periodic adjustment while I drove- the longer I drive I would have to just nudge the temp one way or another. I think you are operating it correctly. So I suspect something is wrong with your cars HVAC.
  23. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    Yes, according to the 430 manual, that's how it should work. The ON/OFF only controls the AC and should have no effect on the heating function.
    The 360 manual says the same thing. I am not sure why your CS is behaving differently, but I do know there is enough variation in behavior based on model year and specific car configurations to cause confusion.
    Caeruleus11 and 24000rpm like this.
  24. Rosso328
    Rosso328 F1 Veteran
    7,344
    Central FL
    Paul
    I think the 328 is so much simpler. You get hot air no matter what, even with the A/C set to max. But with the A/C on, at least you get a splash of cold water on your wife / girlfriend / navigator / codriver’s feet in the middle of every left hand turn.
    Skidkid likes this.
  25. 24000rpm
    24000rpm F1 Rookie
    #25 24000rpm, Jan 19, 2019
    ok, enough for the A/C issue, i think its minor and ferrari ( or I) wouldn't care too much about it anyways.
    let's talk about the car itsself, i am about to buy it.
    I test drive the car, the f430 steering is really different than my Modena(360 is better). its difficult to describe it but the 430 is not as accurate and not as easier to turn to what you want.
    Anyway, this is a late version Euro car,made in 2008. When I cold start the car i heard a distinct low frequency sound coming out of the engine. The sound is like a tractor, accompanied by a small shake throughout the whole car. Is that the infamous header leak? After about 1-2 minutes, the noise goes away and the car runs a smooth idle. There's no CEL.
