COURTESY LIGHT STAYS ON | FerrariChat
Discussion in '348/355' started by mike_747, Feb 17, 2010.
  1. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    I should count my blessings as this is the first malfunction in my 355 purchased a year ago.
    Anyway with the courtesy light in the position where is goes off after the door is closed, no longer goes off. so I'm just leaving it in the neurtral off position, toggled to horizontal.
    It does come on in the third or manual position, just doesn't go off in the 1st position with the forward edge pushed up.
    any ideas? Looked in the door jambs and didn't see any push switches to de-activate this light.
    thanks
  2. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,181
    Australia
    Paolo
    it will probbaly fix itself when it gets tired.
    they have a mind of their own sometimes - ferrari's
  3. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    +1
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Do the lights on the doors go out when closed?
    Also I believe there is an override switch for the dome light on the console, may want to check if you bumped that on.
  5. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    True that, maybe you have accidently pressed the interior light switch. Its located right next to the gear stick, above the fuel filler flap switch.
  6. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    +1
  7. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Yep, I did this the other day while detailing the interior. You'd never know the switch was engaged by looking at it. Click it and see what happens.
  8. mike_747
    Dec 15, 2008
    794
    Seattle
    Success, when you push this button you can see the light flicker just a little. Problem solved.
    thanks guys.
  9. mike_747
    Dec 15, 2008
    794
    Seattle
    Trivia - this same small light also was in my 1980 Triumph TR-8. It was in each door panel and worked the same way. that was a cool little sports car - aluminum V8, underpowered but nice torque.
    Triumph fans out there will remember this car.
