Cover up, or not? | FerrariChat
Cover up, or not?
Discussion in 'Technical Q&A' started by RJay, Apr 7, 2007.
  1. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Hi, all you 308 GTS folks out there.
    My 78 came with no cover over the flywheel (where you see the timing marks). Do I need to put this in place? Other than it is a scary bolt collector. I saw a recent engine posted here with not only a cover but a gasket. Do I need to weather tight this? If not, is there water collecting under my flywheel? i.e. why can't you leave it open?
    Experience is appreciated.
    -Rjay
  2. BigTex
    79,398
    Houston, Texas
    Bubba
    It'd be pretty easy to fab the flat cover and gasket...
    A bolt, or oil from a filter change wouldn't be the best thing to have fall in there......
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    It's extremely hard to get the oil filter off w/o spilling some oil down on that cover. w/no cover, that's oil right onto your clutch...
    BTW,The 'gasket' is just a flat sheet of about 3/32" thick rubber the same shape as the Al plate.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I just dropped a nut down into my bell housing the other day. I will now have to remove the transfer gears and bell housing to recover the nut. I HIGHLY recomend the cover.
    Do as I say and not as I do, apparently.
  5. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    I also recommend the cover. Just this winter I got a replacement rubber piece that goes under the cover, so that's easy to find if you want it. The cover itself will be some work to find a replacement I think. The dimensions will be critical as I found it a *little* tough to fit the original once the rubber cover was in place.
    Seamus
  6. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Guys,
    Thanks for all the advice. It looks like a fab of the cover should go quick. I assume that water will collect in the bottom of the housing. Verell, the oil thing scares me! I hadn't thought of that and I have taken the filter off a few times.
    -Rjay
  7. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I thought about fabbing one out of clear plexiglass...
  8. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    787
    Treasure Coast Florida
    MATT
  9. 78-308gt4
    78-308gt4 Formula Junior
    May 22, 2005
    735
    Memphis, TN
    I've had mine almost two years ( I've averaged 3K mi/yr )and changed the oil 3 times. It had fresh oil when I bought it. Next oil change will be later this month. In my admitedly limited experience I have never spilt a single drop of oil changing the filter.
    The last time I changed the oil, once I had the filter clear of the car and over a drop cloth I tilted it somewhat and some oil came out. If you keep the filter directly upright the enitre time it won't spill.
  10. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    #10 FasterIsBetter, Apr 9, 2007
    Definitely cover it. There is no reason NOT to cover it, and lots of reasons why you should. Just fab up a cover, and making a gasket is even easier. The next time you are working around the engine and drop something, you'll thank yourself.
  11. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Yea, yea ....THAT engine! Thats the nice little cover that got me thinking. Actually, Matt (Polo35), your suggestion on the $17 is not such a bad idea. I can fab one but then, at that price, why not.
    Thanks everybody...I think we've beat this to death.
    -Rjay
