Covering cold engine to clean 328 gts | FerrariChat
Discussion in '308/328' started by TK 328, Jun 15, 2007.
  1. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Perth West Australia
    Tony
    Just wondered, is important to cover the engine when cold before washing a 328 gts???????, Hope this is not a stupid question. If it is you can remind be to put the Targa roof in before washing also.......Thanks guys..and girls. Tone
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Not really, cause' there's no reason to get a lot of water through the louvers if you're washing by hand.
  3. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,608
    Gates Mills, Ohio
    Jon
    You might post in the 308/328 section, but the short answer is that some of us consider it a good idea.
    You don't want to give the engine a drenching in any event. I usually take a large, old towel and drape it over the engine, and take care not to aim the hose directly through the louvers on the deck lid. I've had no problems with this approach to date.
  4. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
    Thanks guys, I should have posted in 328 section or Technical Q & A. Just wanted to check others experiance You guys are the coolest thanks for such a quick response....Tone
  5. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
    Did the towell thing, worked a treat.Cars gleeming clean.Thanks
  6. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    As Bullfighter said, some do and some don’t. I don’t worry about a bit of water on a hot engine but am somewhat concerned about a cold one where the water won’t evaporate quickly. I cover my 308’s engine with a cheap plastic shower curtain liner, which is heavier than typical plastic dropcloths and thus easier to handle and less likely to tear.
  7. Mitch Thompson
    Apr 17, 2007
    42
    Bingley (England)
    Mitchell Thompson
    Does this mean it's bad to drive a 328 in heavy rain? I plan to buy a 328 in a year or so and as I live in England I'm pretty much guaranteed to get cought-out by the weather on some occasions.
  8. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
    No buddy, I got caught in the heaviest rain in the world in Queensland Australia for 3 hours shortly after picking up my 328 you will not have a problem. The only one I got was my windshield leaked!!!!!.......Dont ask!!!! Trust me you can drive them in the rain-No problem.Enjoy. Tone
  9. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Within a few days of taking delivery of my Ferrari , I went to the car wash and sprayed the engine compartment with engine degreaser and rinsed it off with hot water, no ill effects at all. (actually did it twice)
    It wasn't until I read about it here, that I started to be more careful about water in the engine compartment. I think the coils and distributor might be the most sensitive areas , that you may want to cover.
    The one thing that I ALWAYS do after washing the car, is to go for about a 10+ mile drive to help dry the engine compartment and it's components.
  10. Bullfighter
    Jan 26, 2005
    22,608
    Gates Mills, Ohio
    Jon
    I'll defer to the real technicians on this, but it is the electrical bits that ought to be kept dry -- distributor caps were my first concern as well.
    I'm in San Diego, so it's no problem for me to keep the whole car bone dry all year, but I worry about dumb stuff like water spots on the coolant expansion/overflow tank...
    I don't think driving the car in the rain is equivalent to pouring water into the engine bay while the car is cold and stationary.
  11. Theo
    Theo Formula Junior
    May 6, 2002
    359
    Westford, MA
    Theo Pappas
    When i had my 86 326 GTS, I washed my engine every time I washed the car. My mechanic (John Tirrell at IFS) told me to. I just sprayed Fantastic all over it and then used a garden hose (with a gentle shower head) to wash it off. I then just drove the car a few miles to dry it off. I had no problems with it driving in the rain either. no leaks at all. Had 0 problems with it for over 2 years. The engine was bulletproof.
    Theo
  12. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Wash it with a low pressure water spray. Then spray WD-40 all over the place, to displace the water, but especially on the coils, plug wires and distributor caps. Then a nice drive until you reach normal temperature. Anyway, that's what I do and haven't had a problem.
    Erich
  13. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    25,018
    Dallas, TX
    Jim E
    I don't see the difference in washing your car or leaving it in a parking lot in the rain. It's a car, it's going to get wet.
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Shooting water under pressure at an engine with the engine cover/hood open is different than plain old rain. It's a matter of where it is aimed, how much pressure etc. Your going to hit some areas with water that are typically not touched by rain under normal circumstances. It may or may not cause a problem depending upon other variables.
    Erich
  15. jimpo1
    Jul 30, 2001
    25,018
    Dallas, TX
    Jim E
    I guess that depends on your washing techniques. I never use more pressure than a simple garden hose can provide, without a pressure nozzle. I've seen rain fall harder. I've also never washed it with the cover/hood open.
  16. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    True on the high-pressure avoidance. I used to be a real enthusiast for blowing around in the engine compartment with the high-pressure wash at a quarter DIY stall, after soaking a warm engine with the engine clean setting. Sure made things look clean inside there!
    UNTIL - my ZR1 suddenly started hitting on only 7 cylinders right after one such treatment. From the second I started it up in the stall. It did not go away after a reasonable drying time.
    It turned out to be an injector that went out. This means pulling the intake plenum, flow balancing all 16 injectors (primary & secondary), replacing 3 of them, and cleaning everything up. Six Hundred & Fifty bucks. The tecnician also pointed out that my starter motor and solenoid are up there in the valley of the vee under that plenum, too - and that I had soaked them down pretty good as well. I am sure that Ferrari's probably have analagous little critical "water collecting traps" that can wreak havoc on electricals.
    So, nothing gets near the ZR1 or the Testarossa except for limited hand spraying, brushes and cleaning cloths nowadays.
  17. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I do wash the engine (warm) from time-to-time with a garden hose and a spray nozzle (after applying degreaser). WD-40 after that and no problems.
    Erich
  18. f355spider
    f355spider F1 World Champ
    18,055
    I never covered my 78 308GTS or 87 328GTS when washing. I did have a problem with the 78 308GTS, though, the spark plug wire covers (rubber cover caps), where not sealing well, and allowed water into one or two plug holes. This caused a miss. I replaced all 8 caps, and never had a problem again. I guess after 23+ years you need to replace them! ;)
    So, no, if you have your distributor covers and spark plug hole cover in place (and in good condition, making a good seal) there is no reason to cover the engine. Otherwise, what would happen when you are driving or park the car in rain? (heaven forbid!) :)
  19. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,831
    Cerritos, CA.
    I drove my 308 once in a pouring rain I mean Pouring Rain for an hour I didn't have any choice I had to get home, the car ran perfect, no electrical issues, I even got stuck at the traffic light for about 3 minutes without any problem. Anyway I know it's not just a car it's a special car, but remember the car came from the factory with a set of wipers that means it can be driven in the rain or design so you can, if you have to.
  20. wetpet
    wetpet F1 World Champ
    10,210
    funny, i just went to pick up my 328 and had this problem. i had the engine power washed and it started missing. we pulled the plug wires and the extenders were wet. but they were also corroded so we replaced them. pulls like a stallion now. be careful with water around your engine.
  21. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    "Power washed" versus rain or rinsing/spraying with a garden hose is almost comparing apples to oranges.
  22. wetpet
    10,210
    your point is?
  23. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Try this...the next time it is raining, step out the back door and hold your face up to the sky with your mouth open.
    Then, for comparison, go to the quarter car wash and ...
    But I guess we get the point, don't we?
