430 - Crack / hole repair in plastic under tray | FerrariChat
430 Crack / hole repair in plastic under tray
Discussion in '360/430' started by Mario Andretti, Apr 29, 2024.
  1. Mario Andretti
    Mario Andretti Formula 3
    1,777
    Boston
    Hi all,
    I remember seeing some handy people here repairing the plastic undercover with fiberglass kits and resin and stuff... I managed to hit something under the car and put a big hole in my big plastic (rear) under tray.
    What is the best thing I can use?
    Thank you
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
  3. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Mario Andretti and flash32 like this.
  4. colorfull
    colorfull Formula 3
    2,340
    Franklin Park, New Jersey
    John Napoli
    Not really versed in this, but when I repaired mine, looked into it a bit, just note the tray is not made of fiberglass, I'm not exactly sure what the material is but it is some kind of plastic, so I would stick with products designed for plastic repair.
    I used a sheet of ABS plastic and JB Weld to effect repairs, worked very well
    flash32 likes this.
  5. Mario Andretti
    1,777
    Boston
    On my undertray, I can clearly see strains of fiber going through as the hole was ripped....Maybe different years had different materials used? Or is it just a core of fiber of some kind with plastic layered on it ?
  6. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    I think this is exactly what it is, not straight plastic as that cracks too easily, it's just as you state, some kind of ABS but with material in it for reinforcement
    You can't make it out too well in this pic, but I remember when I repaired the cracks, there was definitely something in the center
    Mario Andretti likes this.
  7. Mario Andretti
    1,777
    Boston
    Yes, that's what mine looks like, I'll take a pic when I go back in the garage (installing headers now :) )
  8. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    Likely a CFRP or which is common in the industry. That's carbon fiber reinforced plastic. There's also a glass fiber version. It's usually either injection molded or pressed.
    Mario Andretti and colorfull like this.
  9. David Copeland
    David Copeland Karting
    Mar 9, 2019
    58
    League City, TX
    David Scott Copeland
    Had to repair/replace some of the attachment tabs and cut replacement tabs from a carbon fiber panel and added threaded inserts. Attached with JB Weld and glass cloth to distribute the load over a larger surface. Should rough up attachment surfaces for good adhesion. Has held up great for 5 years and counting.
    colorfull and Mario Andretti like this.
