crack in vynel upholstery on my dash | FerrariChat
Discussion in '308/328' started by ninoinadino, Feb 23, 2010.
  1. ninoinadino
    ninoinadino Rookie
    Feb 23, 2010
    7
    Can anybody help in my search for black upholstery for my 308 gtb 1976 (dash top upholstery cracked). as the rest of the interior is also black vynel in good condition, I am trying to keep this car as original a possible , so I would be much obliged if anyone can point me in the right direction . Thanks
  2. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    Try looking at your local fabric shop.
    The brown I got for the seats on the boat was real close in looks to the black on the dash of the Mondial
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I've bought miles of vynel but vinyl was called Naugahyde in the previous century and bought from Auto Upholstery places. It is bought by the yard and 54" wide and in more colors and patterns than you ever imagined.
    Not a big job DIY as long as no sewing is needed in which case the upholsterer's labor is needed.
    Were I to do my dash I would buy another cow hyde and dye it myself. Did that when I did the ceiling and package shelf. Hydes cost about $450.
  4. 903L
    903L Formula Junior
    Aug 13, 2009
    703
    S. Calif. / Arizona
    Marty K
    Lots of that vinyl on eBay. Ferrari 308 parts and accessories.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    In order to re-cover the dash it needs to come out. Sorry but on your car this means taking out the windshield. You can find vinyl that is an exact match however it will be aged at a different rate than the rest of the dash so you are left covering the dash and the insturment pod which involves stitching to do it right. It is a bottomless pit I know. Depending on how bad the crack or rip is, do not rule out one of those mobile repair services. Depending on the guy the work can actually be quite good and act as a good temporary repair before taking on the bear of a job I pointed out. Good luck with it.
  6. 308 GTB
    308 GTB F1 World Champ
    11,723
    New Jersey
    Barry Wolinsky
    #6 308 GTB, Feb 23, 2010
    +1 There's an upholsterer "on call" to nearby Classic Coach who works miracles with vinyl and leather repair.
  7. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Guess you can remove the windshield if you want to but according to others, dash removal is "super easy" by removing the instruments and 5 bolts - 2 at door jam and 1 at relay panel.
    http://www.ferrarichat.com/forum/showthread.php?t=274376
    _________________
  8. t3thomas
    t3thomas Formula Junior
    May 9, 2008
    427
    North Carolina
    GThomas
    This was being discussed just the other day and I had made the same assumption, however another Fchatter who has a GTB said the unlike the GTS that the winshield has to be removed. As far as the replacement material, you can get the authentic material at World Upolstery: http://www.worlduph.com/itvnl.htm and then either recover yourself or have a local upolstery shop do it for you.
