CRANK PULLEY!! Hi - Can anyone tell me the torque setting for the crankshaft pulley and also the bolts which connect the torque convertor drive plate to the flywheel? My WSM states in Kg/m Securing Flywheel - 3.1 Securing Flywheel to Crankshaft - 8.5 Securing Damper to Crankshaft - 20 Not sure if I've lost something in translation but just wanted to check Many thanks
That should actually be "Kg-m" (kilogram*meter), not Kg/m. 1 Kg-m = 7.23 lb-ft so just multiply them out to get them in lb-ft (and those values seem reasonable for the sizes of those bolts). I use this website for converting units: http://www.onlineconversion.com
