Cracked 355 Wheel Lug Insert? | FerrariChat
Discussion in '348/355' started by broepke, May 25, 2007.
  1. broepke
    broepke Karting
    Feb 25, 2006
    142
    San Francisco, CA
    Brian Roepke
    Hi All,
    Got a few scratches reparied on my 355's wheel this week and the guy who did it (VERY good with wheels and knows Ferraris) said that the "aluminum inserts" for the lugs were showing some cracking.
    Does anyone know where i get replacements for these? I tried Daniel but I didn't see anything nor did the parts manual show them...
    Thoughts? What am I looking for?
  2. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Hill Engineering....
  3. broepke
    broepke Karting
    Feb 25, 2006
    142
    San Francisco, CA
    Brian Roepke
  4. Ricambi America
    Sponsor Owner
  5. ScuderiaLV
    ScuderiaLV Karting
    Dec 6, 2006
    230
    Las Vegas, NV
    Don C.
    I have a couple of questions on these wheel inserts:
    1- Has anyone replaced their inserts with the Hill Engineering ones?
    2- Anyone have any proceedures on how to replace?
    3- Is there any machining work that needs to be done in order for the insert to be mounted?
    4- Will the torque value on the lug nuts remain the same on these replacements?
    Thanks in advance for the input!
  6. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Well well well......seems like I posted something about these inserts cracking.
    Thought everone said this was a non issue???
    Daniel should be able to give you the replacement procedure. If not contact Hill Engineering.
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    You did say so Bruce as have some others in the past ;). Like you said why would hill eng. make them to begin with...... :rolleyes:.....
  8. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    this is interesting. are these inserts stuck to the wheels or do they come loose? Can someone show a picture of what they look like mounted on the wheel?
  9. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    They are basically an interferance fit collard sleeve with lug bolt taper receptacle to strengthen and protect the magnesium from the lug bolt.
  10. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    thanks! for a moment there I thought my wheel saga of putting 355 wheels on the 348 was due to not having these inserts, but I just popped a bolt and verified that I do. They are firmly stuck on the wheels.
  11. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
  12. Uberpower
    Uberpower Formula 3
    1,115
    #12 Uberpower, Jun 17, 2024
    Was the procedure to replace these ever published?
    Edit, found it:
    355 wheel problems
