Cracked frame and other assorted woes | Page 3 | FerrariChat
Discussion in '348/355' started by RSO1091, Mar 10, 2016.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    "Member, you member? Member I told you?"
    :p
  2. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    So as a compromise to my current space crunch situation, I won't be removing the engine on my F355 right now. But Tim has agreed to try to weld the subframe for me next Thursday at his place in Long Beach. Immediately following that surgical procedure, I'll take her to Craig at FASTCARS in Redondo Beach for the motor mount and CV boot replacement. I'm certain that an engine-out is in my future somewhere down the road, but for now, this will address the most critical issues and not break the bank. If any of you other Stooges are around next week, come by Tim's for some pierogi...
    Cheers, Henry
  3. fatbillybob
    Aug 10, 2002
    29,256
    socal
    I have a breakfast at the Toyota Museum but free after about noon. At the least lets get lunch. MM failures don't happen very often but CV boots all the time over every car made with a CV joint. You should learn how to service them. It is really fast and easy once the axle is out. That could really be a Spring Stooge gathering event and many could learn from that. But you probably just want it fixed. If someone has an old axle we should service it at the next stooge event so people can learn. The title of the next stooge event?
    "Don't be an axle and miss Spring Stoogapooluza"
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Thursday at my place
    I could use a hand of stooges :)
  5. fatbillybob
    Aug 10, 2002
    29,256
    socal
    What time? And PM me address again because I'm stupid.
  6. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I'd like to meet you if possible. PM me an address and time.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Spring is here, when are the stooges meeting up for StoogeFest?
    M
  8. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,613
    AZ
    Rick
    Sounds like the way to go if you ask me. It will probably be stronger than it ever was originally once Tim gets in there. Seems silly to me to drop the engine if it doesn't need belts yet. In a few years you can, reassess it when the belts are due.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I will say this one last time.
    Drop
    The
    Engine
    To weld that subframe correctly you do not want any stress on it. You have a bunch of Stooges out there willing to help you, one of which is officially certified. Do it right, drop the engine.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I agree....however, it's quite possible to load the frame in a manner to close the current (crack) gap, hence removing the load.
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    #61 SoCal1, Mar 25, 2016
    Yuuuuup, done it several hundred times, literally. Peace of cake.
    This is an exact copy of my last machines, I had 4 of these.
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I'll see if I can make it. I can get the address from Bruce. I sense an impromptu mid-week Stoogefest!
  13. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Bring a motor mount. 30 minutes.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Call it a ice cream stoogefest LOL
  15. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    I need all four replaced Bruce, but I didn't want to get in Tim's way.
  16. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    I realize that's the absolute right way to go Ernie, but I really think that with Tim's welding ability, I can put off the gussets and further welding until the next major in 2018-19.
    Henry
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    When I looked at the crack it had not separated at all so you will not need to load it unless it has moved. I think the pics show the same. Some hiw a chunk is missing can not really understand how that happened.
    Actually all four sides looked like the pic with no separation on the crack
    Its possible its been cracked fir some time, maybe even befor the engine out?
  18. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Defiantly need to play with the subframe frame overhang to see if anything else hidden in there.
    Worst case guys I have 2 355 subframes in stock we can gang bang and swap it over LOL
  19. yelcab
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    The last one I saw also has a piece missing. I have no idea how that came about...
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    How the heck you think that happens Mitchell?
    Was it also a 95 car?
  21. fatbillybob
    Aug 10, 2002
    29,256
    socal
    Cut out thin tube. Weld in thick tube on your extra subass and do an exchange program.
  22. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    One thing I did notice the tube is of very poor 1990s euro spec, not the best material at all
    Just welding them can distort the metal enough to weaken it then vibration from out of balance wheel crack it over time.
    This was quite a I would say not common but a seen issue from that era and region.
    Yeah we will throw a splint in it and weld here up with nice temperature controlled welds.
  23. yelcab
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Tim
    teach me how to weld ...
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Mitchell any theory on why a chunk is missing?
  25. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    If you want to know the answer to that question you'll have to fly back down here next week and help us out Grant. Not a snowflake in sight...
    Cheers, Henry
