Cracked frame and other assorted woes | Page 7 | FerrariChat
Discussion in '348/355' started by RSO1091, Mar 10, 2016.
  1. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    #151 RSO1091, Apr 2, 2016
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #152 SoCal1, Apr 2, 2016
  3. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Glad you guys enjoyed them. Looks great. That's one thing we Stooges can do is cook (and eat I suppose).
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Thats what its all about :)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,670
    San Carlos, CA
    Mitchell Le
    Cook, yes it seems like the Stooges can cook.
    153 posts, only 3 posts are for the repairs. The rest is all about food. Hesus Cristo.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Good observation Mitchell
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    It's only a car
    Food is FOOD :)
  8. fatbillybob
    Aug 10, 2002
    29,261
    socal
    Sometimes we talk about guns...
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    I do remember a car being there, I think it was red
  10. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Great stuff! Great photos!
  11. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Mitch, have you EVER seen a thread on FCHAT that didn't eventually get hijacked or deteriorate into something 180 degrees from the original post? You need to come down a bit more often and we'll convert you. You may gain a few pounds, but we'll get you in the end.
    And now back to our original programming. Yes we managed to repair the cracked subframe (driver's side, vertical support adjacent to the control arm. Because of the limitations that not removing the engine posed (sorry Ernie), it was decided by committee to weld the breach on all four sides as a temporary measure until a more permanent repair could be completed when the engine-out is done somewhere down the road. This seems to be something that may afflict early model 355's, but we urge you all, regardless of the year car you own, to scrutinize your subframes more thoroughly for any signs of metal fatigue or cracking. Once I have the car apart, I'll be welding on some support gussets to help stabilize the sub-structure. If you should detect a defect, we would appreciate it if you'd pass along the information for the benefit of us all. Now that wasn't so bad was it?
    The cooking and comraderie is what these Stoogefests are all about. I really wish we could hold an international event somewhere convenient for the rest of you guys to join us. It truly makes for a memorable day.
    Cheers, Henry
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Great public service announcement.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Vince did we notice that the later model had a gusseted suspension mounting point to remedy this?
    I will check the 95 challenge cars
    BTW those cross members weighed a lot more then the OEM ones, took them off and put them on a scale. So newer frame parts are made to a higher quality.
    I will post pics later with weights
  14. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Checking weight differences between years would be good information :) ..... assuming they just didn't add more paint ... ;)
  15. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Yes, the later model subframe had one of the uprights with a gusset. The other did not. Henry's didn't have one at all, as I recall. And although we did not measure, the replacement subframe pieces (the 2 removable horizontal ones at the bottom) were noticeably beefier than the stock pieces.
