Cracked frame | FerrariChat
Cracked frame
Discussion in '308/328' started by maxflynn, Sep 4, 2018.
  1. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Anyone with a 308, 328 can you check the frame where the rear shock is mounted. I found a crack in mine, I suspect it is from a previous issue, can't say for sure since I am 5th in line of ownership. But I have noticed this in a couple of other cars, one 308 and another 328. Same spot same crack. If anyone else has this or knows about this, any comments are welcome.
    David
  2. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    That sure is a clean break, looks more like a seam than a crack.
    Rosey likes this.
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    Not a crack. That is the butt joint of two rectangular tubes. Nothing to worry about there.
  4. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    So it's fatigued or poorly welded from factory? It is cracked just the same, as in not one continuous piece. Seems its a very stressed part of the frame, no?
    Anyone else have this on either side?
  5. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    No, it is, nor was it ever, welded or one piece. It's just two separate pieces. At least to the best of my knowledge and observation.
  6. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    I don't understand. The two pieces just sit there beside each other, or it is somehow sleeved inside? I'm sorry, but i can't see how that would be made, especially so close to a suspension pick up point. FWIW, the other side has no crack ir visible seam or anything. I can understand if the two pieces were butt welded then ground smooth, but just sitting there, I don't get it.
  7. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Can't imagine this is ok.
  8. absostone
    absostone F1 World Champ
    10,049
    weld it paint it
  9. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Thanks, but if anyone else has seen this problem or has it, would you please mention it.
  10. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    My car has some sort of protective paint/coating on that area, so I can't tell if it's two separate parts. But, there is no visible seam whatsoever. I would have assumed it was all the same piece of metal, until I saw this thread.
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    What does it look like underneath?
  12. absostone
    10,049
    do the welds on the shock mount look stock to anyone? either way the frame seam is not welded and should be. just set the car up with equal chassis heights at each corner and weld it. make sure the doors are closed and correct tire pressure for the heck of it to keep the heights even
  13. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Underneath cracked side. Notice weld at the crack position. Indicates to me that the top weld was finished for aesthetics at the factory.
  14. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
  15. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
  16. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Also metal finished on the top for appearance sake.
  17. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    As I mentioned before, I have seen two other examples the same as my car. Question is, do they have a tendency to crack in this spot, on this side only, or both sides? Or is this a consequence of a minor shunt? So if anyone is admiring their 3x8, take a quick look. If it is cracked, and you know there was no damage of any kind, please post.
    Thanks again
  18. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    I'll checked mine out tonight and post
  19. AN-M
    AN-M Formula Junior
    Jun 30, 2012
    367
    Norway
    André
  20. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    My 78 is also like this. Maybe the approach differs by year.
  21. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Maybe. Mine is a 1985 GTS.
  22. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    This was mine ('79 GTS) before restoration. Smooth at the bend. The close-up next to it shows some of the original welding :) It''s a high-stressed area given the spring/shock mount so has probably fatigue cracked. Notch, clean and weld. Remember to isolate the electronics as much as possible-- disconnect battery and earth clamp very close to the weld onto bare metal.
  23. Schulz308
    Schulz308 Formula 3
    1,506
    STL USA
  24. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    So gently take off the paint on either side of the crack a few mm's and see if there was a weld there.
