360 - Cracked Tubi Style Muffler. Switch to OEM? | FerrariChat
360 Cracked Tubi Style Muffler. Switch to OEM?
Discussion in '360/430' started by Ds1, Sep 27, 2021.
  1. Ds1
    Ds1 Rookie
    Dec 27, 2011
    39
    Syracuse, NY
    Hey all,
    Wanted to get the forums thoughts. I heard a loud rattling sound from my muffler area, pulled it last night and discovered both inlets of the Tubi Style muffler are cracked pretty badly.
    Seems like a common issue. I can have it repaired, but I'm sure it will crack again,
    Do you think it would make sense to just swap back to an OEM muffler? It seems like the tips have to be replaced to OEM, correct?
    The car also has Tubi headers and high flow cats, so I'm hoping everything lines up with the OEM parts.
    Any other thoughts or ideas let me know!
  2. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    Get it re welded and see when you refit it see if it is stressed- are you putting strain on the weld when you bolt it up. Fit a spacer on a bracket if you need to. The pic of the old one looks as if it has been pulled, ie stressed
    EastMemphis likes this.
  4. Jb-Slow
    Jb-Slow Karting
    May 11, 2020
    203
    Easy weld job
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    The original weld looks pretty good,
  6. Ds1
    Ds1 Rookie
    Dec 27, 2011
    39
    Syracuse, NY
    I read some other threads that said these crack pretty often, I just didn't want to have to take all the time to get this back apart if it cracks again, but if you all think a weld will hold then I will give it a try!
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    You can always get the welder to fit a couple of gusset plates at right angles to give it extra strength
    one4torque likes this.
  8. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,165
    Wash DC area
    Robert
    I had mine welded up, no issues
  9. Ds1
    Ds1 Rookie
    Dec 27, 2011
    39
    Syracuse, NY
    Got this quotes to weld by 2 places today. 1st place said they couldn’t weld it without a jig to hold the inlets in place otherwise it could not line up after.
    2nd place said they don’t need a jig and would fill it with argon, and it would cost $700-$800.
    My switch to OEM thought is looking a lot better. Does anyone know if the aftermarket Tubi headers and cat pipes will line up with the inlet of the OEM muffler? I know I will have to get OEM tips as well.
  10. one4torque
    one4torque F1 Veteran
    5,720
    Houston
    One4torque
    You might see if there is a welding school in your area. They might enjoy working on a Ferrari part for free.
    I’m a half ass mig welder… I would try it myself b4 dropping 800+tax to those boys,
    that should be repairable
    Might be a good time to build an f430 cs copy exhaust. They sound superb!
  11. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Your quote for 800 is high yes that is getting back purged with argon and when you do SS welding that is the correct way. But that is a 300 $ job.
  12. Jb-Slow
    Jb-Slow Karting
    May 11, 2020
    203
    1st shop just doesn't want that job.
    2nd shop just wants your money.
  13. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    If this was my problem, I'd spring for a MIG welder and a pile of stainless tubing to practice on and then do it myself.
    I'd have a mig welder already except I can't justify it quite yet.
  14. one4torque
    5,720
    Houston
    One4torque
    East- exactly what I did… I was getting quotes to weld some simple subframe plates into my e36 project…. People wanted $1k to look at it.
    I learned to weld on my e36 chassis… tig upside down on my back…. I pivoted to mig now w better results.
  15. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    I would not weld SS with a mig. Yes you can but tig is much better and the correct one way. I did my cs exhaust that had a crack and fixed these myself.
    Image Unavailable, Please Login Image Unavailable, Please Login View attachment 4064605
  16. 67bmer
    67bmer F1 Rookie
    2,959
    MD
    That's really impressive! I have never welded anything.
  17. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    I'm self taught from when I was 12 when I picked up my first mig welder. Been in the automotive game my whole life
  18. one4torque
    5,720
    Houston
    One4torque
    Nice work clean!
    my first useful thing w my welding machine was fixing a cheap bearing puller tool that broke on 1st use.
    highly rec buying a machine and getting a level of prowess. Fixed outdoor oven, lawn mower deck, tools, car chassis, car hood hinge mounts, exhaust fab, made wife an over built pencil holder which can double a blunt weapon.
    Il Tifoso, EastMemphis and clean512 like this.
