430 - Crank No Start After 9 Months of Storage | FerrariChat
430 Crank No Start After 9 Months of Storage
Discussion in '360/430' started by Qavion, Feb 2, 2022.
  1. Qavion
    Qavion F1 World Champ
    13,938
    Ian Riddell
    Folks, I'm trying to help an FChatter in PM with a no start problem on a F430. He/she seems a little shy to ask on the public forums.
    New battery (voltage at fuel pumps is 10.6 volts, but haven't been able to ascertain if this is during cranking). Do the 430 pumps pumps prime with the ignition being turned on? If so, do they run for a few seconds or continuously?
    Spark plugs replaced
    All fuses checked
    Fuel tank topped up with new gas
    Fuel pressures on rails not yet checked.
    Suggested checking the inertia switch.
    I don't know if the FChatter has an OBD code reader.
    FChatter currently suspects an immobiliser issue, but I don't know the normal indications on a F430.
    "when I push key fobs button, it chirps once with signal indicator lights once for a short time (door is unlocked).
    When I press key fobs to close, it chirp twice with a longer 3 seconds indicator lights stay on, then indicator off (door is locked)."
    Not sure why the indicator (LED?) would go off with the car locked.
    The immobiliser and alarm system have separate ECUs on the 430, so I guess the alarm side of the system is ok as the siren is chirping.
    There is a "CODE" (padlock) symbol on the instrument cluster on the 430 which I assume is related to the immobiliser side of the system, but I don't know the finer details of this symbol
    Does the padlock symbol only disappear after engine start on a 430?
    Would a long storage with no trickle charger affect the immobiliser?
    Is there anything which needs to be reset after a flat battery (prior to cranking)?
    Thanks!
  2. Qavion
    13,938
    Ian Riddell
    P.S. Does the immobiliser stop cranking on 430? I can't see any link between the immobiliser and the start relays in the wiring diagrams. The START button on the steering wheel isn't just a dumb button however. The CAN busses do talk to the steering wheel so they may have the ability to send data to the START button from the Immobiliser ECU. Seems overly complicated, though.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,703
    Central NJ
    Dominick
    Sounds like we are helping the same person but we are getting different feedback ..if it is the same person his dash is dark (busted) and can't tell if paddlock appears
    If paddlock appears the system stops juice to pumps .. iirc
    Qavion likes this.
  4. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    I spent the necessary time and effort to implement a full immobilizer delete for the F430 a few years ago now that works 100%.
    I can completely remove the immobilizer box and once this is done the key will start the car without using fobs at all. Since on the F430 the immobilizer is a distinct unit to the door lock reception that still works even if the immobilizer ecu is totally removed. I've seen a few F430's with immobilizer issues and if you go the dealer route you'll be spending many thousands as they seek to replace everything including engine ecu's which are paired to the immobilizer. This is not required but unfortunately dealers don't have the required tools or support from Bosch to accomplish this.
    If you start getting desperate or ridiculous bills start being quoted pm me and I will see what I can do to help. Good luck!
    rizzo308, flash32 and Qavion like this.
  5. Qavion
    13,938
    Ian Riddell
    As we know, the instrument panel is fed by and feeds data to all parts of the car on CAN busses. The panel may not be supplying data to the engine management or immobiliser system. Maybe we should be focussing on this?
    Maybe he/she should recheck the instrument panel fuses AF15 and AF9 in the frunk?
    flash32 likes this.
  6. Qavion
    13,938
    Ian Riddell
    If you want to test your fuel pumps, you can jumper relays behind the seats.
    The 430 has two levels of power for the pumps. Jumping pins 5 & 3 on relays PSR8 or PSR9 should activate the left pump. i.e. pin 87 and 30 in traditional relay numbering. The pins are live (no ignition required) so take care when jumping the relays.
    Same for the right pump using relays PDR8 or PDR9
    The "8" relays are for low speed, the "9" relays are for high speed. Try jumping the low speed relays first.
    Wiring diagram here:
    https://www.dropbox.com/t/tkKDGo8fObbKp2HQ
  7. Amber Cooper
    Amber Cooper Rookie
    Jan 19, 2019
    13
    AmberCooper777
    Hi all,
    Thanks to Qavion on opening this thread (as i don't know where to open the public thread as it requesting to add recipient 1 by 1 which is quite hefty).
    Yupp, the FChatter - it was me :-D
    Long story short...around 2 years ago, i disconnected the battery from my F430 as i went out a few months outstation for working. After few months, i came back & saw the battery totally flatout, so i tried to jumpstart her using another sedan car jumper wire directly to the battery. That's the starting point when i noticed my instrument panel went blackout with nothing working including all needles, gear display, fault indicator, tachometer, odometer, fuel meter, temperature meter, etc. - no Xmas tree at all. However, battery fully charged, pushed start button, engine cranking, & finally engine running perfectly for drive, but only up to 2nd gear only. Subsequent gear shift up, i need to neutral 1st while driving then shift up 3rd gear, and so was the 4th, 5th, onward (but i didn't drive more than 3 miles). Just drove to wake her up, warming up 2-3 miles, refill fuel, then park again, covered with canvas inside garage for another few months.
    1 & half years ago, i came back from outstation, took the disconnected battery plug-in back, tried to wake her up after a few months sleep. Indeed successful. Drove her around a few miles, warm her up, chilling a while, refill the fuel, then park her again under a canvas inside my garage as usual.
    Last year, I disconnected my battery & left my F430 longer around 9 months bcoz of outstation tight schedule. As usual, the climate was around 36 deg C (97 deg F). When i came back, bought a new battery with same specs, refill the gas until full, & tried to start the engine. Heard the engine is cranking, but won't start. After a few cranking the engine still not start, i decided it's time to change all 8 spark plugs to a brand new ones, then try starting engine again. It's cranking, but still...the engine won't start.
    a) Opened the passenger footrest & tested Power Fuses (Maxi 5 alternator) with digital multimeter, no fuse burnt.
    b) Opened the frunk & tested fuses AF1-AF20 (esp AF9 & AF15 instrument panel fuses), no fuse burnt.
    c) Opened RHS behind passenger compartment, tested fuses PDF1-PDF26, no fuse burnt.
    d) Opened LHS behind passenger compartment, tested fuses PSF1-PSF32, no fuse burnt.
    e) Unplugged the RHS fuel pump connector cable, checked the voltage, it read 10.6V, & so was the LHS fuel pump. There is power on both pumps.
    f) Took out the plug coil & test spark plug on engine grill while cranking, saw the sparks at iridium laser tip.
    Now i'm scratching my head, staring at my F430, weeping at her & asking, why now after 9 months sleep, this time she just won't wake up, unlike before...
    Did anybody experienced this kind of symptom b4? Appreciate ur kind supports & assistance...
  8. catdog
    catdog Formula Junior
    Aug 18, 2010
    258
    any mice in the garage? maybe chewed through some wires
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,703
    Central NJ
    Dominick
    So you proved fuel and spark already ?
  10. Qavion
    13,938
    Ian Riddell
    Did some/all of your instruments come alive again? How did you know what gear you were in? (by feel?)
    Perhaps the immobiliser experts can tell us if the ECUs need to be unlocked for spark to occur (or does the immobiliser only affect the fuel system?)
    strife_wy likes this.
  11. Amber Cooper
    Amber Cooper Rookie
    Jan 19, 2019
    13
    AmberCooper777
    Thought about that too. Opened the engine bay, using a torch light saw all wires good. No cut, nor chewing gum
  12. Amber Cooper
    Amber Cooper Rookie
    Jan 19, 2019
    13
    AmberCooper777
    Indeed yes....pulled out 1 coil & touched end of the plug very near to engine grill, saw the sparks light up.
  13. Amber Cooper
    Amber Cooper Rookie
    Jan 19, 2019
    13
    AmberCooper777
    Yes, by feel. While driving I pressed the throttle pedal, can hear shift up 1st & 2nd gear only, then it roars out. After immediately engage to neutral, then i can paddle up to 3rd gear. The same step i repeat for 4th, 5th gear onward.
  14. Qavion
    13,938
    Ian Riddell
    I seem to recall that some F1 systems need vehicle speed data to go above 2nd gear. Just wondering if this logic can be fooled by going back to neutral first? Maybe your jump start fried all the speed circuits (dash/Motronic ECUs/ABS computer).
    Do you have a OBD scanner? If you can interrogate the engine ECUs, perhaps this will tell you if your immobiliser is preventing the engine running.
  15. Amber Cooper
    Amber Cooper Rookie
    Jan 19, 2019
    13
    AmberCooper777
    I didn't have an OBD scanner, but a mechanic nearby my town has it. I'll ask him to run a diagnostic to see the fault error soon.
    Any recommendation of good OBD model to buy, with reset, reflash factory settings/configuration capabilities (in case a good model exists)?
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,703
    Central NJ
    Dominick
    Thinkdiag
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,703
    Central NJ
    Dominick
    Trev @360trev
    How does.my theory stand up ..the battery in the immo /alarm unit has been depleted since the main battery was not there and now the immo is not working ..
    Does that make any sense
    I heard if you leave the key on the on position for 2 hours it will charge the battery in the immo unit and you will be good ..any clue if that makes senses
  18. Qavion
    13,938
    Ian Riddell
    Are there batteries in the immo and alarm units? Or do you mean the one in the siren?
    If you leave the key in the on position with the car on a trickle charger, won't the main battery discharge faster than it will recharge? You'd be running all your computers, instruments, etc. I thought trickle chargers only supplied a few hundred milliamps.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,703
    Central NJ
    Dominick
    Ian
    I am on the "move" and probably should have done more research before posting .. but my memory remembers something about the siren battery dying since no main battery to power the alarm system and then once dead you have a padlock on instrument panel. I further remember to "charge" up that battery was to leave main system in "on" position so that the siren battery gets juice and you would be able to start car. Again this is all from my memory and I don't have ( at this moment ) time to search for that post. I was hoping Trev would remember more
    Qavion likes this.
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Then stick a 4 amp old style charger on the terminals behind the passenger seat, when you have volt problems a trickle charger is as much use as a wooden leg at an ass kicking championship.
    You mention 10.2 volts at the fuel pump, if the pump has 2 speeds does it have 2 sets of windings or 2 speeds due to the supplied volts. I am thinking 10.2 seems a bit low if low and high speed windings.
    You can buy a voltmeter that plugs into the power socket between the seats, gives an LED readout and very handy to see what is going on, only a few dollars from Amazon.
    With all the lying around the car has had you might want to think about draining the fuel tanks, you have sparks so it should fire.
    Qavion likes this.
