Crank Sensor issue | FerrariChat
Crank Sensor issue
Discussion in '612/599' started by Justin Hughes, Aug 26, 2022.
  1. Justin Hughes
    Justin Hughes Karting
    188
    Oxfordshire - UK
    Hughesie
    So, after a recent charity day at Goodwood I had a gearbox issue and a dash full of errors, limped the car home and had it sent to my local indie who has diagnosed a £25 quid sensor issue which was cracked (from age) and due to the heat was causing the other issues.
    Car is in for a new sensor and whilst in is have a few other sensors replaced for good measure whilst the top of the engine is off and a small gasket leak on the heads a know issue as TADTS (they all do that sir)
    My car has done just over 70k miles now and due to some (mild) coking in the ports it having a decoke and injectors cleaned as well so should be fighting fit for another 70k !
    Hughesie
    599_GTO, Skidkid and Maranello993 like this.
  2. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    What kind of dash lights were you getting?
  3. George Vosburgh
    George Vosburgh F1 Rookie
    BRAVO on the 70K!
  4. Justin Hughes
    188
    Oxfordshire - UK
    Hughesie
    Transmission Failure, Mannetino Failure, CST Failure, Check Engine.
    Qavion likes this.
