crank trigger ignition system | FerrariChat
Discussion in '206/246' started by omgjon, May 21, 2016.
  1. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Has anyone installed a crank trigger ignition system on their Dino? If so what kind did you use and are you happy with. On the 206 sp Im doing the distributor will not fit, so I want to eliminate the distributor and go with a crank trigger system. The engine I'm using is a 2 litre Fiat Dino Motor.
  2. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    #2 Nickrry, May 24, 2016
    yes I have been there - the trigger wheel just clamps on the crank pulley and for the rest I used standard ford bits and a few brackets. a transformation, more torque - it was about 30%up at the bottom end from memory - 160 to 177 bhp when the engine was standard and much more economy. It also starts when its hot. The distributor drive isn't even connected - well worth it
  3. racerboy9
    racerboy9 F1 Rookie
    2,650
    Where do the spark plug wires go if not coming from the distributor?
  4. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    from a ford v6 coil pack tucked behind the oil/ water heat exchanger, then routed through the caps of the distributor and to the plugs so it all looks perfectly standard.
  5. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    More photos would be great! :)
  6. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    #6 Nickrry, Jun 6, 2016
  7. swift53
    swift53 F1 Veteran
    8,331
    E.S.
    Alberto
    Nick, Thank you kindly for the most detailed information.
    Regards, Alberto
