Crankcase leak | FerrariChat
Crankcase leak
Discussion in '348/355' started by Pengster355, Apr 27, 2019.
  1. Pengster355
    Pengster355 Formula Junior
    Mar 9, 2006
    269
    Singapore
    Oil leak at crank case.
    On Friday, my car died in the middle of the road after 5 mins from the house. Cranked but couldn’t get it going.
    Long story short, turned out that there is oil leak spilled to sensors and it couldn’t read properly. Hopefully there is nothing more than just oil leak and seal change.
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    Good find, Pengster.
    I'll add that to my bizzare-causes-for-failures list. :cool:
    Pengster355 likes this.
  3. Qavion
    14,312
    Ian Riddell
    Do you know if it was oil dripping on the sensor head, or was oil getting into the plugs? I see your upper sensor (right bank) connector rubber boot is split. i.e. on the car side of the connector.
    The sensor position on the 2.7 car is an endless source of confusion. The lower one is for the left bank. The upper one, on the left hand side of the engine (as viewed from the rear of the car), is for the right bank.
  4. Pengster355
    Mar 9, 2006
    269
    Singapore
    I don’t know just as yet as my Mechanic will start working on it tomorrow, will keep you posted.
  5. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    #5 Jackie and bill, Apr 28, 2019
    The sensors in the picture are crank sensors, not "cam" as wrote onto the picture. The camshaft sensor is a single one thats on the R/H head in the 1 o clock position from the oil filter.
    On quite a few crank sensors that i have seen have some kind of oil residue on them. After all there tucked away, especially the one positioned at 9 o'clock of the crank pulley.
    If there is a problem with the car not starting , and its been diagnosed to be with one of the two crankshaft sensors. I would say its not because its got oil on it, but its a dying sensor. There not hard to replace, just remember to look out for the spacer shim behind them.
    Please let us know the out come.
    I do hope its not such a bad oil leak thats coming from the crank seal, i hope its not :(. This is not an easy job due to the pulley can not be removed with out either moving tbe engine back or engine removal. So fingers crossed its a faulty sensor or upper cam seal.
    All the above is just my opinion og course.
    Qavion likes this.
  6. F355Bob
    F355Bob Formula 3
    I had same problem years ago from a bad Gary Sharpe engine rebuild. Had a bad oil leak that leaked onto one of my crank sensors and car would only run on 4 cylinders. Leak was cam seal and crank seal.
    WATSON and Pengster355 like this.
  7. Qavion
    14,312
    Ian Riddell
    Moderator! Unfortunately, I haven't figured out how to delete photos in my posts. The irony is that I labelled the photo "crank sensors.jpg" on my desktop.
    ernie and Pengster355 like this.
  8. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Mate i was fully aware that you knew your mistake because i read your posts and know you know what you are talking about. I only corrected the mistake for the original poster to save confusion.
    Pengster355 and Qavion like this.
  9. Pengster355
    Mar 9, 2006
    269
    Singapore
    Unfortunately the engine had to come out . The 2 crank sensors are literally brand new as We just changed them when I did clutch changes.
    Will keep you posted
    Qavion likes this.
  10. AuthenticRebuilds
    Feb 5, 2019
    93
    david
    in the industrial world ive seen oil seep into sensors with no effect, then ive seen them fail in the same situations.
  11. Qavion
    14,312
    Ian Riddell
    Those sensors seem to be hermetically sealed. I'd be more inclined to think that the connector plugs below the sensors were contaminated. Or can the sheer volume of oil on the sensor heads affect the inductance?
  12. AuthenticRebuilds
    Feb 5, 2019
    93
    david
    I had an oil leak on a mercedes drip oil onto the O2 sensor plug and it started giving all kinds of goofy lambda readings causing a cel light. after some contact cleaner it was fine. Oil and electricity can be strange, ive seen reducers at work leak oil and soak a motor and it will run another 5 years but get that crap on the wrong connection and poof no workie. It could be the type of oil to though.
