Cranking Old Man | FerrariChat
Cranking Old Man
Discussion in 'Aviation Chat' started by SWITCHESOFF, Feb 24, 2007.
  1. SWITCHESOFF
    SWITCHESOFF Formula Junior
    Nov 9, 2005
    582
    After reading the AOG thread and how it digressed into hand propping airplanes, I just had to go back several years to when I started flying, or at least hanging around airports. All the airplanes were hand propped to start and it really wasn't a big thing. As Paul said, when the" propper" technique is used it is safe and can become routine. I grew up with hand-propping airplanes and have propped everything you can think of including an AT-6, winning a 10 dollar bet that I couldn't do it. All of the light planes that you have ever heard of and some that you haven't heard of, I have hand propped. Stearman PT-13,17; Fairchild PT-19,&PT-23, Ryan PT-22, Travelaire 4000, Waco ATO, CSO, UPF-7, Ryan ST, Sopwith Pup, Neiuport 17, Avro 504K, and many more. The hardest, of course, was the AT-6, the most dangerous was the Avro 504 because it was rotary powered and had a bird cage of struts and wires that braced the nose-over skids in front of the prop , which was huge and heavy. After starting, you had to do a carefully rehearsed dance to get back from the prop.Hand cranking a modern 6 can be troublesome because the nose on the trike geared planes is so low but it you get the blade in postion on a compression stroke and use the right moves, you can do a hand strat just fine.
    Switches
  2. imported_Rudy
    imported_Rudy Rookie
    Nov 18, 2006
    41
    There was a time that cars were hand cranked to start as well. I don't hand crank my car and I don't see the need to hand crank a plane either.
    If it's something that you enjoy, then have at it. It's not for me.
    Rudy
  3. planeflyr
    planeflyr Karting
    May 27, 2006
    174
    Have you ever needed to "pop" the clutch to start a car with a dead battery (as long as it had a manual transmission)?
    These are survival skills.
    Planeflyr
  4. IFLYDC104U
    IFLYDC104U Rookie
    Aug 7, 2005
    19
    I can appreciate your experience, knowledge and info. You and my father would get along just fine. I learned the same things u did hanging around the airport. Most of the current generation cant appreciate these things and want to learn only a GPS instead of paying their dues and learning pilotage, dead reckoning, VOR & ADF naviagation.
    Thanks for sharing.
    It sure beats being stuck somewhere that is for sure. I have had my fair share of students thank me for teaching them the merits of handpropping after they became owners and instructors themselves and had to handrop a plane to get home for one reason or another.
    Paul
  5. IFLYDC104U
    IFLYDC104U Rookie
    Aug 7, 2005
    19
    Well said!
    Kinda hard for a pre-solo candidate to understand the intent of the discussion. I never got any pleasure out of hand-propping an airplane that is for sure. But it sure beat walking.
  6. SWITCHESOFF
    Nov 9, 2005
    582
    I can understand someone not wanting to hand-prop an airplane. The propeller can be deadly if it isn't addressed correctly. I grew up with it and was trained in the procedure and gave it little thought other than the satisfaction of getting the correct prime, swinging through the adequate number of blades, setting the prop at a compression stroke , and having the engine kick over and start when you pulled it through. I have to admit that I'm an anachronism, a dinosaur now and I don't know anything about the new fancy nav stuff but I have great memories AND I can still fly .....not as coordinated as I once was but I can still get the job done with the ball centered. I flew for the joy of it; cloth, wires, wind, sectionals, a compass, and nothing beyond that.
    Switches
  7. imported_Rudy
    Nov 18, 2006
    41
    Yes I have, but as I have not owned a manual tran car in 20 years, not very helpful now.
    There was also a time when rebuilding an engine in a car we did not have access to a lift, so we just removed all the fenders and what not till we have the front of the car down to the engine on the frame.
  8. planeflyr
    planeflyr Karting
    May 27, 2006
    174
    I think the point of this discussion is to make the distinction whether "to prop or not to prop". Certainly with a "modern" aircraft (sorry Switches ;) ) with electrical systems, a starter, and presumably a good battery, this technique is becoming a lost skill.
    I believe that every pilot should be taught the proper way to hand-prop an airplane because some day, somewhere, far from your home base you will return to the FBO after closing time and find that you *gasp* left the master switch on. Or you over (or under) primed the airplane, or a vapor lock hot start (fuel injected) or non-vapor in cold weather (carbureted) caused you to run the battery down, or the battery was on its last legs already. You all get the idea. It would be far, far better to know the way to properly and safely hand-prop an aircraft rather than trying to do it from just knowing that it can be done and risk an accident or tragedy or both.
    The divergence here I'd like to bring up is actually the opposite of propping the airplane to affect a start but the task of "pulling the propeller through" during the pre-flight. This is also something which is not taught by most instructors due to the obvious safety implications and more likely due to the instructors themselves not knowing the proper and safe way to do this. I was always taught to do this as part of the pre-flight (and yes, I was also taught how to hand prop start an airplane) by my primary instructor and we would practice these skills on a periodic basis. The reasons for pulling the prop through were to 1) loosen any thick oil in cold weather, 2) check for weak compression on any of the cylinders, 3) listen for any unusual noises, and 4) feel for anything unusual which might indicate an internal engine problem.
    I have done so religiously, and without exception, for my entire flying career.
    It was numbers 3 and 4 which saved my bacon one day too!
    In 13 years of flying (at the time) I had never experienced a concern. Then one morning, returning from Tucson a day after transporting a co-worker, his wife, and his infant son there for a visit with the in-laws, as I was pulling the prop through I reached a point where IT DIDN'T! I gave a hard yank and it went "clank-clink-clunk". Oh, S**T said I. I came around a second time with the same result.
    Here is where the renter and the owner's thoughts differ. The renter will immediately say "What's wrong" while the owner will immediately say "How much!"
    I knew I had either a $1500.00 problem (cylinder, valve, etc.) or a $15,000.00 problem (engine). It turned out to be the latter. Upon removing the oil filter it was caked with aluminum and in the oil screen was a chunk of aluminum the size of my thumb.
    The really scary part of this is that the engine would have started up and run normally, while it was continuing to tear itself apart. If I would not have pulled the prop through and started and taken off, the best thing which could have happened is that the engine would have quit on the runway. In the more likely worse case I would have found myself wandering around the desert looking for a pay phone. It certainly wasn't going to make it back to Denver.
    The engine was trashed internally and required an overhaul including case welding.
    So for in the "what its worth" category I continue to recommend learning how to, and then performing a pull-through EVERY FLIGHT.
    Planeflyr
  9. SWITCHESOFF
    Nov 9, 2005
    582
    I heartily agree with you , Corey. The key is to make damn sure the ignition is OFF first. Treat the prop as HOT and use safe technique in pulling the prop through as though you think that it is going to kick over in a start. A hot engine can sometmes pop a blade or two around if you give a little push. And listening as you pull the prop through can save you an embarassing off airport landing if you hear a hissing out of the exhaust valve instead of a " phunk"- like sound. To hear metal grinding and rattling.......
    Switches
  10. IFLYDC104U
    IFLYDC104U Rookie
    Aug 7, 2005
    19
    Great Post!
    I agree wholeheartedly. You had a great primary instructor and it will follow you your whole flying career.
    I recently took my 17 year old nephew to a flight school to get his first intro flight out of North Las Vegas airport. I wanted to take him up my self but the flight school wanted a two hour checkout with one of their 250 hour 22 year old instructors. I chose to have my nephew go up with the instructor.
    The instructor never came close to the prop on their preflight. I was shocked at his answer when i queeried him on this? He told us that "the flight school teaches us to tell our students to never touch or move the prop" I was shocked!
    I pulled my nephew aside and told him a few things about propellers and that it is perfectly safe to move the prop and that it should be done on every preflight for the reasons you mentioned in your post.
    I queered the instructor about his knowlede on propellers and it was obvious that he knew nothing about magnetos, p-leads or how to properly preflight an airplane.
    He even went as far as to say if the "master swithch is off the engine will never fire!"
    It is sad that people are paying $145 an hour of dual for this type of instruction.
    Paul
  11. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,946
    Southlake, TX
    Rob Lay
    I can't hang with this conversation related to planes, but have plenty of experience with cars.
    Funniest is a new race car we built. It wouldn't start, so we went to a push start. Well, every time I let off the clutch it would lock the rear wheels and not start. We gave up after several trys. When working on the car we had used the wrong bolt on the clutch cylinder and it was too long pinning the flywheel. :)
    In the current RX8 I try not to touch the brakes on the cool down lap all the way to stopping in the pits so I don't crack the rotors with difference in cooling temps between rotor and pads. My technique is to turn the car off as coasting into pits and brake with the engine. Darn thing is so hot and without spark still will turn over a little. :eek:
