Crankshaft damper pulley fell apart | FerrariChat
Discussion in '456/550/575' started by Bahaba0, Mar 25, 2013.
  1. Bahaba0
    Bahaba0 Karting
    Feb 4, 2010
    125
    Miami, Fl
    David Stone
    After a long run as I was pulling into my garage I heard a bad engine npise and the check engine and slow down light came on. The cause- the crankshaft damper pulley fell apart. Is this a commpn 550 problem?
  2. tazandjan
    39,176
    David- Have never heard of that on any of the 65 deg V12s, but maybe one of our pros has heard about it. Any other damage?
    Bad luck.
  3. Bahaba0
    Bahaba0 Karting
    Feb 4, 2010
    125
    Miami, Fl
    David Stone
    dont know yet car at dealer
  4. JoshECS
    JoshECS Formula Junior
    433
    Ashburn,VA
    Josh Hill
    I personally have only come across this a couple times in various models. Not the sort of problem we advise people to be wary of. I'm sure there are extenuating circumstances that led to this failure.
  5. bay
    bay Formula 3
    Mar 13, 2011
    1,274
    Belgium
    Bernard
  6. mcypert
    mcypert Formula Junior
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    David:
    Don't know about our V-12's, but had one fail on an older Mazda V-6. Like yours, it just fell off in the driveway. Shouldn't do any damage at those speeds, except maybe new serpentine belt. I think they just wear out with age and heat.
    Regards.... Mark in Houston
  7. Rifledriver
    37,105
    Someone here had it happen a few years ago. I have seen it in older cars but not something as new as a 550.
    It seems like it wasnt a great idea to have the inertia ring drive the accessory belts. Usually the belts are driven by the part mounted to the crank, not the rubber.
  8. Strictly Ferrari
    Strictly Ferrari Formula Junior
    637
    3045 Davis Blvd.
    Naples Classic Car
    Can you post a picture of the damper/pulley .
  9. Cribbj
    Cribbj Formula 3
    Within the last year we've had 5-6 456/550/575 owners documenting their torsional dampers coming apart:
    Luis..........2000 456M........45,000km
    Romain......???? 456
    Laurent.....????
    JLuce.......???? 575
    Ian..........1999 550...........24,000mi
    David.......2000 550
    Not counting those the pros have seen.
    So what can be done to detect a failing damper before it lets go and wipes out some other expensive bits? I shudder to think about the consequences of one failing at redline.......
    According to LuK who are one of the largest manufacturers of dampners and dual mass flywheels for the OEM's, the dampner should be visually inspected off the car for any signs of rubber degradation, then grasping the outer hub, try to turn it while holding the inner. Any sign of movement is an indication of a problem.
    John Deere recommend the same, and go on to say that the radial runout of their dampner should be checked, and if over 1.5mm, it should be replaced. This is 1.5mm on a much larger damper than on our V12's, however.
    I also wonder if putting a timing light or a strobe on the dampner and checking for jitter would be useful?
    Any pro's opinions on how to detect a failing damper?
  10. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I just completed a major service on my 550M. I inspected the damper very carefully...and she looked perfect at 13 years old/11,000 miles. Speaking of crank dampers coming apart, I've got one here off of a bb where the rubber (appears) to have seen better days. Anyone know of a rebuilder?
  11. Rifledriver
    37,105
    I know this is on the other side of the country but I have used him for vintage V12 dampers and he was very good.
    Damper Doctor 530-246-2984 1055 Parkview Ave. Redding Ca.96001
  12. windsock
    windsock Formula 3
    1,153
    This is very common on the 456/550 and we are starting to see it on the new models as well. We pay very particular attention to them during inspections as the generally walk backwards and take out the timing belts and drive pullys.
  13. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Perfect. Thank you.
  14. tazandjan
    39,176
    John- More of them failing than I thought. At $752 from Ricambi for a 575M, kind of an expensive preemptive replacement, though.
  15. chrismic
    chrismic Formula Junior
    Jan 7, 2012
    272
    #15 chrismic, Mar 26, 2013
    After reading a few stories, including Luis', I had the damper pulley replaced during a recent belt change on my 456M even though it looked fine...345 Euros for the part
  16. Bahaba0
    Bahaba0 Karting
    Feb 4, 2010
    125
    Miami, Fl
    David Stone
    Got the car back. The rubber ring in the pulley wore badly and separated causing the failure. Nothing else damaged except my wallet - $1600 ($752 for crank shaft pulley). I urge 550/575 owners to visually inspect for failure as I don't want to imagine what would happen if it let go at high speed. A quick look with a good flashlight can tell if the edge of the rubber ring is corroding and needs to be replaced. Car drives fine now. I had no prior warningl of the failure except check engine light came on just before the failure. No prior noise, vibration, etc.
  17. lsgv
    lsgv Rookie
    Nov 1, 2010
    47
    Belgium
    Luis Gaivao
    Happy my bad luck served you. Mine cost me 1.200€ for the flatbed transport, plus another 1.100€ for the repair as covers and pulleys had to be replaced too. Luis
  18. tazandjan
    39,176
    David- Happy no further damage was done.
  19. Bahaba0
    Bahaba0 Karting
    Feb 4, 2010
    125
    Miami, Fl
    David Stone
    Pully Fix is great.Also replaced both cat ecus. Took a long run to Key Largo.she runs great. Life is good
  20. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    The one on my BB512 was in very bad shape. The part is NLA nowadays, so I had my tired old one refurbished by these guys:
    harmonic balancers
  21. SCantera
    SCantera F1 Veteran
    5,835
    Living Falls NC
    I had it happen to a 2000 550 I had a few years back. Just had the major service done only to hear that awful noise and rubber from a shaved belt on the floor. I think the car was 6 years old at the time.
  22. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    #22 wbklink, Apr 7, 2013
  23. bay
    bay Formula 3
    Mar 13, 2011
    1,274
    Belgium
    Bernard
    Yes , Ferrari référence 168565
  24. chrismic
    Jan 7, 2012
    272
    Scantera and everyone: have we established whether it was quality problem of a certain badge of pulleys, or whether the origine of the problem is to be found elsewhere (or simply worn out pulley?)A number of guys, both 456 and 550, seem to have had the problem occuring shortly after belts change.
    Chris
  25. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Thanks Bernard !
    cheers,
    Bill
