Crankshaft pulley bolt | FerrariChat
Discussion in '308/328' started by pedders, Oct 28, 2022.
  1. pedders
    pedders Karting
    Apr 25, 2010
    69
    Hi all,
    When removing the crank pulley bolt (using an impact driver), is it necessary to lock the flywheel?
    It seems to me like you would have to (especially when tightening back up with a torque wrench), but some of the other posts on this subject don’t mention it, and I am a little apprehensive about how to lock the flywheel without risk of damage to the starter ring teeth - I can’t see how a more traditional locking tool could fit with the engine in the car (and still attached to the gearbox).
    The car is a 1979 308 GTB.
    Many thanks.
  2. absostone
    absostone F1 World Champ
    10,025
    My guess would be car in reverse and e brake on. IMO
  3. pedders
    pedders Karting
    Apr 25, 2010
    69
    Was thinking along similar lines but 5th gear - thank you.
  4. absostone
    10,025
    Or that you can also put a screwdriver in the brake rotor slot
    pedders likes this.
  5. absostone
    10,025
    Actually 5 th is best. I’m still sleeping.
    pedders likes this.
  6. pedders
    pedders Karting
    Apr 25, 2010
    69
    Thanks again - I’d rather do this than try and get something on the ring gear.
    absostone likes this.
  7. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Agreed - though never on a Ferrari, I've removed a LOT of crank bolts... never locked the flywheel down.
  8. Steve Magnusson
    26,790
    Using an impact gun = typically not necessary to lock the crankshaft rotation somehow as the inertia/friction of the rotating assembly is enough to prevent things from moving before the crank bolt threads release.
    Using a manual braker bar = in a high gear and e-brake "on" is usually enough, but adding screwdrivers in the rear brake disk edge vents, as absostone suggested, is the next level.
    grtoz, thorn, pedders and 1 other person like this.
  9. pedders
    pedders Karting
    Apr 25, 2010
    69
    Thank you everyone - much appreciated.
