crankshaft | FerrariChat
crankshaft
Discussion in '308/328' started by mgclinard, Dec 27, 2014.
  1. mgclinard
    mgclinard Rookie
    Nov 5, 2014
    27
    Waterford VA
    Mark Clinard
    will a 328 crankshaft fit a carb-308 engine?
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,848
    Atlanta
    John!
    Yes but the pistons must be replaced with the pin location being altered to accommodate for the additional stroke.
  3. Albert-LP
    Albert-LP F1 Veteran
    8,171
    around Modena, Italy
    Alberto Mantovani
    #3 Albert-LP, Dec 28, 2014
    i didn't know there was that possibility, and I'm still a bit skeptical. And at BDC, what will happen?
    ciao
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Not only is that possible but the same can be done with a 360 crank.
  5. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    Does the 3.2 crank need machining like the 3.6 crank?
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I believe it may be a simpler swap then the 360 which requires a little machining on the end.
