Crash Test - '59 Bel Air vs '09 Malibu | FerrariChat
Discussion in 'General Automotive Discussion' started by RacerX_GTO, Sep 23, 2009.
  1. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,764
    Oregon
    Gabe V.
  2. anunakki
    anunakki Seven Time F1 World Champ
    78,999
    Las Vegas Nevada
    Jerry
    Doesnt surprise me at all
  3. GuyIncognito
    99,962
    Once again, the car I'd want to crash in isn't the car I'd want to drive
  4. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Amazing how well that Malibu holds up.
  5. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    I was thinking about this little crash... Of course the new car is MUCH safer than the old one, but I think the test might be a bit misleading. In 1959 seat belts were not required, and it seems they ran this test so unequipped. I wonder how much difference seat belts in the '59 would have made?
    Shiny Side Up!
    Bill
  6. NWaterfall
    NWaterfall Formula Junior
    Aug 2, 2009
    564
    The Track
    Waterfall
    Which one do you think weighs more??? :D
  7. Protouring442
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Might surprise you... Yes the '59 is heavier with a shipping weight of 3,625lbs, but not by much. The Malibu's advertised weight is 3,415lbs.
    Shiny Side Up!
    Bill
  8. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    As with most of the tests carried out by the IIHS, this one was specifically designed to help increase regulation of the industry. It doesn't necessarily reflect the real world.
    Remember that the IIHS is a front group for the insurance industry and they are out to show how the crash requirements that they have foisted on us over the years have made things a lot better.
    The impact location in this test was SPECIFICALLY designed to miss the main frame rail of the 59. Most of the front impact strength in that design was due to the frame rail. If the impact had been a foot closer the center the old car would likely have aquitted itself a lot better. But showing a that wouldn't help them increase regulation, so they did the test that gave them the maximum results. This is about as valid as hitting a Model A in the door with a semi, yes, everybody is dead, so what's the point?
    I'm not saying that the new car isn't a lot safer, but that in this test they specifically crashed the two cars in a manner that was intended to inflict damage where the old car had no structure. If it was a more simple head on impact the results would have been a lot more similar.
    Just remember, when you watch anything the IIHS does, it is being done to forward their agenda, which is to pay out less while raking in more money.
  9. Buzz48317
    Buzz48317 F1 Rookie
    Dec 5, 2005
    2,862
    Shelby Twp., MI
    Michael
    I am betting that the difference would be death at the ER vs death on the roadside. Remember that in 1959 seatbelts were nothing more than lap belts and the occupants would have still been bouncing off everything inside of that car.
  10. Protouring442
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Absolutely true. I should have said that I wonder what difference a set of 3 point seat belts would make.
    Shiny Side Up!
    Bill
  11. jefffromcanada
    jefffromcanada Formula 3
    1,205
    Alberta
    I can't tell 100% but it seems to me that there is no engine in the 59.
  12. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    There is.
  13. Etcetera
    Etcetera Two Time F1 World Champ
    24,042
    C6H14O5
    3 point belts would have kept occupant centered better for more complete eating of steering wheel and dash.
  14. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    This is why my standard answer in my F-328 "how fast have you gone?" is usually
    something like "... well, pretty much the speed limit - maybe a bit more".
    If I want to take chances, I'll do it in the E350 with 900 airbags, crumple zones,
    and the thingy that automatically calls the ambulance and sends the coordinates
    of the tree I just killed.
    Jedi
  15. TcpSec
    TcpSec Formula Junior
    Feb 8, 2004
    453
    LA, USA
    Zeno S Paradox
    Only car you will crash in is the car you will drive. Did that occur to you, Sir?
  16. Cozmic_Kid
    Cozmic_Kid F1 Veteran
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    Yep, why else would they make such a test, if it was flawed from the beginning.
  17. Etcetera
    24,042
    C6H14O5
    Passengers do not get in car crashes?
    Did that not occur to you?
  18. 1ual777
    1ual777 F1 Rookie
    Mar 21, 2006
    2,948
    Orange County, CA
    First comment says there isn't and the hit the 59 at the weakest point. Which is it?
  19. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    According to another board I'm on there was an engine. A straight 6. It was confirmed by GM press.
  20. GuyIncognito
    99,962
    whenever I see an imminent crash, I stop, get out, and get into a more crash-worthy car.
  21. Etcetera
    24,042
    C6H14O5
    This is a wise course of action.
  22. Reddol
    Reddol Karting
    Jun 10, 2007
    231
    Italy
    I don't know how it works in the US but it's a standard thing in Europe to do the test with an offset impact, since this type of crash happens more often than that with the two cars completely in line.
  23. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Wow, that was A LOT of damage to the '59... more than I would have guessed.
    Mike in Kuwait
  24. TcpSec
    Feb 8, 2004
    453
    LA, USA
    Zeno S Paradox
    Touche!
  25. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    this diff was a staged crash to show how a new car takes a crash better then a 50 year old one,i would have liked to see a real head-on crash,not one were they missed the frame rail
