Crazy 360 Spyder wreck | FerrariChat
Discussion in '360/430' started by SouthernThunder, Feb 7, 2011.
  1. SouthernThunder
    SouthernThunder Karting
    May 23, 2009
    169
    Dallas
  2. djastral69
    djastral69 Formula 3 Silver Subscribed
    Aug 6, 2007
    1,896
    Fl
    David
    That is probably the nastiest wreck that I've ever seen! where was this unfortunate accident?
  3. JS NZ
    JS NZ Formula Junior
    Sep 24, 2010
    305
    Auckland, NZ
    Looked very survivable though, rear end hit the trees, capsule ok, then a fire
  4. Chiaroman
    Chiaroman Formula 3 Rossa Subscribed
    Apr 21, 2004
    1,687
    New Jersey
    But what is that in the road???
  5. SrfCity
    SrfCity F1 World Champ
    Nov 1, 2003
    10,142
    Orange County, CA
    People don't realize how squirrely a 360 can get if you're pushing it especially on a slick road. Plus you've got about a 60% chance it's going up in flames if you hit something. Hope they got out. It's always assumed to be the driver's fault but not when you see so many spinning out of control then bursting into flames.
  6. SrfCity
    Nov 1, 2003
    10,142
    Orange County, CA
    Good question. I'd say it's a piece that flew off when it exploded into flames upon impact into the trees. If so, the occupants didn't have a chance.
  7. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    Every time I really got into my 360, just having fun, I'd get to the ragged edge and could feel the thing wanting to break loose. Much, much happier in a 430.
  8. Periokid
    Periokid Karting
    Oct 19, 2004
    235
    LI, NY
    David
    That sends chills up my spine.
  9. TheMayor
    TheMayor Ten Time F1 World Champ Rossa Subscribed
    Feb 11, 2008
    106,184
    Vegas baby
    This is on Wrecked Exotics. It says two people were injured. It happened in the Netherlands.
    I think this is survivable if you can get out before the fire engulfed the car. Certainly looks terrible though.
  10. hangarsixco
    hangarsixco Formula Junior
    Oct 10, 2010
    396
    S. California
    Chris
    The first picture was the wheel broken into bits and the tire rubber is melted, it looks like you can see the steel belt from where the rubber melted or that may be the lip of the rim. You can also make out a few spokes of the rim.
    Terrible accident, makes me think twice when hitting speed.
  11. TroyI
    TroyI Karting
    Mar 18, 2010
    80
    Las Vegas
    Troy Isaacson
    What makes the 360 so prone to going up in flames?
  12. TheMayor
    Feb 11, 2008
    106,184
    Vegas baby
    When you hit so hard that you rip the engine out of the car, wouldn't say fire is unexpected, not matter what car you're driving.
  13. HH11
    HH11 F1 Rookie Rossa Subscribed
    Sep 4, 2010
    3,344
    I sure hope the passengers are ok. From the looks of that crash I would venture to say they may be in pretty bad shape. Just a reminder of how we need to respect the machine.
  14. Piper
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    Yeah, cracks me up when I'm talking to the sales guys, Maserati mostly, about safety and they stress that their approach is centered around collision avoidance.
  15. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    Rear saddle fuel tanks, there are two one on the driver’s side and one on the passenger side with a bypass between them as well as the fuel feed lines. When you have a violent crash and these components are separated you have excessive fuel leaks add high exhaust and engine temps and you get a fire. Front engine cars have the obvious engine in the front fuel tanks in the rear, while fires can and do happen you are less likely to have one in a standard vehicle, unless it's a violent crash where you seperate fuel lines. Fires suck! I’ve seen cars burn to the ground on the Dyno due to AN fittings & braided fuel lines improperly installed and it’s bad!!! Always have a properly regulated extinguisher with you or around you if possible.
    I pray these people are ok to live and drive another day.
  16. SrfCity
    Nov 1, 2003
    10,142
    Orange County, CA
    The hot cats are under the engine. Any kind of fuel compromise and spill onto the cats sends it up. Porsche has the cats off to the sides and Mercedes for example use expensive titanium to cool the cats. F do neither that's why you see so many catching fire.
  17. SrfCity
    Nov 1, 2003
    10,142
    Orange County, CA
    It's to a point where the 360 handling is flawed and it wasn't until the 430 that they improved the serious over steer. Most wrecks you see in 360's are due to over steer that becomes almost impossible to correct once it goes to far.
  18. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Seriously sad for the occupants and car. Makes me think that the Capristo heat wraps are a good idea for every 360/430. What changes did they make to the 430 that reduced the terminal oversteer? Certainly will make me think twice about any mod that would dial out understeer.
  19. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Wow! Hope all involved are ok!
  20. Tarek K.
    Tarek K. F1 World Champ Rossa Subscribed
    Sep 7, 2006
    10,798
    Cairo - Egypt
    Tarek K.
    Wow........terrible accident.
    One of the wheels, you can still distinguish the spokes.
  21. rmani
    rmani F1 Veteran Owner Silver Subscribed
    Nov 1, 2003
    7,334
    NJ
    RMani
    Hope the occupants survived and are ok. Ouch...
  22. forgeahead
    forgeahead F1 Rookie Owner
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    I got my 360 spider after having a 997TT. Needless to say, transitioning from all wheel drive to a mid engine rear wheel drive was an eye-opener. Stupidly, one morning I tried to drift through a turn and was rudely made aware of the tendency to "oversteer." 360 in a 360! Fortunately, I stayed on the road and away from anything else. One of those lessons learned! I had great respect for that car following that!
  23. Juston51ATL
    Juston51ATL Karting
    Feb 4, 2011
    67
    Cartersvile, GA
    Juston
    WOW! Hope the passengers are ok. The car can be replaced. Worst wreck I've ever seen!
  24. pninja005
    pninja005 Formula Junior
    Nov 10, 2010
    605
    Europe
    Is the 360 that bad to drive compared to the 430?
    I thought the 360 was so much better than the 355?
