crazy headlight (problem) [355] | FerrariChat
Discussion in '348/355' started by lyrm, Jun 11, 2011.
  1. lyrm
    lyrm Karting
    Sep 9, 2008
    176
    spain
    hi
    since yesterday after clean the body, 5 minutes after the right headlight is continuous up and down all time, the left is fine, no problem, only the right, without key, with engine off and with the lights switch off
    all time, up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,up down, up , down, up down, up down, up down, up, down , up down, up down, up , down, up down, up down, up down, up, down , up down,
    and just in this up and down the engie make smoke !!! :D :D :D
    hahaahha
    the engine is ok, only small smoke but the engine yes run normal
    ok, them, I desconect 2 motors, left and right,and change the engines of side (for check diodes) and the problem continues in the same side, right side, I think the engine qand diodes not is the problem
    them I changed the realys pairs, the two lefts relays for the two right relays and the problem continues in the same side
    after I clean all conectors , the problem continues, put off the fuse box and check all conectors and clean and the problem continues but the las times that I´m check it some times the problem no exist, and some time yes, all times in the right side......
    now, for example, the problem no is in this moment, ok, I,m go and no touch the car and after 5 minutes sometimes, 20 minutes sometimes the engine start other time it self.....
    and this not is all problem , in this moment I have one new problem and is that I´m crazy too!!!!!
    somebody can help me ???
  2. lyrm
    lyrm Karting
    Sep 9, 2008
    176
    spain
    the car not have alarm
  3. lyrm
    lyrm Karting
    Sep 9, 2008
    176
    spain
  4. lyrm
    lyrm Karting
    Sep 9, 2008
    176
    spain
    if you have the same problem in your ferr, if you want check it, you need check 87a terminal in E13 relay with 86 termina relay E10 and 86 terminal relay E6 and the correct value is not OHM, if you have some ohm, 200, 300 , 1000, is that you have one bad bridge under fuse box cover, the problem started at 300 ohm about or less
