CS - central locking KO and the ever illuminated power window switches- PLZ HELP!!!!! | FerrariChat
Discussion in 'Technical Q&A' started by bikz, Aug 6, 2014.
  1. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    #1 bikz, Aug 6, 2014
    guys i have a similar thread on the 360/430 forum but thought this forum might have a wider set of readers to help....
    1) guys the first photo shows the ever illuminating lights on the power window switches! they never turn off and drain the battery ;
    2) the second photo- the orange plug which connects to the lock/unlock button- doesn't seem to operate the locking mechanism....another fchatter (driviprdds), had similar issues in his 430 whereby the plugs on his switches were plugged in the reverse...however in the CS there is only one switch and plug so doesn't look like it can be plugged in wrongly.
    3) third photo- the white plugs are connected to the power window switches (which work the power windows alright but the lights don't seem to turn off)
    my car can't seem to lock/unlock using the lock button from the middle console! nor does it lock/unlock by me using the remote control......(been doing so manually with the keys and the guys at Ferrari told me believe it or not, change the locking mechanism!!!!!!)
    i kinda had a hunch it was related with the power button switch lights not going off (because when i disconnect/reconnect the battery, the locks on both doors seem to lock and unlock a few times by itself simultaneously - even so when i pull the power window fuses and put them back on...they keep clicking "lock, unlock, lock" a few times so i knew the locking mechanism and its motors were fine).......pretty sure they're all connected but can't figure out how.... my suspicion is even strengthened by driviprdds who posted with similar symptoms but in a different car (430 which has two switches for the locking mechanism as opposed to only one in the CS)
    so anyone with any clue what could be the issue?
    thanks a lot guys for reading through the above and thanks in advance to those who might be able to help
