360 - CS Conversion & Gated Shift | Page 2 | FerrariChat
360 CS Conversion & Gated Shift
Discussion in '360/430' started by RANDY6005, Dec 9, 2020.
  1. 24000rpm
    24000rpm F1 Rookie
    the only hardware change for a Superfast II CS is the f1 actuator (or even just the teeth part of the actuator), and some additional sensor and some wiring. And maybe a transplant of the "power unit" (as decribed by ferrari) since scud's f1 pressure is a little higher than CS, I'd think.
    most of the work should be software.
    RANDY6005 likes this.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    A few months back I fixed this very gated CS conversions issues so it now drives as it should. It's owner is Khan and he's a really nice guy. He's actually on here but I don't think he comes on very often.
    If you remember back to Sam @seenthroughglass, the famous YouTube car vlogger, he drove it and felt very underwhelmed. It was because it was still running in F1 mode and running in half broken state because whoever they had got to do the ECUs didn't really know what they where doing and botched the job by turning off every single fault code! Even detonation and safety checking. Absolutely shockingly bad. The poor CS, it wasn't even running gated software so in the end all they did to hide their botches was deactivating ALL fault class codes in the ecu which is a terrible way to delete hardware! Whomever did this if your reading hang your head in shame!
    If you do it this way the software still knows about the fault present and drives much worse because of it, your just hiding the CEL. For instance if you hide the fault for say air injection without truely disabling the system your car will run super rich on cold start and no CEL will complain. Similarly same thing on cat efficiency, just deactivate the code and well your still reserving torque for various functions and deactivating fueling maps for cat protection. It's all a big mess if you don't do it as per the way Bosch calibrated things at the factory.
    So in summary while some tuners can get away with hiding CELs many, like poor Khan's car never run properly ever again and are therefore underwhelming which is a real shame.
    Thankfully all is good on his car now. My only recommendation now is to swap that center console.. Its the only thing I don't personally like now on his car, I'd have one made in CF in Same style as CS or if its too much hassle modify a 360 Challenge one to fit like what I run today... [emoji12]
    Sent from my VOG-L29 using Tapatalk
    MAD828, imahorse, ShineKen and 4 others like this.
  3. jag-oo-r
    jag-oo-r Formula Junior
    424
    Oh I'm a subscriber, for sure! haha. very nice work!
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,092
    Josh @jtcarprojects
    Well I guess I'm one step up on haveing the challenge center console on mine
  5. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Retail every part needed shift lever assembly minus number 19 plate 2400.00 from page 037 outside gearbox controls.
    Order sent should all be available.
    160480
    108010
    199070
    13895870
    159137
    174967
    180936
    176626
    176425
    176642
    182391
    181753
    115980
    177029
    177027
    172918
    181751
    172934
    219570
    brogenville and armedferret like this.
  6. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,092
    Josh @jtcarprojects
    Make me wanna order
  7. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  9. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Second order just placed .
    Clutch master ## 180841 retail cost 355.00
    gearbox control cables ## 180701 retail cost 323.00
    First invoice rounded up 2400.00
    Second invoice rounded up 700.00
    3100.00 total so far.
    brogenville likes this.
  10. ttforcefed
    ttforcefed F1 World Champ
    19,241
    Is 181751 available?
  11. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,092
    Josh @jtcarprojects
    Are you doing the work randy
  12. brogenville
    brogenville Formula 3
    2,234
    Robin
    Be interesting if it is, as it was definitely NLA for quite a while. If so, then you’d assume Ferrari have decided to make a new batch?
  13. ttforcefed
    19,241
    Yes but all the normal sources are NLA
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Yes not as if I have to fabricate any parts just remove FI system and replace with gated shift parts.
    Harder to convert a gated shift 360 to a F1 system..
    one4torque and clean512 like this.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I. clutch pedal ## 180599 HOLY GRAIL !!
    2. complete outer control ## 184022 HOLY GRAIL !!
    With just these two parts you would have it licked all down hill..
    There so much new technology parts can be made now like never before.
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Beginning CS build no CS bumpers anywhere only aftermarket or from wreck CS,s
    After years looking Neil from Eurospares calls Ferrari remaking nine sets Euro front and rear style bumpers.
    So far just in one week I have already found OEM clutch pedal and outside control unit BRAND NEW IN A BOX !! problem !! they know what they have want be cheap.
    armedferret likes this.
  17. brogenville
    2,234
    Robin
    You have done very well Randy. Guess you’re all in now too! [emoji16]
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Brogenville wished . One on ebay and one at a high in shop both out of my price range
  19. imahorse
    imahorse F1 Rookie
    4,293
    WI
    Dustin
    I'm looking forward to seeing this come to fruition.
  20. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Neil Belton
    7:50 AM (4 hours ago)
    to me
    hi Randy
    160480 £148.76 original new to order 10-14 days or £55.00 pattern copy in stock
    108010 £5.20 each in stock
    199070 £52.29 new to order
    13895870 replaced by 13896070 £3.04 new to order 10-14 days
    159137 £10.26 each new to order
    174937 no longer available and no used to offer
    180936 £308.97 new to order
    176626 £321.71 new to order
    176425 £174.32 in stock
    176642 £72.46 new to order
    182391 £6.27 new to order
    181753 £43.49 new to order
    115980 no longer available and no used to offer
    177029 £32.33 in stock
    177027 £38.12 new to order
    2x 172918 £3.02 new to order
    181751 no longer available and no used to offer
    172934 £28.98 new to order
    219570 £84.04 new to order
    180841 £262.88 new to order
    180701 £252.53 new to order
    all new to order parts are likely to be mid jan now
    armedferret and AandSC like this.
  21. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Reply email from Eurospares .
    Shift assembly .
    no longer available for order
    174937
    115980
    181751
    where the fun begins finding them ...
    armedferret and brogenville like this.
  22. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  23. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Love it my first gated shift part on the way .
  24. brogenville
    2,234
    Robin
    $90! That’s nuts!!!
