CS - Enzo Brake Rotors? | FerrariChat
Discussion in '360/430' started by Pzerohero, Nov 10, 2013.
  1. Pzerohero
    Pzerohero Karting
    May 28, 2013
    70
    I saw a CS recently with what look like Enzo ceramic brake rotors, they were bigger than the ones on my CS and had a kind of flower pattern around the centre. I think they are also used on Scuderias, does anyone know if these bigger brakes were a factory option?
  2. tazandjan
    39,170
    The Enzo has 380 mm front rotors, same as the CS, and 380 mm rear rotors, larger than the CS's 350 mm rears. Maybe you saw Scuderia brakes, 398 mm, which barely fit inside the CS wheels with minimal clearance. Or Mov'It front calipers, which measure 396 mm, like the ones on my 575M.
  3. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Speaking of Scud brakes....
    Can front Scud brakes be fitted to a 360 ? Using oem Scud wheels, the 8" in
    the front, should be able to fit them.
    What adapter bracket and who has them, would I need ?
    Thinking about doing this...Using the Girodisc steel front rotors, and retain stock rears.
    What pads are available for steel rotors with Scud fronts ?
    Any issues with braking balance using the stock rear brakes ?
    Why do this ? Just got Scud wheels, want to fill the wheels and additional
    performance for track time.
  4. rb4u
    rb4u Rookie
    Oct 5, 2013
    12
    You will need the comparable calipers that can take larger rotors, space calipers out is one of the options.
